Question about Sewing Machines
When I adjust the needle position in the center, the underneath thread loops. It sews fine when the position is left or right. Do you know how to fix this?
  • Sewing Machines Master
  • 626 Answers
1.Take the feed dog off and check for a spot in the center for rough spots.
2. It is likely you can fix it with a finger nail file and sandpaper or to order a new one.
Posted on Apr 05, 2015
I just had my 7470 serviced because the thread tension was messed up. Now as I'm sewing along, the needle will move from center position to left position by itself and then within a few stitched,
the gear or part that holds the needle position in place may either
be getting jarred or is worn,,
try using a different threadThe needle thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
also try adjusting the top thread tension
as far as the bright spot, the display could be going out.
sometimes the repair person does not check the machine to
see if the machine is working correctly, because they would have
to charge more and some don't so you have to bring the machine
back more often and that makes them more money.
Dec 18, 2012 | SINGER 7470 Sewing Machine
Stitching is too loose on the Juno Janome Serger Model 3434D
sergers the most frustrating machines. Every time you change fabrics you go through a tension adjusting phase.
First make sure you have threaded the machine in the proper order. upper looper, lower looper, then needles from right to left. Always thread any machine while the presser foot lever is in the UP position.
If you ever break a thread... you MUST pull all threads and rethread using the proper order.
Ok that's out of the way. Pull all your threads and get out several pieces of the same fabric scrap. Thread each pathway with a different color. This will help you determine which thread is giving you fits. Sew a test strip. Which thread is loose? tighten/loosen that tension. Keep doing this until you have a well balance seam. Then clip the colored threads starting with the upper looper thread, tie off to your proper color for your seam pull the thread through and up through the throat plate. proceed in this manner with lower looper, right needle, left needle. Sew a test seam.
Good luck.
Aug 08, 2012 | Janome Sewing Machines
Kenmore 385. 15343600
Remove bobbin, presser foot, needle. Tip machine back on towel gently. Unscrew plate--don't lose screws! Do not service in presence of children and curious pets. Put foot pedal next to you on tabletop. Use Zoom Sewing Machine oil. Any part MOVING that are NOT gears get one drop oil. Any DRY ONLY gears get dab of Singer sewing machine lubricant. Replace screws. Secure screws. Open left front compartment & one drop oil @ top of needle bar. Open race shuttle (where bobbin case fits in). One-half drop oil of on oscillating hook (bottom left - hand corner...smear that oil around! Insert NEW needle all way UP in needle bar groove, flat needle shank toward back. Turn handwheel towards you and raise. Raise presser foot so that threading locates all tension slots a's you pull thread TAUT from spool to each tension slot and left to right through silver, metal take-up lever, and down to tension bracket, pass needle, then pull 6" thread towards you and thread from FRONT to BACK of needle. Place bobbin into case and "thread" it. Set presser foot on DOWN position. Turn handwh towards you, dipping needle into needle plate. Make loop with bobbin thread, pull towards you. Place a good 7" underneath presser foot (both threads). Let machine RUN on 24" scrap to distrubute oil/lube. That's it! Jimmy
Apr 05, 2012 | Sewing Machines
Can't set the tension on needle or bobbin to match
1. make sure your machine is threaded right.2. set the tension between 3 and 4 and play with the tension as you need it to adjust it.3. make sure the bobbin is threaded right.make sure to visit the site below; it has solutions to multiple problems and instructions how to thread the needle or bobbin. Good luck.htt://Fix Looping/Knotting Thread Fix Knotting/Bunching Thread Looping Bunching & Knotting Thread
Aug 03, 2011 | Euro-Pro 1260DX Mechanical Sewing Machine
I cannot ser a straight stitch with the needle in center position. The manual does not state how to adjust needle position (left, center, or right). Because the needle is in the left position and the...
Some machines are not designed to sew the straight stitch with the needle in the center position. Some are left or right position to do that and it is simply the way they were designed. Linda at Relics
Jul 04, 2011 | Husqvarna Huskystar 215 Sewing Machine
How do i thread my needle with the singer handy stitch?
  1. Loosen needle screw & insert needle with shank's flat side facing front of machine. Push needle in all the way, then tighten screw to hold needle in place.
  2. Install a fully wound bobbin by loosening bobbin nut & placing bobbin on top. Re-attach bobbin nut & tighten. If standard thread spool will be used, then attach spool pin to bobbin shaft & place thread spool onto shaft. Attach white spool cap on end of thread spool, then tighten. Bobbin/spool should unwind facing forward toward needle.
  3. Bring end of thread through thread guides & over tension control. Pass end of thread through needle eye, from back to front, & pull it out about two inches.
  4. A spring pushes pressor foot onto fabric that is being sewn, so lift pressor foot & place fabric underneath.
  5. Turn large handwheel on side of machine (handwheel can be turned in either direction) to raise needle arm to its highest position.
  6. Holding the Handy Stitch in place with your right hand, press on power switch & begin sewing. Guide fabric (being sewn) with your left hand.
  7. To end this sewing session, turn off power. Turn handwheel to raise needle to its highest position. Carefully pull out about three inches of thread through needle & snip, then lift pressor foot to remove fabric. Turn fabric over & loop needle threader through last stitch. Place end of thread from underside through eye of needle threader, & pull to loop through. Pull to tighten and snip end of thread.
Nov 11, 2010 | As Seen On TV Handy Stitch Mechanical...
I can start working withmy baby lock, the needle brokes verytime i runthe machine , and i can not sew
If this machine has a needle position adjustment and it is on the center position -
and you are sewing a zig-zag stitch and using a presser foot with a narrow opening this could break the needle
and the needle plate is a single hole, this will break the needle.
and you are sewing a straight stitch with a new needle and it breaks, the machine needs to go in for servicing.
Feb 13, 2010 | Baby Lock Sewing Machines
Babylock seger machine keep breaking the left side needle.
Try rethreading the machine, and make sure the thread is not wrapped around anything. Then check the tension for the needles. Run a few inches of chainstich off slowly, while watching the thread and loopers make the loops over the finger. Your threads may be in the wrong position, or underneath the wrong parts to start.
Jun 12, 2009 | Baby Lock Eclipse Serger
JANOME RX18S
If it was sewing correctly BEFORE the needle break...why did the needle break in the first place?...and what fixes did you make?
If it sewed properly...what changed?
Cut your upper thread close to the spool...make sure the presser foot is raised and pull the cut off thread section through/out of the machine from the needle area (sewing direction...do not pull the thread backwards!)
Clean out the bobbin area...remove any traces of lint or pieces of thread...look for any broken off needle pieces... brush the bobbin area out....then add a drop of sewing machine oil (but only if your manual says to oil that area).
Remove the needle plate to expose the feed dogs...brush/clean out that area too and add a drop of sewing machine oil...then secure the needle plate back on.
Replace the needle...do it again...yup...some needles arrive bad from the factory. Make sure the needle is inserted and positioned properly. Then thread the machine WITH the presser foot in raised position. (The thread needs to get seated into the upper tensions.)
..with the.presser foot down...thread the new needle.
Oh...and use the correct needle for the thread. (a universal 80/12 is standard).
Thread can cause issues too. Try a different bobbin, or maybe a different spool of thread to see if that makes a difference.
Mar 25, 2017 | Janome Memory Craft 9500 Computerized...
Sewing Machines Logo
29 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
