Question about Sewing Machines
How to sew casing
Trying to figure out how to sew the casing that is in the shirt
    Master:
  • Sewing Machines Master
  • 470 Answers
Some YouTube videos that might help:
Google
Posted on Apr 05, 2015
I have mc9900 janome when trying to embroidery on t-shirt material threads bunch up in back and I end up with holes in shirt
Are you using a fabric stabilizer to prevent the t-shirt fabric from stretching?
Also, be sure to Always Raise the presser foot when threading the top thread. Knots could be bird nests.
May 08, 2017 | Janome Sewing Machines
What is turning
Could be a couple of things.
If you are sewing a new collar, turning is done after you've sewn three edges together and then you turn the item so the right sides are out and the raw seams are enclosed inside the collar. Then the collar is attached to the garment using the fourth (unsewn) edge.
https://www.craftsy.com/blog/2013/12/sewing-perfect-collar-points
How to Sew Collar Points Melly Sews
Or turning on an old, worn garment is when the collar or cuff is unstitched from the shirt and then flipping it over so the worn part is on the underside and the fresh, clean part is facing up (as against the neck edge or, in the case of a cuff, against the arm). This is an idea from the depression era when people wanted to get more use out of an item that was showing wear.
Turn shirt collar
Oct 02, 2016 | Sewing Machines
It wont stitch tee/shirt material it misses stitchs
If machine misses stitches consistently, it can be several things.
Needle not installed correctly, not threaded correctly, Bobbin case not installed correctly, make sure the bobbin itself is inserted correctly and spinning in the correct direction.
Finally, machine may need service the timing is off. All actions of a sewing machine are carefully "timed" to form a stitch while sewing. Sewing things that were too heavy for the machine or you hit the bobbin case while sewing can knock the machine out of adjustment.
Let a professional do the maintenance on your machine. Some may opt to show you how to do more in depth maintenance yourself at home.
Cheers,
Feb 01, 2013 | Sewing Machines
What are the types of sewing machine for t-shirt making?
almost any machine can be used to sew tee shirts. all you really need is a stretch stitch and overlock stitch which event the most basic machine has these days. try using an old shirt that you no longer wear and try different stitches, stitch lengths until you are satisfied with the results,
Oct 29, 2010 | Brother LS-2125 Mechanical Sewing Machine
My 8280 modle singer: I sewed a zipper for a shirt, but the needle hit the hard part of the zipper, so the needle broken, when I replaced a new needle, but found that that machine stuck, even I push the...
If you are not able to free this easily, you really should consider taking it to a service technician to look at it in case you do more damage to the needle bar and elsewhere trying to fix it yourself.
Sep 07, 2009 | Singer 8280 Mechanical Sewing Machine
Sing a Futura Sewing Emboidery Machine, how do I
This I do quit often, just pull the shirt away from under the foot as you go, pause the machine every now and then and readjust the position of the shirt, it is time consumming but it really works and using the correct stabilizer with spray on glue as well as the plastic stabilizer on tob, (pin this very tight on top of the shirt) you get a beautiful result.
Apr 17, 2009 | Singer CE-200 Quantum Futura Computerized...
How do I do a stretch stitch?
The bes way to hem a t-shirt on a household machine is to use a double needle, straight stitch. You will see two straight stitches on top and zig zag on the back. Just make sure the zig zag catched the top of the hem.
Feb 19, 2009 | Kenmore 12102
Pockets
Dear sewer:
The only way I have found is to take the pocket off the shirt and re-sew it after you have finished embroidering it. Notrub
Mar 05, 2008 | Baby Lock Esante
Top Thread
Can you sew a normal zig zag on a scrap piece to check if the bobbin thread is being picked up.....if not, or only on one side of the ZZ, then your timing will need adjusting.
OR...
Are you using an old blunt needle ?
Feb 18, 2008 | Brother SE-270D Computerized Sewing...
Sewing Machines Logo
24 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
