Question about Measuring Tools & Sensors
My 17.5 hp briggs and stratton will start and run while the choke is on but when I try to idel up and come off of choke it dies it has automatic choke soo and it also will not start if not choked
  • 352 Answers
Something is restricting fuel flow. It might be:
  • Debris in the fuel tank. - Clean the tank.
  • Debris in the fuel filter (if it has one). - New filter.
  • Debris in the inlet valve (float valve). - Disassemble the carb and clean.
  • Debris in the jets. - Disassemble the carb and clean.
  • Hard deposit in the jets - New Carb.
Good luck.
Posted on Apr 05, 2015
SOURCE: Need carburetor adjustment
I had a similar problem with my 23 hp briggs. While cleaning the carb I found that the great gas we get today had eaten the seal around one of the jets in the throttle body causing it to fall out. Replaced the jet and now runs like a champ. Hope this helps.
Posted on Jun 07, 2009
protek480
  • 1723 Answers
SOURCE: i have a briggs and stratton will start will
It sounds like your flooding out. Do yo live at high altitude? It will need to be jetted for altitude, (less gas)
Posted on Jun 30, 2009
mrrichardlbo
  • 59 Answers
SOURCE: Have to choke to keep running
this is not hard to do here is what you need , 1 can of carb cleaner anykind will do , a 10 mm rench to remove the bowl 7/16 socket . now remove the carb take a good look where the spring is before you take the carb off it muct go back in the same hole , now that you have it off take the bowl off remove the float place to the side here is the fun part look in the carb you will see some small hole spray them this will clean all of the old gas out if you can let it set for about 10 min then do it again blow out with air if you have one nothing else to do but reinstall this works most of the time ...Good Luck..
Posted on Aug 16, 2009
  • 15 Answers
SOURCE: Briggs and Stratton 20hp twin cylinder runs only with full choke
Had one on my saw mill had this problem as well Try pulling bowl off bottom of carby as the float can get **** with old fuel especially ethanol fuels as they attract water bowl is normally held on with one center screw on bottom of carby. Note always turn fuel off and let engine run out of fuel as this stops goop from building up in carby
Posted on Sep 06, 2009
SOURCE: Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1: will only start with choke on and after warm (chok...
If it has a plastic intake manifold there is your culprit. The flanges warp and produce vacuum leaks and all three.
Posted on Nov 06, 2010
B&S one start pull take numerous pull to start
If it is system I am thinking about it does have an automated choke system and that it is out of adjustment
Jun 03, 2015 | Briggs & Stratton Lawn-Boy 10640 20-Inch...
I have a 25 hp ohv briggs and stratton, it will not run without having to choke it some
Try increasing the idol by turning the idle screw up.If that doesn't work the carburetor may need to be reset properly or it might need an overhaul.
Mar 09, 2011 | Briggs & Stratton Briggs Stratton Intek V...
I have a 22 hp bs crafstman riding mower and it would fire off starting fluid but would not on its own. I took carb off and cleaned out and got it running but only on choke. It's a v twin and on one side...
running rich will make it run colder.....I wouldn't run it anymore til you find theproblem, it will burn your valves. air leak in your intake/carb is more than likely your problem , check for cracks in the intake manifold , leaking gaskets
Feb 23, 2011 | Briggs & Stratton Briggs Stratton Vanguard...
Smoking and loosing power
Blue smoke means engine worn or too much oil in sump.
Black smoke is caused by too much fuel being sucked into carburettor.
This can be caused by a dirty air filter, choke being left on after engine is started or fault in choke system if automatic choke fitted.
Feb 21, 2011 | Briggs & Stratton Briggs Stratton Intek V...
3.5 Briggs with not run at full throttle
same problem, was told it was the jets, are your symptoms as follows
runs at low throttle, will only run at full throttle if fully choked
dies if choke is relieved
Apr 15, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Motor will run fine with the choke on , but push
The governor is out of adjustment. It will be located on the side of the engine with a rod pointing downward with a weight
Apr 14, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Briggs and stratton runs good for 5 minutes then starts to smoke
My first thought is that the throttle lever is being pushed so far forward ( max RPM's ) that you are running the engine 1/2 or better choked
Look at the choke butterfly with the throttle in your normal run position it should be completely open
This may require and adjustment in the control rods or might be as simple as not pushing the throttle wide open
Apr 06, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Sep 04, 2009 | Briggs & Stratton Briggs Stratton Intek V...
21hp b ANd S engine keeps stalling unless choked
CARB CLEANER FOR CARS WILL WORK JUST FINE,BUT YOU MIGHT HAVE TRASH IN THE BOWL.IF SO YOU WILL HAVE TO TKE THE CARB APART
Aug 17, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Measuring Tools & Sensors Logo
174 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
