Question about Garden
When cutting a log, the saw revs up, stays revved up and won't return an idol.
  • 2,760 Answers
Throttle sticking ?? ck it visually with engine off , sawdust gets in and gums up the works ,also some models require a return spring look for that as well
Posted on May 21, 2015
2 Suggested Answers
MNfisherman
  • 11896 Answers
SOURCE: Husqvarna 385
Sounds like dirty carberator or carb needs adjustment. How is the spark plug?
Posted on Jun 22, 2009
What are the air and gas settings for a poulan micro XXV chain saw
adjust the L screw in fully till right in,then out 1.5 turns,same with H screw.Then start saw,adjust L screw in or out slowly till you get max revs.You may need to lower idle via idle screw if revs too high.When screw cant acheive better revs,reset idle.Then,rev saw to max revs,adjusting H screw to get max revs,then when max revs acheived,turn screw anti clockwise 1/4 turn out.That gives it enough petrol to cool the tip of the plug
Aug 12, 2014 | Garden
1998 Nissan 200sx won't rev past 4000 RPM in neutral. What's the cause?
STOP doing that, forget about it, your going to blow your engine !
Mar 06, 2013 | 1998 Nissan 200SX
Car start but in like second it cut off
Just started the car and it cut straight out. It revved up like a normal start but instead of revs dropping to normal it cut out. I decided to try and drive it anyway to top up with petrol as light was on (But not near empty) and when I came to a stop it cut out. On starting it up this time the car revved up to the redline by itself and I had to quickly remove the key. It did this 3 more times then on the fourth start it decided to stay on but rev itself and kept reving between 1 and 2000 revs as seen in the video here I just took: YouTube - Alfa 156 constant reving
When I turn the car off it doesn't just cut out as usual either...now it sort of takes an extra few seconds as seen in this second video I just took: YouTube - Delay in turning off (The key is turned at 7 seconds)
I know the is a hole in my exhaust somewhere because there is alot of hot air coming from the drivers door area and its been like this for a few months now but surely a hole in an exhaust can't cause all this. Any ideas?
Oct 20, 2012 | 1989 Ford Tempo
I have a citroen xsara 1.4 revving to high in idol mode how do i adjust revs
AT IDLE, IT SHOULD ONLY BE APPROX 650 TO 750 RPMS. I WOULD HAVE IT SCANNED WITH A GOOD SCAN TOOL, NOT ONE OF THOSE CHEAP ONES, USUALLY AUTOZONE OR ADVANCE WILL SCAN YOURS FOR NO CHARGE, BUT IT VERY WELL SOUNDS LIKE IT MAY BE THE IDLE AIR CONTROL VALVE, AS THATS ONE OF THEIR SYMTOMS THAT HAPPENS WHEN THEY GO BAD, ALSO COULD BE A MASS AIR SENSOR, BUT A GOOD SCAN TOOL, SHOULD SHOW WHAT THE PROBLEM REALLY IS.....
Jul 01, 2012 | Citroen Xsara Cars & Trucks
Hello, i have a stihl ts400 and i just rebuilt the topend(crank,piston,cyl,all bearings and seals.Fires up easy, idles fine,revs fine, but when you hold the throttle down it doesent want to hit rev limiter...
There is not an actual rev limiter. The top end is controlled by the carb. You actually want it to sound a bit rich at full throttle so that it has enough fuel when cutting under a load. What causes me some alarm is the revving up part. If it revs too fast that is a lean condition and can quickly ruin the piston and cylinder much like running straight gas. A torn intake boot can cause this. The high speed spec for the TS400 is 9,600 rpm + OR - 500 RPM. Your saw may not have a needle to adjust the high side as some have only the low speed adjuster. Also when you disassemble and clean the carb always use a new kit with the gaskets and diaphragm. Any Stihl dealer can furnish the kits and they aren't terribly expensive. Often between $10-20.
Jun 26, 2012 | Saws
My 2003 montey hits the rev limite at 4000
if you are revving the engine in park or neutral it will hit the rev limiter as this is designed into the computer so the engine won`t get damaged due to over revving.
Apr 01, 2011 | Chevrolet Monte Carlo Cars & Trucks
Husqvarna 385
Jun 22, 2009 | Husqvarna Chain Saw 20" Bar
Fiat Strada
Bad transmission.
Jun 19, 2008 | 2006 Fiat Strada
Garden Logo
89 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
