Question about Daewoo Televison & Video
Help! My daewoo tv screen is all messed up at first the screen would be half black and if I unplugged it and plugged it back in it would be normal but now my whole screen is all diff colors ?
    Top Expert:
  • Daewoo Master
  • 75,599 Answers
Looks like T'Con fault. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Posted on Apr 05, 2015
zjut
  • 106 Answers
SOURCE: Half Screen went black
Try to replace the Logic board.
Posted on Jan 04, 2008
snakehead
  • 1074 Answers
SOURCE: Half Screen has colored lines, Half screen is working ok
there is a defected capacitor in the vertical circuit trouble shoot and replace. or if the vertical circuit is separate then replace the whole board.good luck
Posted on Jul 25, 2008
  • 70 Answers
SOURCE: black screen red light flashing, i unplugged the
Yes,usually there's two particular capacitors,maybe even 3. If not,then I would go with a Y Main Board since the tv will give error codes if the Y Buffer uper and lower boards have no power and therefore cause no picture,sound,and an error code.
Posted on Oct 24, 2009
  • 8457 Answers
SOURCE: Half the tv screen goes black randomly,then returns to normal
The Tuner signal board have problems.The board CPU,Chip,have intermitten short.When the chip is completely dead.The tv will get only LED light indicator power only,will not get tv signal pictures.
Posted on Apr 12, 2010
fosg2000
  • 229 Answers
SOURCE: Half TV screen is black
you have a bad Y Sustain board or X Sustain board
undo the back (if you know how to deal with electronics) and with the TV unplugged disconnect one of the board and turn on, see if works or not and try with the other one till find out wich one is.
Fosg2000, Rate me
Posted on Apr 13, 2010
Sharp tv has small black and white image in black and white and half screen pink
Sounds like your LCD Control board went bad. Very small chance it is your main board since you said you cant bring up a menu.
Apr 11, 2012 | Sharp Televison & Video
Our 13" tv has deveoped
Hello jcdcam,
Welcome, and thank you for using FixYa!
Your issue is caused but the logic control to the menus displays being "Stuck".
You can try this simple fix before following up with my next suggestion; if the first doesn't work.
Unplug power to this TV and pull the batteries from your remote for 15 minutes. Afterwards, put the batteries back in and plug the TV back in. If the picture is normal, "Yea! We win."
If the picture returns with the "Dark Menu" you will have to have the tuner control board replaced.
Have a great day!
Sep 11, 2011 | Daewoo Televison & Video
Fosg2000, Rate me
Apr 13, 2010 | Philips 42PF9830A 42 in. LCD Television
Apr 12, 2010 | LG 42LC2D 42 in. LCD HDTV
Half screen , left normal but only half usable. right was black now blue and white, Dell inspirson 1501.granddaughters so would love to fix
Reseat the video cable connection under the keyboard. If no change, press the Fn Key while Pressing power button, this will start a PSA diagnostics, there will be 2 sets of color bars appear and a Yes or No at the end of 2nd color bar, press N to start the LCD diagnostic. If the LCD is still 1/2 and 1/2 in the LCD diagnostic, you need an LCD. If the issue doesn't appear in the diagnostic, then replace the motherboard.
Jun 14, 2009 | Dell Inspiron 9100 Notebook
Mysterious black box?
Sounds like something is imposing Picture in picture on your scrren with no source attached to the other picture. Could be cable or Sat or some other device, or TV PIP.
Mar 19, 2008 | Daewoo DTQ-19P2FC 19" TV
Screen split with black bar through center, top of picture shows in bottom
It sounds as you desribe, the vertical output IC and or the b+ feed capacitor off the Hi voltage transformer feeding the vert. IC its required voltage. Not a really hard job to replace, but not for a handi person to do. This should be left to the professional, as there are no user serviceable parts inside this set and with the HI voltage and the safety issues its best to call somesone to assist you with this repair. Good Luck
Jun 14, 2006 | Sanyo DS31520 31" TV
Tv screen
Did the set get dropped?? If it did the picture tube shadow mask inside the tube is bent and there is no cure for that. If not then the degussing curcuit could be at fault. try unplugging the set overnight and plug back in in the morning. did it help at all or a little, if it did but not all the way back to normal do that unplugging like three nohjts . If that dosent cure the problem then you have a bad degussing curcuit and on this set a cold solder connection On the thermistor for the degussing coil is A very very popular repair. Good luck
Apr 25, 2006 | Daewoo DTQ-27S3FC 27" TV
Televison & Video Logo
109 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
