Question about LG Televison & Video
LG50LN5600--LEDs flash LG logo on startup--then goes blank. I have already replaced the power board--no change. Any thoughts?
SOURCE: Acer Aspire 5100 will not start right
It seems your hard drive has corupted.
This sucks, all you have to do is push ALT F10 and then go through the reseting menu, you will loose everything on there though except the original data.
Posted on Jun 26, 2008
SOURCE: My Acer Aspire 5100 wont start up correctly
I had the same problem after running an update to my Norton anti-virus software. When booting the laptop, press F2 to go to the setup menu. One of the options allows you to change the order that is searched when booting up. I moved the boot from hard drive to the last option, allowing it to boot from a network first (which it doesn't find), then from a portable device second (which it doesn't find), and finally from the hard drive. When I boot up, after it doesn't find the first two options, it boots from the hard drive with no problem.
Posted on Nov 12, 2008
  • 1684 Answers
SOURCE: Acer AL1716 A Monitor does not start
The problem on your monitor is a bad power supply. Because of heat buildup in LCD monitors parts called capacitors overheat and blow out. You can go to our web site at:
www.ccl-la.com/badcaps.htm and see what to look for. If you open your monitor and see blown capacitors that look like the pictures on our site then replace the bad ones and you should be back going. Email me if you have additional questions or if you need to get the capacitors, we carry them in stock.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Posted on Aug 27, 2009
Kuwagata
  • 181 Answers
SOURCE: I have a VP201m. display flashes at startup and goes black
That's not monitor problem, it's your CPU, probably the Operating System crash!!!( Windows,etc).
Try reinstall it to solve the problem...
Posted on Oct 18, 2009
  • 99 Answers
SOURCE: 24000 BTUs LG split air conditioner external unit
Hi; Look into Your owners manual for troubleshooting codes. If You dont have a manual call or google the manufacturer...alpharome416
Posted on Jan 22, 2010
LG LCDTV 60LD5 turn on TV logo appears and nothing else. Standby indicator flashing. Help
This happened to our tv so we took the panel off the back and realized the power is actually still on but the screen goes black so that's why I thought it was turning off. Actually the power is ok but found that the connector cable that connects the slave 1 and 2 board is burnt. Now we just need to figure out how to order and replace those boards and the connector.
Sep 13, 2017 | LG Televison & Video
Hi my lg tv just went blank when you put it on it flashes the lg logo then goes blank tss a 55" thank you rochelle
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Jan 10, 2017 | LG Televison & Video
Can someone point me at the blink codes matrix for this LG line?
Check out the inverter board that powers the back light leds.
Mar 18, 2016 | LG Televison & Video
How do I determine if it's the LED Driver or the LED lights that are bad on my LG LED TV?
If it was the LEDs, then you should still have some working. My first thought would be the LED driver circuits.
Best of luck.
Feb 23, 2016 | LG 47" 5700 Series LED HDTV - 47LN5700
Lg 50ln5600 backlight issue
Check whether the back-light start voltage [control voltage] comes to the backlight inverter section of the power board; from the main board. It sounds that that voltage does not come from the main board, after the firmware has been loaded up. If so the main board will have the fault. Contact any service technician.
Aug 03, 2015 | LG Televison & Video
Hello , so I have this problem with my tv lg 47wl5600-UA pictures, on startup the lg logo show and then goes off only for da sound can be heard with da cables box in place. I read and thought if I change...
Fault with its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Feb 09, 2015 | LG Televison & Video
HP Laserjet 4345mfp after memory count finishes control panel goes blank(display is working but all black) nothing else happens. I've already replaced formatter, dc controller and engine power supply,...
I'd be willing to bet that when you changed out the formatter, you used the silver square looking flash dimm from the old board and put it on the new board, If you replace the flash dimm I think your problem will indeed go away... 8mb Flash Dimm
Sep 12, 2011 | HP LaserJet 4345mfp All-In-One Printer
My lg 62sx4d-ub will not turn on. You push the power button, the ballast clicks, then the leds begin scrolling white. Eventually the lamp led flashes red and it shuts back down. I've changed the bulb...
I just had the same problem. Came down to a bad cap on the main power supply board C871. This is the first filter cap after the diode on the 6V supply. Funny,, the schematic calls for a 25V part,, however this one was rated at 16V :-)
Replaced with a new one,,, all is good to go!
Jer in Hayden
Oct 01, 2010 | LG 62SX4D 62" Television
Televison & Video Logo
53 people viewed this question
Computer Repairing
Computer Repairing
