Question about Husqvarna 235 16-Inch 34.4cc X-Torq 2-Cycle Gas Powered Chain Saw
My 235 hurqvarna wont stay running on idle - Husqvarna 235 16-Inch 34.4cc X-Torq 2-Cycle Gas Powered Chain Saw
  • JD99
    JD99 Nov 30, 2015
    I had this problem. It turned out that the carb filter screen was clogged with what looked like metal shavings. Once I cleaned the carb, I no longer had any problems. I must have used some dirty gas.
I had this problem. The carb filter screen was full of matter. I cleaned out the art screen filter and passageways. Alls great now.
Posted on Nov 30, 2015
  • 14,585 Answers
Change or clean the air filter. Service the carburetor.
Posted on Apr 05, 2015
1994 ford ranger 2.3 runs fine wont stay idling
Try TPS. Throttle positioning Sensor. This sets base idle. (Unless this model is too old for that sensor)
Sep 21, 2014 | 1994 Ford Ranger Supercab
Husqvarna 235 chainsaw wont run
Check fuel supply, proper plug (resistor) compression 120 to 145 lbs. If saw will not run have the ignition tested with a 3-point spark tester.
Apr 30, 2014 | Husqvarna 232 235 240 Cylinder Pn...
Why wont car stay running
Because the idle of the engine is to low most likely a bad idle air control its a little sensor near the air duck hose on the throttle body itself it hapen that when the battery was disconnct or down good luck and please rate the answer
Jan 08, 2014 | 2004 Pontiac Grand Prix
I have a 2005 Chevy Malibu wont stay running. Have replaced the battery and starter and had the alternator checked still wont stay running
as part of the solution i first must ask, is the check engine light on? if not, it may just be time for general maintenance (spark plugs, wires, throttle body cleaning, injector system cleaning). second, while running and running in idle, is the idle varying (continually reving up and down), rough, low or none of the above? answer back and i can help out a little more.
Feb 24, 2012 | 2005 Chevrolet Malibu
My 95 gmc 6 Cyl. truck wont run idleing.
run scanner for trouble codes, some auto parts stores will do this for free, check fuel pump and relay
Oct 09, 2009 | 1995 GMC Sierra
Why wont jeep stay running without giveing it gas
throttle is set low, or you may have a fuel pump going out.
Aug 24, 2009 | 2001 Jeep Grand Cherokee
I have a 1988 GMC Sierra 1500 thast wont stay running
Use a gage and check proper fuel pressure. With tbi fuel injection, the fuel pressure is 9--13 psi. I have seen fuel injector spray pattern that looked good to me, but, the fuel pressure was half of what it should have been. 5 psi may show a good spray pattern, but, it won't start and run a v8. In my opinion.
Any applicable trouble codes? Your obd1, you should be able to check some codes yourself, if there are any.
Apr 21, 2017 | 1988 GMC C1500
Wont stay on.
The only way you can fix this is you have the proper tools and have very good soldering skills. If so, I will post more instructions on how to fix this.
It has a blown channel, it can not be fixed without some good troubleshooting skills. The protect mode is so you don't cause more damage to it. If you continue to turn it on, you may cause more damage.
Your best bet is to take it in to get repaired at a service center.
Let me know if you require more help,
Dave
Jul 01, 2008 | Harman Kardon AVR 235 Receiver
Husqvarna 235 16-Inch 34.4cc X-Torq 2-Cycle Gas Powered Chain Saw Logo
363 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
