Question about Ariens Garden
How tite show the bolt on the pto cluch on the motor be
    Sergeant:
  • Ariens Expert
  • 187 Answers
75 Nm (55 lb-ft)
Posted on Apr 06, 2015
Engine will not crank
You need amps to crank the starter. Volts of the horn and lights. Get the battery load tested.
Oct 26, 2014 | Garden
The 20 amp fuse blows when i engage the pto. cub cadet 1045 20 hp
Pto cluch is shorted to ground
unplug the pto to isolate the pto from the circut,
Does the fuse still blow ?
use a ohm meter to test the plug at the pto
Test each side of plug to pto body or ground if meter goes to zero the cluch is shorted , and is not fixable (sealed unit)
you will have to by a new one I'll say around 50 to 75 dollars
Aug 24, 2014 | Garden
On a rzt 42. The pto clutch bolt loosens and clutch falls off with use of 10 minutes or less. How do I fix?
The PTO clutch has a bolt that goes through it and into the vertical shaft of the engine. MANY of the PTO clutches have a large spacing washer that goes on before the PTO clutch is slipped onto the shaft. If the washer was lost when the clutch was changed, the bolt might be bottoming out in the shaft rather than tightening on the threads like it should. I'd get a diagram for your model and make sure all parts are in place.
Jun 05, 2014 | Cub Cadet RZT S Series
How can i get pto cluch to ingage?
This problem needs more information provided.
Look for safety interlocks that have not been engaged, or possibly broken. The switch under the seat will not allow the PTO to engage if it does not detect someone in the seat.
If the PTO is electric, look to see if the plug is loose at the PTO.
Check to make sure that the PTO mounting bolts are still secure.
May 20, 2014 | John Deere Garden
How to test a magnetic cluch
Assuming you are talking about the electric pto clutch , with the pto switch in the on position you should have on the two wires going to the clutch battery voltage between the two wires. With the machine in the run position, engine off and you probably will need someone sitting in the seat so the seat safety switch will allow voltage to be supplied to the pto clutch.
Dec 06, 2013 | Cub Cadet Garden
Why won't my pto engage?
They are normally electro magnetic clutches, the click is the cluch engaging so i would guess it is working, arev you sure the belt is not broken or lose?
Feb 12, 2012 | Garden
My Cub cadet pto cluch bearing is froze up on my 2518 lawn tracto
A medium length extension (stuck through the grill), a swivel and an impact is all you need to remove the pulley with the frozen bearing. It's just a bolt, a washer, and a lock washer holding it on. You just need to remove the pulley to see if the bearing is stuck. Take the pulley to your local shop that can press bearings and you can be up and running for $20 dollars instead of $300. Here's a diagram I found on partstree:
http://www.partstree.com/parts/?lc=cub_cadet&mn=2518-48+Tractor&dn=0043700012
Apr 08, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Bobcat ZTR new blade brake won't engage while engine is running
SOUDS LIKE THE CLUCH SAFTEY SWICH IS BAD OR THE SEAT SWICH MAY BE BAD CK THAT OUT AND LET ME KNOW OK THANKS
Aug 18, 2009 | Husqvarna 23 Hp 48" Deck Yard Tractor
I like to know how to take off a cluch and motor fan and a z71
clutch and fan assembly are connected to the pump with four bolts. Have someone push down on the drivebelt so the pump pulley won't turn and break each bolt free, then remove the bolts.
Jun 23, 2009 | 1997 Chevrolet K1500
Garden Logo
47 people viewed this question
Top Ariens Garden Experts
Phil Walker
Phil Walker
Matt Olenzek
Matt Olenzek
enb54
Level 1 Expert
Are you an Ariens Garden Expert? Answer questions, earn points and help others
