I keep getting error code "LF" , it only makes it through prewash.....please help
  • 352 Answers
You have to tell us make and model to get precise help.
This is a guess: On some machines LF means Long Fill. In other works it is taking too long to get water into the machine for some reason and the machine just stops.
Try the following:
  • Water supply vales are not fully open. Open the valves.
  • Water supply pressure is too low. This may require a plumber to find and fix.
  • Inlet screen at either the inlet water valve or at the end of the hose at the washing machine is plugged. Clean the screens.
Good luck.
Posted on Apr 05, 2015
  • Washing Mach... Master
  • 2,963 Answers
Owner's manual, troubleshooting. no manual, try manualslib.com
or one of the many online appliance parts sites may help diagnose based on make model possibly year and or serial.
SOURCE: LF error code
I had a similar problem with an LF code. I had installed "no burst" hoses which have a smaller inside diameter then regular hoses. I switched back to regular hoses and the problem seems to have been eliminated.
Posted on Mar 24, 2007
IFIXALL
  • 868 Answers
SOURCE: Kenmore Oasis HE 2708..LF error code
Replace the water valve
Posted on May 26, 2008
  • 5 Answers
SOURCE: Kenmore Oasis has LF code on and won't reset
The LF code indicates "Long Fill" which means it is taking too long for the water to fill the washer (times out). From the owner's manual:
"LF" (Washer is taking too long to fill)
Check the following:
Are the water inlet hoses kinked or clogged?
Are the water inlet valve screens clear?
Press STOP to clear display.
Here's a suggestion I found that worked for me:
Check your drain hose to see it it's stuffed too far down the standpipe. Another poster had this problem and it gave her LF errors. If the drain hose hangs down too far it can siphon water out of the washer, and then the washer thinks it's taking too long too fill. There's supposed to be a U-shaped plastic bracket that sets the length of the drain hose where it goes into the standpipe. Your installer may have tossed it.
Posted on May 30, 2009
localwonder
  • 6784 Answers
SOURCE: errror code LF
If the water fill time exceeds ten minutes, the water valves are turned off and "LF" is flashed. This will be an issue that concerns the pressure switch. Follow the procedure below to address this issue further.
The water level switch(aka pressure switch), is responsible for regulating the water fill level in this situation. It does this through a plastic tube which runs from the switch in the control console down to the side of the outer tub, near the bottom . The tube is filled with air. As water enters the tub it also enters the tube. As water climbs inside the tube, it pushes on the air trapped inside and increases the air pressure. When the air pressure reaches a certain level, it triggers the switch.
I would advise to Inspect the air tube for kinks, breaks or damage. The tube should also be free of water. The tubing should be securely connected to the bottom of the outer tub and to the bottom of the water level switch. If there is water present, the switch must be replaced.
The water level switch has three connectors. Label and disconnect the wires from the switch. Test the switch for continuity using a multimeter. Set the multimeter to the ohms setting X1. It will be necessary to test each of the three possible pairs. replace the switch if it fails the continuity test.
Posted on Nov 11, 2009
mc1bean
  • 3053 Answers
SOURCE: whirlpool cabrio error codes
Hello, stefanie
I am trying to help you out here. Maybe this will help some? I am know on Fixya as the cleanup expert pro. Which means I spend my own personal time to seek out customers that maybe have not had there problem yet solved by the other fantastic great experts. I do this on my own for free. Think of me as a Specialized Trouble Shooter.
I have found out that it appears that lots of customers appreciate my efforts and help. So, I thought I would take some of my own personal time
to see if I can help you. Even though this Informational site may not have your exact model or brand, But this site will help you a lot. Here is the site link about everything you want to know about washing machines and possibly yours, from repair to trouble shooting it.
http://home.howstuffworks.com/how-to-repair-a-washing-machine.htm
Please if this helped you at all, if you can find the time and in your heart to rate my help and some kind words written would be appreciated for my free help, I would appreciate it. Like I said I just try to help, If anything this is good information for future problems. If you felt that my free help was a waist of time for you, I'm sorry. I do not get paid to help people on the site, I do it cause I like to help and maybe make a smile on someones face.
Here is also my direct link to my own pages of other areas of my expertise for other problems you might have in Automotive, Appliance, and Electronics. Drop In anytime for my help.
http://beta.fixya.com/users/mc1bean
Thanks Mike
Posted on Nov 01, 2011
F error code "kenmore top load" washer oasis he3
Hi
LF means Long Fill, this error flashes when the water level does not change for a period of time after the valves are turned on OR water has disengaged the basket but control does not detect a water level change. Check whether water supply is connected and turned on. Make sure the hose is not blocked and hose screen is clear. If so make sure pressure hose connection to machine/motor control is fine. Also check the continuity of water inlet valve, use a multimeter to check the continuity. Hope this helps... Please post back if you need more information.
Daniel
Feb 16, 2011 | Kenmore Washing Machines
I have a kenmore elite and I keep getting the error LF? What can i do?
LF means long fill clean your screens in your water inlet hoses also make sure the hoses are not kinked and that both hot and cold are turned on ...Good luck and if I helped you please vote...
Feb 02, 2011 | Kenmore Washing Machines
What does LF mean - my kemore washer quit working
hello
mean while LF error code indicates that the water temperature sensor reading is out of range (below 23 degrees F or above 217 degrees F).
The LF error code is an indication of a water temperature sensor error. There is a chance that there is a loose wire connection on the water temperature
however,what you need to do tp fix up the problem is to unscrew the washer then clean up all forms of dry and water you can seen in it with this the problem of the LF error code is solve .
please make sure that all form of power supply is put OFF before you can do this
thank you and thanks for using fixya.
Jun 03, 2010 | Kenmore 24032\24036 Top Load Washer
Error 600 canon mx320
Error code [6000] or light blinking 3 times.
1. Smearing or scratches on the LF encoder. Please clean the LF encoder.
2. Foreign material or paper debris in the LF drive. Please remove any foreign materials if encounter.
3. Check cable connection.
4. Replace LF encoder or Logic Board
May 27, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Solucion para error 6000
May 27, 2010 | Canon Office Equipment & Supplies
Getting code 6000
4. Replace LF encoder or Logic Board or Paper Feed Motor or Paper Feed Roller Unit
May 27, 2010 | Canon PIXMA MP620 All-In-One InkJet...
What does LF mean on the rinse cycle?
"LF" is a Long Fill error. If the fill time exceeds roughly 10 minutes, the fill valves are shut down and the error code is generated. If the error does not clear, or keeps reoccurring, it is recommended that you doublecheck to make sure your water taps are on all the way and check the hoses for kinks or clogs. If everything checks okay, check the screens on the fill valve for sediment build up. You may need to replace the valve. I hope this helps you.
Oct 23, 2009 | Kenmore Washing Machines
Washer has LF error?
Lf means Long Fill This error code is displayed if the control failed to save cycle information during a power failure. This does not generate an error code beep.
Press STOP/CANCEL to clear the display. Good luck
Oct 06, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
LF Error
Sep 22, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Apr 07, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
