Question about John Deere Garden
What is the gap on the spark plugs of a 3010 john deere tractor with eltronic ignation
    Sergeant:
  • 462 Answers
.030 i believe
Posted on Apr 23, 2015
Spark plug gap on 8hp
20 thou or .51mm
Specifications - John Deere
manuals.deere.com/cceomview/OMGX21222_J2/Output/OMGX21222_J212.html
  1. Cached
  2. Similar
Model Series 121602, Intek. Horsepower 5 kW ... Spark Plug John Deere M78543, Champion RC12YC. Spark Plug Gap 0.51 mm (0.02 in.) ... JS63 and JS63C. John deer model 63 Google Search
Oct 10, 2016 | Garden
John deere tractor has no spark eng is fb460. i put a new spark plug and a new coil still no spark
Make sure you set the gap properly on the coil should be a filler gauge 10. Make sure the flywheel is clean at the firing point. And make sure there are no safety switches that have gone bad. Safety switch that go bad will cause a break in the circuit and will prevent the coil from allowing spark.
Aug 04, 2016 | John Deere Garden
What is the point gap on a 3010 john deere gas engine
most gas engine point gap is around .20 thousands .
Oct 04, 2015 | John Deere Garden
Have john deere l130 that doesn't have spark
Sounds like the plug boot may not be on all the way. You may also have to check the spark plug gap.
May 04, 2014 | John Deere L100 Series
STARTED AND RAN ROUGH AND WONT START AGAIN... NO SPARK
Drain gas completely from tank to ensure no water is in the tank, check for spark with spark tester, if no spark shows with spark tester, re check gap on coil, if points & condenser are present, sand down the gap between the points to ensure a proper connection. Make sure to change fuel filter with a high quality John Deere fuel filter and use fresh fuel... Fuel can "go bad" after 1-3 months, if the tractor is/ left outside chances are there is water in the tank.
Nov 18, 2013 | John Deere Garden
No spark to spark plugs on john deere 2510
do you have a bad wire or a bad wire going from the points to the coil
Jul 28, 2012 | John Deere Step 2510 2520 3010 3020 4000...
John Deere 445 Garden Tractor, starts immediately,
could be bad gas, but it sounds like a choke problem. did it sit over the winter with less than a half tank of gas in it. try putting some rubbing alcohol in the fuel or draining the tank and disconnecting the gas line so you can drain the gas out of the carb. also check the gap of the spark plug and make sure that is correct. when was the last time there was fresh oil put in. also check the air filter, it could be full of dirt.
Apr 18, 2010 | John Deere 420,1020,2010,2020,2510,2520...
I have a lx 255 john deere wont start
You have a defective ignation coil. When the engine gets hot, the winding in the coil opens and the engine stops. After it cools down, it will again make contact and start again. If you don't know where the coil is, follow the wire from the spark plug. The spark plug wire is attached to the coil from the factory. It's easy to replace with a 1/4 inch socket set. Set the magnet to coil gap with a standard business card.
Jul 10, 2009 | Garden
Garden Logo
62 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
