What way round does the drive belt go on? - Washing Machines
  • Washing Mach... Master
  • 5,323 Answers
The ribbed side inward smooth surface outside
Posted on Apr 20, 2015
Do I need a new belt or Service. the drum still turns but out of round
Out of round? Do you mean off centre, If so it sounds more like bearings than belt. Belt connects drive motor to drum but nothing else
Jan 11, 2018 | Washing Machines
Alternator belt diagrams
dear you have two free roller (tension er & free roller ) this two must be out > anther four drive roller must be inside the belt ,So put the
belt a round 4 roller first then round out the free roller ,last press tensioner roller
Nov 08, 2013 | 2005 Skoda Fabia 1.2
Where can I obtain the large round drive belt for MR929 tape recorder
I am not famailiar with this deck model but if you know the brand name you might be able to search for the belt at Marr Communications where Fred sells belt kits.
http://marrscommunications.com/
Feb 06, 2013 | Audio Players & Recorders
Diagram for drive belt pulleys for cub cadet 1045
Round the two outer pulleys on the deck. Round the the outer pulley in middle deck, round idle pulley inside, next pulley in center of deck to drive pulley
May 03, 2012 | Garden
The drive belt off my AWA turntable has come off and I cannot re-configure it
undo clip on centre of deck circlip normally (round clip) remove deck platter round plastic that records sit on...when removed turn over replace drive belt if brokern . if just come of place belt around the inner circle so there are no twists etc on the belt ....look at near outer edge of platter there is a clip you can stretch belt to to hold so you can put over drive motor...(belt stretch from centre to clip creating v with the bely as you veiw from above ..locate motor on the deck noe alifn top of v with positin above motor .. when done drop down platter onto centre shaft again.gently turn the platter clock wise until belt locates correctly with deck ..replace clip and test ..if ok done ..if not repeat until you get it right....sometimes over time belts stretch so a new belt may be required ..ebay can supply most belts . type in turntable drive belt ..measur size of belt by cutting is it..(if strectched and no use) measure lenght of belt find replacement belt that is smaller than measurment .i.e nearest size ...hope this helps yammandan
Aug 19, 2010 | Audio Players & Recorders
The drive belt on my old john deer riding mower broke how would i fix
need to purchase a new belt should be numbers on it too get the right one after getting it it will fit round the pulleys under the mower from the main drive to go round a tenshoner to end up round the blade pulley just need to figure its ruote round the pulleys the tensioner pulley is the last one to fit it on as you need to pull against the tension to get the belt to go round
Sep 29, 2009 | Garden
How to attache drive belt to drive drum .belt will not reach.loosening bolts that hold motor on did not help.forced on but belt twisted on drum.
Remove rear cover of washer, and top cover also, tilt washer towards you, get someone to hold washer steady, fit belt round motor pulley,and slowly feed belt round drum pulley, watch your fingers, keep feeding belt round oulley, turning drum at same time, it will be tight, but persist, and belt will go on.
Please rate my solution.
Thanks.
Sep 28, 2009 | Hotpoint Aquarius WF220 Front Load Washer
Drive belt came off spindle on Hotpoint First Edition Washing Machine.Have tried to replace but back of machine does not remove, just a small access hole. How can I refit a new belt please??? John Bennett...
Remove rear panel, remove top cover,.tilt washer forwards, get someone to hold it for you, and fit belt round motor pulley first, then start feeding it round drum pulley, easing drum round at same time, it will be tight, so watch you fingers,
Thanks.
Sep 13, 2009 | Hotpoint First Edition FEW12 Front Load...
Fitting a new drive belt to a hotpoint aquarius
Remove lower rear panel, tilt washer forward, getting someone to help, and fit belt round motor pulley, then fit belt round drum pulley, slowly turning the drum pulley round as you feed the belt on, it is very tight, and you might think the belt is to small, but this is normal, as the belt stretches, just persist, but be careful you do not trap your fingers. Good luck.
TRhanks.
May 10, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
