While washing water comes out bottom of tub in the middle?
    Genius:
  • Washing Mach... Master
  • 1,585 Answers
Needs new bearing kit
Posted on Apr 13, 2015
  • 686 Answers
SOURCE: water leak
POSSIBLE LEAKING PUMP OR TUB SEAL
Posted on Apr 17, 2009
canbruce75
  • 1776 Answers
SOURCE: Soapy water left in bottom of tub.
This is usually caused by a cold water supply problem, since cold water is what is used in the rinse. Check the water inlet valve. Remove the water supply hoses and check the small screens inside the water inlet valve (especially on the cold side). Make sure they are clear of rust and debris. The solenoids can be tested using a mulitmeter or ohmmeter. Test for continuity. A lack of continuity indicates a faulty solenoid. I will attach a photo for reference. Hope this helped and best wishes.
Posted on Aug 16, 2009
Testimonial: "Thanks. We live in a very rural area and our local Maytag repairman has been stumped. What a great way to find solutions!! "
beltronic205
  • 1466 Answers
SOURCE: Oil coming in the bottom of my washing machine tub.
Yor drum bearings are faulty and nee replaced Quite an expesive repair
Posted on Sep 27, 2009
SOURCE: Spin dryer on my twin tub washing machine does
I 've got twin tub w/machine service is not spinning and draining, can you pls tell me how to solve the problem?
Thanks
Posted on Nov 07, 2010
richroth
  • 9472 Answers
SOURCE: Leaking into wash tub
The water inlet valve needs to be replaced. It is not sealing.
Here is a link to the part you need.
Posted on Aug 13, 2012
Where would the water come from if it is draining from the bottom of the washer when trying to fill tub
more than likely the pump is cracked and as it fills its leaking out. If I had the model number off the machine I could give you a better answer
Jun 05, 2012 | Washing Machines
The washing machine is leaking water and it is coming from underneath the washer during all filling cycles and running cycles why?
Could be several things. Check all the hoses, water pump, water valve also check if water is coming from the bottom of tub could be tub seal. Check that there is not a leak in the outer tub somewhere I had one that had a nail stuck in one of the holes in the inner tub and rubbed a hole in the outer tub. Have fun I hope this helps.
Aug 28, 2011 | Washing Machines
It is leaking on the bottom when I do laundry. The hoses are fine. The water seems to be around the edges on the bottom of the washing machine. The machine is only 5 1/2 years old.
if you look at the front inside panel and the side panels nd if you see like black spots half way up the panel you have bad tub seals and that's what it sounds like you have.the tubs have to be separated and the middle seal has to be changed out.you need special tools to do this job.might be better replacing the washer if it's the problem.fill it with water,run it and look at the tranny part coming out the middle of the tub on the bottom of the tub,let it agitate and put it in spin,if you see water leaking out the middle of the tub it's the tub seal
Jan 19, 2011 | Amana Washing Machines
When driaining out water comes out
Where does the water come out from? From under machine or where the drain hose hooks to the drain. If it is coming out the drain where the hose hooks the drain is most likely stopped up. If coming from underneath could be a hose or the pump leaking. I have seen something like a screw get caught and wear a hole in the tub. Check around the bottom of the tub if there is water leaking around the bottom of the tub could be the tub seal is bad. Hope this helps.
Dec 23, 2010 | Washing Machines
Water leaks from the machine tub while it is in the wash cycle or turned off with water in the tub. I can empty the tub using the spin cycle without any leaking
you have bad tub seals. is there stains on the walls inside the washer and the water is leaking in the middle bottom of the tub?if the washer is old get a new washer,did one last week but the washer was in good condition it was close to 300 bucks.you have to pull the agitator,remove the top ring,with a spanning tool you need to remove the center parts and pull the inner and outer tubs and the three nuts and bolts holding the outside tub on and replace the two pieces in the middle it's a bearing and a seal kit,but you need the tools to do it,like i said if the washer is old replace it or call someone in to do the job for you
Aug 25, 2010 | Kenmore 24032\24036 Top Load Washer
Machine leaks bad while filling
possible bad tub seal which goes between tub and transmission shaft...you know if the water is pooring out from bottom middle of tub... a hole in a water hose under machine or a disconnected air or water hose on tube...
Sep 17, 2009 | Washing Machines
Leaking below washer
Sounds like you have a leak from the tub. Either the seal in the bottom of the tub or a hole in the tub.
When you run it again try feeling around the bottom center of the tub for water or try to see if water is leaking any where out of tub. Clear water would be from the supply line , soapy water would be from tub or a hose coming out of tub.
Jun 09, 2009 | Washing Machines
Leak in washing machine
can you tell where the water is hitting the belt from is it in the middle of the wash tub or from the outside of the wash tub please let me know if its from the middle of the tub its probably the seal that keeps the agitator from leaking, and if its from the side the in lines from the water spicket or the valve that controls hot and cold in the machine could be leaking, please look closely and try to see where the wateris dripping down from. thank you, then let me know
Dec 21, 2007 | Washing Machines
Agitator won't agitate
Replace what is called the dogs in the agitator (part number 80040? i think)
Oct 29, 2007 | Roper RAS8244KQ Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
