New WIFi house hub. Automatic WiFi connection process has not worked despite a good WiFi signal.Why ?
In connecting to the new hub can I use a new password. A password is requested & I cannot remember the original .
  • 352 Answers
You should be able to do a factory reset. This will restore the default password, and the default permissions. Your manual or the online manual will tell you how to do a factory reset and the default password.
Posted on Apr 05, 2015
Weak wifi signal?
you have 2 possible solutions:
the easiest (but suboptimal) is to put buy a wireless repeater and install it half way between your access point and the point where you experience low coverage.
Amazon com NETGEAR N300 Wi Fi Range Extender Essentials Edition EX2700...
the best solutions is to buy a power line kit like this:
Amazon com NETGEAR PowerLINE 1000 Mbps WiFi 802 11ac 1 Gigabit Port...
you can plug the one without the wifi to a power outlet near your wireless router, and connect the two devices by a network cable. then you can plug the second powerline (the one with the antennas) in a power outlet near the place where you need wifi signal. the second device needs a little configuration (just put same network name and password of your old access point).
this way you will have your a new wifi access point, that will connect to your internet connection by power wires in your house.
Aug 01, 2017 | Advance Computers & Internet
How can I get the tablet fix because it cannot connect to WiFi , Facebook , google, and accounts
FIRST OF ALL TRY CONNECTING TO A PUBLIC WIFI LIKE A LOCAL LIBRARY. IF IT WORKS THEN CALL YOUR LOCAL INTERNET PROVIDER AND HAVE THEN WALK YOU THRU CONNECTING IT. IT IS A FREE TO DO SO. BUT ALWAYS ASK. GOOD LUCK.
Oct 25, 2014 | Tablets & eReaders
My iphone 4s will connect to my wifi but cant download anything new - yet works fine on 3G
check the settings of the wifi ( make sure thats DHCP) in the wifi menu
good luck
Feb 13, 2013 | Apple iPhone 3G
Toshiba thrive wifi connectivity
u search wifi networks ,,should have in the menu wifi connections or add a new network,,do a search for wifi,,a wifi scan,,when new netwrks or signal s appear on there,,,if it says open u can go online,,if passwrd enabled or wep or psk or whatever u cant ,,has to be a open signal,,like mcdonalds,,hotels,,,stuff like that,,drive an d search,,
Dec 23, 2011 | Toshiba Thrive Android Tablet
Im trying to connect my wii to the internet at my new house and it won't it keeps saying unable to find access point. please confirm the ssid and try again?
I'll advise briefly, but suggest you find the router page address (something like 198.168.2.1). You can find this by looking in the manual for the router. You can also double click to open the router and then "open device webpage"
This will allow you to access the router settings and configure the wireless protocols and passwords / security. Without knowing which router you are using, I cannot give specific help.
You need to ensure that the wireless password that you set in the router is typed EXACTLY into the network connection on your PC / laptop
Jun 13, 2011 | Nintendo Wii Console
Does not connect to to wifi connection when wep
My neo v kept losing the WiFi connection after a while, only connecting when I turned off and on the router despite always seeing a high signal.
I changed the router from wep to wpa2, same issue. Then I changed the DNS server in the router from the telefonica default to Google's own, I.e. 8.8.8.8 and 8.8.4.4. Now my phone's WiFi connection is rock solid.
Dec 29, 2009 | Sony Ericsson Satio Cell Phone
I have a toshiba x300, it always connect to other wifi connection? how can I block the other wifi signal? I already uncheck the automatic settings of the other network and delete it from my preferred...
REinstall wi-fi adaptor in device manager
Just go to device manager and expand network adaptors.
Right click on wireless adaptor and select UNINSTALL option
REstart laptop and connect to your network
Thanx
Sep 14, 2009 | Computers & Internet
Wifi connection to BT Home Hub problems
Make sure you do not have any third party software running in your taskbar that deals with wifi connection if your trying to use the windows connection. this is what i do. its better, and more simple. Home Hub does not work well with non BT software. If your not sure, turn any wifi connection software off. i.e if any came with your wifi device. and then click on the start button. and click connect to on the right lower side of the start menu. You can use almost any wifi device with these devices. your best bet would be to let windows try to connect to your home hub. Also are you typing in your WEP key. correctly. How far away from the hub is the wifi device. Is windows wireless zero configuration off in system services. unliekly. but worth a look. I have had a home hub for three years and i have to admit they are a nuisence. The BT Voyager wifi works ver well. just in case there is some kind of incompatibility with your device, i highly doubt it though. Good Luck.
Apr 27, 2009 | Archos 705 WiFi Digital Media Player
WIFI Connection Problem - connects only to EDGE
If you want to use wifi only when your at home you can go in and manually disable the cellular data so the internet will only be wifi based. Probably saving you MB's and data cost.
Go to Settings, General, Network, then simply turn off the Cellular Data. Then it won't connect anymore to the cell data and rely only on wifi when your connected to it.
And simple follow the same steps and revers the process when your out on the go.
Thanks
Oct 15, 2007 | Apple iPhone Smartphone
74 people viewed this question
jasbo
jasbo
