Question about Echo Garden
Echo Cs-400 chainsaw. Standing the carb up with the sliver vent on top which fuel line goes to the 90° inlet on the bottom and which line from the primer bulb to the carb?
    New Friend:
  • 4 Answers
The lengths of the line and,or the bends in the line . I would say the line from the bulb would go the carb since it is used to prime or,choke the carb.
Posted on May 06, 2016
4 Suggested Answers
SOURCE: McCulloch,Mac 3200 Chainsaw fuel lines...........
retgmdI need the same, did you ever find one?
Posted on May 27, 2010
  • 2239 Answers
SOURCE: Walbro WT891 carb on a
Who connected these hoses? the normal routing for a machine with a primer is like this, the fuel hose from the tank with the filter on the end goes to the carb fuel inlet nozzel ( not to the primer ) nearest to the pump cover ( cover on carb held with one screw ) the pipe from the metering side of the carb connects to the shorter nozzel on the primer bulb ( suction side ), the longer nozzel on the primer ( pressure side ) connects to the pipe going back to the tank, just remember the primer pulls fuel from the carb,into the bulb, and pushes it back into the tank, it is not actually a primer it is a purge. because it is connected this way it is impossible to flood the engine no matter how many times the bulb is pressed.
Let me know if it starts and runs.
Posted on Jan 31, 2011
  • 1169 Answers
SOURCE: I have a Echo chainsaw CS-400 and the carburetor has three nipples which two is on top of the carb and the other is at the bottom in a curve. which is the inlet for the fuel line with the filter
Walbro WT-820
Posted on Apr 04, 2015
Testimonial: "So the suction side of the primer is what you're saying? And the fuel line with the filter goes to the fuel inlet?"
What is the little black hose fuel vent for on my echo CS 400 chainsaw?
To let air into the fuel tank as the fuel goes down, otherwise there would be a vacuum and no fuel supply!
Jul 25, 2016 | Echo Garden
Cs-302 fuel line replacement
How do I remove the Flywheel on a 1982 Echo chainsaw 302? I can't get to the fuel line since a piece got stuck under the flywheel.
Feb 01, 2014 | Echo Cs-302 Flywheel Assembly Cs 302
I have a wt820 carb on an echo cs400 how do the fuel lines route
wt820-carb-echo-cs400-fuel-lines-route-u2zok31ofbeqiqkdplhepnij-2-0.jpg which is for the fuel line with the filter and which is for the primer bulb?
Nov 13, 2013 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
I have a walbro carb on a craftsman chainsaw..Can you tell me which fittting on the carb (TOP RIGHT) OR (BOTTOM LEFT) gets the fuel line with the filter on it??
All chainsaw primers pull fuel from the carb, so the fuel inlet ( pipe with filter on the end ) goes to the connection nearest to the pump cover of the carb ( the alloy cover with a single central screw )
Feb 01, 2013 | Craftsman sears 18" Chain Saw Chain (...
Poulan 2150 fuel line routing wt324 carb
the large hose from the tank goes to the suction side of the primer bulb. The large line from the out put side of the bulb goes to the bottom inlet of the carb.
the small line goes from the top outlet tube on the carb back into the tank near the primer bulb.
Mar 25, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
I may have lines on Backwards??
filtered line from tank goes into top inlet at carb. bottom inlet receives line that goes to carb side of primer {draw side} 3rd line goes from push side of bulb bach to fuel tank.
Echo cs-341 stalls out when cutting sideways
Make sure the fuel filter is indeed attached to the fuel line in the tank and pushed down to the bottom of the tank.
Mar 14, 2009 | Echo 30.1CC Chainsaw With a 14 In.bar and...
Open Questions:
Garden Logo
210 people viewed this question
Top Echo Garden Experts
Jim Parker
Jim Parker
Jim London
Jim London
colesmowers
Are you an Echo Garden Expert? Answer questions, earn points and help others
