Question about Kenmore Kitchen Ranges
Kenmore electric range model 790.9414 flashing F11. Need answer to code. Thank You
SOURCE: manual for kenmore electric range
I finally found a website where I could order the manual.
Thank you.
Posted on May 28, 2008
IrishDruid
  • 2712 Answers
SOURCE: Could you tell me what F11 code means?
F11 error code means there is a problem with the Control panel. Could be melted wiring, etc, since you left the oven standing. However, you can try unplugging the device from the power socket for about 5 minutes and reconnect. If the error goes away, then well and good; if not, you may have to replace the panel control.
Posted on Oct 25, 2008
blueextc3221
  • 15935 Answers
SOURCE: Hi,Im tech and I have a problem with range
The F10 F11 F12 F13 F14 Error Codes indicate that the electronic oven control board senses a runaway temperature condition in the oven through the oven sensor circuit.
This can be caused by a faulty oven temperature sensor probe or a failed electronic control board.
Oven temperature is detected by the control board as it monitors the resistance through the oven temperature sensor circuit.
You could have a failed oven temperature sensor, a wiring harness failure, an open thermal switch or a failed electronic oven control board that would cause this problem.
The first component to check would normally be the oven temperature sensor probe.
If you have a volt/ohm meter, you can shut off the breaker for the range and remove the screws that mount this sensor to the back wall of the oven.
Carefully pull the wire harness into the oven cavity until you get to the wire harness disconnect plug.
You should have enough slack to pull it this far into the oven.
Disconnect the sensor but do not let the wire harness retract back through the back wall of the oven or it will be hard to reconnect.
Measure the resistance of the oven temperature sensor with your volt/ohm meter. At room temperature, the resistance should measure around 1100 ohms.
The resistance chart is shown in the image below.
If the resistance is above 2200 ohms at room temperature, then the sensor probe is causing the F10 error code and will need to be replaced.
You can order a new sensor probe from the Sears PartsDirect website. The part number for the sensor is 316217002.
If the resistance is normal, then one of the other causes mentioned above is producing your F10 code.
You would need to access the electronic oven control board (Timer) in the console and check the resistance at the sensor circuit connection to the control board as the next step in troubleshooting this problem.
http://media.fotki.com/1_p,wbqdsfkrfqtswfqxgtqsskgwtqkq,vi/krdbrtqkgxkrbbqbrwb/1/1303472/5961857/image37801img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
&^%TG
Posted on Oct 01, 2010
Macmarkus
  • 2605 Answers
SOURCE: I have a Kenmore Elite Electric Range Model #
Hello, welcome to FixYa.
I understand you have the Kenmore 7904671 range, correct ? I also understand based on your post you're getting the F11 error message, correct ?
This range is built by Electrolux/Frigidaire as you may or may not know and a
ccording to the service manual, here's what it is and what you can do
...I will also add, Fault codes are not a foolproof system. Never assume that a part has failed based on a displayed fault code.
("TST" is the touch sensitive panel and EOC is for Electronic oven control or timer)
...If you pull/slide the unit away from the wall and unplug it or turn the house breaker off for 30 seconds to a minute the control should reset. That should do it...unless either of the control's has failed.
Let me know how you make out and if you need anything further I'll be glad to help in any manner I can. Good luck.
Regards,
Macmarkus :)
Posted on Oct 14, 2011
  • 17 Answers
SOURCE: Kenmore gas range F11 error code
The "F11" fault code indicates a shorted button on the electronic oven control. This means the oven control board will likely need to be removed and replaced. You could disconnect power, wait 30 seconds and reapply power. If "F11" returns upon power-up, replace the electronic oven control board (EOC). but if i had your model number i could nail it right on the head with a fix...
Posted on Dec 13, 2012
WHAT MEANS ERROR CODE FOR MY DRYER MACHINE F11?
Communications error.
  • Troubleshooting and Repairing the F11 Error Code in a ... www.youtube.com/watch?v=RXH5MWzZJKM
    • BY SAMURAIREPAIRMAN
    • 6 MIN
    • 121K VIEWS
    • ADDED 2013-10-22
    Video embedded · Troubleshooting and Repairing the F11 Error Code in a ... Troubleshooting the F35 Sud Error Code in the Whirlpool Duet Steam ... Washer Dryer ...
  • Kenmore Elite He3 F11 Error Code - WordPress.com https://hydripinri.files.wordpress.com/2015/10/kenmore-elite-he3... · PDF file Kenmore Elite He3 F11 Error Code circuitboardmedics.com/whirlpool-duet-fdl-ccu-repair/ How to troubleshoot the ... Kenmore F1 Error Code He2 Dryer Problems Amp Solutions
  • Kenmore Washing Machine Error Code F11 - WordPress.com https://meofapitri.files.wordpress.com/2015/07/kenmore-washing... · PDF file Kenmore Washing Machine Error Code F11 what does f11 mean - Kenmore Elite HE3 Washing Machine. The F11 code is from a communication break in the serial link from ...
  • Related searches for ERROR CODE DRYER F11
  • Whirlpool Duet F11 Error Repair ' Circuit Board Medics circuitboardmedics.com/whirlpool-f11-code Whirlpool F11 Error. This is a repair service for the Whirlpool Duet F11 error code on a Whirlpool Duet washer.
  • Bosch Tumble Dryer Fault Code F11 - prapmumbmihe https://prapmumbmihe.files.wordpress.com/2015/08/bosch-tumble... · PDF file Bosch Tumble Dryer Fault Code F11 Bosch Exxcel tumble dryer error code F:09 · Bosch Exxcel WVT. Asciugatrice Bosch Wts86511It: Errore F11 Hello, My dryer ...
  • Whirlpool F11 error code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • LAST UPDATED: 2014-02-18
    • 6 POSTS
    • FIRST POST: 2012-02-18
    I got an F11 error code on the washer and tried some of the things discussed on the Applianceblog.com site for simiilar duet washers and found a link to this site ...
  • Jan 30, 2016 | Dryers
    F11 code flashing, oven wont come on
    Hello Paul, this is Z. Thank you for your inquiry!
    If you are receiving an error code F11 on your Frigidaire range, it typically indicates that your range has detected an issue with the runaway temperature (overheating). One of the best ways to determine if this is a false error code is to reset the power to your appliance. You can do this by either unplugging it or flipping off the breaker for about ten minutes. If the error code persists, at this moment I would suggest connecting a professional to proceed further. Most likely the EOC (Electronic Oven Control) or RTD Probe (Resistance Temperature Detector) will need replacing. I hope this information helps to some degree.
    Jun 02, 2014 | Frigidaire FEF366 Electric Kitchen Range
    Dec 13, 2012 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
    I have a Kenmore Elite Electric Range Model # 790.4671 that is flashing a F11 Error. Any advice on repair? Thanks
    Regards,
    Macmarkus :)
    Oct 14, 2011 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
    Kenmore electric range shows a f 10 code when oven is on after while.
    F10
    Runaway Temperature.
    1. (F10 only) Check RTD Sensor Probe & replace if necessary. If oven is overheating, disconnect power. If oven continues to overheat when the power is reapplied, replace EOC. Severe overheating may require the entire oven to be replaced should damage be extensive.
    2. (F11, 12 & 13) Disconnect power, wait 30 seconds and reapply power.
    3. (F11, 12 & 13) If fault returns upon power-up, replace EOC.
    I would first pull your range out from the wall, unplug your range, then take off the back access panel and using a DVM check the ohm reading on your oven sensor#37 here:
    http://c.searspartsdirect.com/lis_pn...9098-00003.png
    It should ohm out at 1100 ohms at room temperature.
    Here's the oven sensor probe for your model:
    Part#316217001
    show?id=yo6223wzsty&bids=122738.613159039&type=10&subid=
    partimage.aspx?imgid=z3bqljbfbxnfmtawnzeynjezl0ldvy9zb3rvahb0cmfwlw%3d%3d
    If that checks good, then your EOC control board is the problem.
    Here's the EOC Board for your model:
    EOC Board - Manufacturer's Number: 316418207
    I hope that this helps.
    asnowman
    Mar 05, 2011 | Kenmore 95592 / 95594 / 95595 / 95599...
    Sears (Kenmore) drop-in unit, Model 911.4698815. Ran the self-cleaning cycle - now it's showing Error Code F3 and neither the bake element nor the broil element will work. Any help would be...
    All F3-E Codes - Oven Temperature Sensor (RTD) or Warming Drawer Defect - Replace oven temperature sensor (RTD).
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^$#@
    Sep 12, 2010 | Kenmore 95822 / 95824 / 95829 Electric...
    Kenmore oven error code f10
    on that type of range F10 indicates a problem within the electronic control, but it could possible be caused by a faulty temperature sensor.
    I would recommend service from a technician
    May 27, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
    Kitchen Ranges Logo
    69 people viewed this question
    Top Kenmore Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    Mike Carew
    Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
