My tv screen flutter and is very dark - Televison & Video
    Top Expert:
  • Televison & ... Master
  • 75,289 Answers
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
In some models of LCD TVS; the backlight inverter and its T'Con board will be a part of the panel itself, and will be a built-in type inside the LCD panel. If so, they can't be replaced. In this case; a panel replacement is the only repair. For some other models, the backlight inverter section circuit will be a part of the main power supply regulator [SMPS]. To such sets, the power supply section circuit too should troubles shoot. Contact any service technician. The circuit will differ with models and versions.
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Posted on Apr 05, 2015
  • 2,992 Answers
Check power supply connections and antenna or cable connections.
Testimonial: "Sorry to say but already did this. TV was working for a while before this happend"
My tv screen is to dark how do I lighten the picture
If your TV has already fully adjusted in brightness set up?, and there will be no good picture results?...try to adjust the "SCREEN-Screw" at the flyback slowly. If the picture still dark'?. the picture tube has need to rejuvenate.
Oct 24, 2014 | JVC Televison & Video
Picture flutters
If this is a projection TV and it shrinks and expands its a common issue with certain Philips TV sets. Sites like www.TvRepairKits.com have the kits to fix this.
Mar 30, 2012 | Televison & Video
Flutterin sound in tv
try turning the bass down and see if this helps the fluttering. If it does help a little most likely it is a blown speaker. Can replace at radioshack for under 20 dollars. It is hard for me to tell since i am not there to diagnose but also can you do a balace to go completely to the right with bass up and see how it sounds. now with bass up turn the balance to go to left speakers. if you hear fluttering from one side that means a speaker or speakers from the side that is fluttering need to be replaced. i hope this helps and good luck fixing this.
Feb 21, 2009 | RCA Televison & Video
Staandard 20
the plyback of your tv had a problem, there's a leak that's why you heared a sound.
Oct 01, 2008 | Emerson EWF2004 20" TV
Fluttering glitchy screen
if your laptop supports dual monitors then it's a pretty easy fix. Plug in an external monitor and secure the screws. reboot your system and it will recognize the external monitor and set it up as your main monitor. you now have access to all your files w/o the cost of replacing your laptop screen (which would cost about as much as a new one). ^_^
Aug 01, 2008 | Toshiba Satellite A55-S1063 Notebook
Screen slowly turns blue...
I had blue lines showing up on my screen, then the other night my screen started to flutter the blue, bright to dim and back. So I followed this link to resolve the blue lines and the blue flutter was resolved as well. Hope this helps.
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Jul 26, 2008 | Sony KP-51WS500 51" Rear Projection...
Continuous rolling screen.
check out ctechnicians.com and find the error code
Dec 24, 2007 | Mitsubishi VS-60607 TV
Compaq Armada 110 - No screen image
WELL I WOULD LIK TO SUGGEST U TO PLEASE RE-INSTALL YOUR GRAPHIC CARD'S DRIVER AND HAVE A LOOK.
Nov 05, 2007 | Compaq Armada 100S Notebook
Fluttering and picture discoloration
model # VS-60607 Mfg Yr February 2000 Big Screen TV:
1.  tearing/fluttering/ripping across entire screen caused by damages associated with diode 522, and;
2.  the problem is really an OEM Mitsubishi causation as the
leads of said diode get too hot <too much current flowing through
it> and this component lifts itself off of the main circuit board, &;
3.  supplemental hidden damages arise from this, and;
4.  you should not attempt to fix this set but rather contact the
national & state Consumer Protection staff & file a complaint, &;
5.  pleadings should say:
    a.  this set almost burned down our/my home & us to death;
    b.  we paid too much money for this to happen, and;
    c.  we demand full replacement of the set & money for our
         inconvenience for all of the above, and;
    d.  said replacement need not be a Mitsubishi but like unit;
6.  check with Martindale-Hubble to find a good law firm/lawyer.
7.  have fun, eh!
Oct 07, 2007 | Mitsubishi VS-60607 TV
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
