Question about Garden
How do I adjust the height - Garden
  • 56 Answers
(if your wheels are bolted to the mower).....unbolt the wheel(s) from the mower and there you will see a series of holes, each hole is a half inch apart. use these to adjust your cutting height. some mowers like the picture has other methods of adjustment. look at the wheels and you can see what is used. I recommend a 2" for the entire summer but some folks may say 2.5 ins instead. choose what is best for your area. hope this helps !
Posted on Apr 05, 2015
Where can we get details relating to electric height adjustable desk?
There are lots of sites on web that are providing data associated with electric height adjustable desk. These are specially made for all those people that are looking at affordable costs for quality electrical height-adjustable table. To find out more please visit this site:
FlexiSpot Height adjustable standing desk desktop workstation
Mar 06, 2017 | Electric Garden
How to level the mowing deck on 2002 John Deere (Scotts) 42 " mower. Mower deck drags on right side. Mower height adjuster doesnt work seems jammed.
Have a look underneath while someone operates the height adjustment. There's probably a link arm come off which does deck height. Go to google images for this machine, type height adjustment and look at the pictures if you don't have a handbook. Google JD handbooks and see if you can find a free download.
Aug 13, 2016 | John Deere Garden
Height adjustment does not work
Hello! The vacuum does not move up and down when you change the height setting. When the handle is reclined is when the height of the nozzle will adjust. Hope this was helpful!
Jun 26, 2014 | Hoover Tempo Widepath Upright Vacuum -...
I need to adjust my scag mower deck
The mower deck can be adjusted from a height of 1.0 inch to 6.0 inches at 1/4-inch intervals. To adjust the cutting height:
1. Disengage the power to the cutter blades.
2. Push the cutting height adjustment foot pedal all the way forward using your right foot until it locks in place
3. Insert the lanyard pin into the cutting height index at the desired cutting height. Push forward on the deck lift foot lever, hold in place and pull back on the deck release lever. Slowly release the foot pedal. A deck height decal is located on the cutting height index as an aid in adjusting the deck to the desired height.
Aug 18, 2013 | Scag STT61V-27CH Hydrostatic, Gas Turf...
How to adjust water flow coming out of bubbler
Check stream height from bubbler. Stream height is factory set at 35 PSI . If supply pressure varies greatly from this, remove the (bottom cover plate) and adjust the screw on the regulator Clockwise adjustment will raise stream height and counter-clockwise will lower stream height. For best adjustment stream height should hit basin approximately 6-1/2" (165mm) from the bubbler.
Mar 02, 2011 | Elkay Water Cooler ADA Wall Hung 8 Gallons...
Lower for height adjustment?
There isn't necessarily an adjustment on all bikes. You can drop the ride height by adjusting the tension on the spring on the rear shock and lower the front end by moving the forks up in the clamps on most makes and models.
Mar 07, 2010 | 2003 Suzuki DR-Z 125 L
Need to adjust height of handlebar on a jeep sahara bicycle
Most bikes use an allen key to adjust the height of the handle bars. Typically 6mm. But be careful most bikes do not have much adjustment that can be done to the height of the handle bars. The handle bar stem will have a line on it of the "minimum insertion". That line must be below the top of the head set nut for safety reasons. Look for the line as you adjust the height.
Oct 03, 2009 | Jeep Cycling
Height adjustment won't work on Hoover windtunnel
In my experience, Hoover height adjustment are "stops" rather than being attached to an axel. Look for something that rould resemble a set of circular steps somewhere in the path the axel would take as it goes up and down. It is usually on the underside from the knob that sets the height. Each 'step' represents a height with the shortest step being the lowest setting from a certain perspective.
On some Hoovers, therte is a ratchet petal on the right side. The ones I have seen are similar in operation to the above.
Let me know if this helps you.
A
Sep 21, 2009 | Vacuums
Height adjust for Dell UltraSharp 1907FP 19" LCD Monitor
Is it stuck, or just not adjustable? Try setting it on a phonebook. I'm kidding. If it is an adjustable base, sometimes they need a little downward pressure before the button will depress and allow it to move upward.
Thanks,
Chris
http://BoiseLCD.webs.com
Jan 03, 2009 | Dell UltraSharp 1907FP 19" LCD Monitor
Garden Logo
56 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
