Question about Kenmore Dishwashers
Hi a service tech said I needed a new control board. I went ahead and replaced it and immediattl the locked button went on I reset that buy the delay light keeps going on
And no other lights will stay on and washer will not work can u help Andy
  • Kenmore Master
  • 2,992 Answers
Who did you get the control board from? I'd ask them for help.
Posted on Apr 05, 2015
Why won't my system go to service mode
If youre out at the equipment controller and push the button to switch from auto to service and it doesnt work, it usually means you need a new board. Theres a reset button on the outdoor controller, look to make sure it wasnt pressed and got stuck. If that looks ok, then the board should be replaced, buy an iaqualink instead of your replacement board, it is backwards compatible, meaning all of your existing controllers will still work, but it gives you internet/iphone/android control capability as well.
Jul 24, 2014 | Zodiac Jandy AquaLink RS All Button Wired...
Kitchenaid superba failure codes e1,f2, and door is locked
Hi Bill:
The E1F2 error code indicates replacing the board. It is in the realm of possibilities that your new board is defective. If I were certain the board was good I would focus my efforts on tracking down an electrical fault.
The likely failure is the control panel; however it could be the control board.
Since you did replace the control board already, the problem is most likley a key pad that is sticking.
I added a portion of the technical data sheet in the image below. You will need an ohm meter to be able to check the key pad operation. I added the information needed in the image below. If the control panel tests OK, replace the control board, if it fails, replace the control panel.You may need a hands on tech to run these tests and diagnose and repair your oven. Or just buy the key pad controls. Check THIS LINK.
Here are the parts
Replacement parts for WHIRLPOOL KEBS208DSS8 ' AppliancePartsPros.com
Here is a manual and a tech sheet
https://secured.whirlpool.com/Servic...all%20Oven.pdf
http://www.servicematters.com/docs/w...%204451879.pdf
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Dec 20, 2011 | KitchenAid KEBC208 Electric Double Oven
Can't get the lock on button to go off by pushing
Hi
First make sure that nothing is blocking the drain pump assembly located inside the lower front panel of the dishwasher. If the issue returns after its cleaned then try to reset the dishwasher control by pressing the NO HEAT DRY button and hold it for 35 seconds, if its still not resolved then it means that the control board has gone bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 31, 2011 | Kenmore 16762 Dishwasher
The only button on the panel that will light up is the 4 hr delay nothing else happens
This type of diagnosis will require taking voltage readings at the control board with a meter to find the root cause of the failure. Please see the rest of the information provided & the images below for the accessing, testing & replacement instructions.
1). Put the washer into the Diagnostic Test Mode per the Tech Sheet. 2). Did the Right Hand Interface light up? 3). IF the Right Hand Interface did not light up in Step 2 check for 5 VDC on the UIP3 wire connector coming off of the control board to the Right Hand Interface from (Pin 1 to Pin 2) and from (Pin 1 to Pin 3). 4). IF you do not have the 5 VDC then remove the MI3 connector from the Machine Control board. IF the display lights; replace the Motor Control board. IF the display does not light; replace the Machine Control Board. 5). IF you do have the 5 VDC then replace the Right Hand User Interface. 6). IF the Right Hand Interface does light up. Lock the controls by pressing the control lock button for 3 seconds. 7). Once the control has been locked press the power pad. IF the control lock light blinks when the power button is pressed it tells us the power button is sending the output from being pressed to the right hand interface but the right hand interface is not responding and will need to be replaced. 8). IF the control lock light does not blink when the power button is pressed replace the center user interface.
Jan 09, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Power will not go on, door locked.
Unplug the washer from the wall for 5 minutes and see if it resets, the problem is the washers computer controlled timer board. If it doesn't reset you will need to call service for repair.
Dec 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Remote Control button frozen - unable to select any number
Hi, the best way is to clean the green circuit board inside your remote control by Brennspiritus (pure Alcohol) (or eraser) and same to the buttons from inside too.
then wait until to be dry ( 2 min ), then it have to work.
if didnt , that mean there is a problem in the green circuit board amd its better to buy a new remote control.
Good Luck How To Repair Remote Control Buttons That Don Work
Jan 14, 2018 | Vizio L32 32 in. LCD HDTV
Electric went out to the house, it came back on, and the microwave inside light works, the display panel reads just a " : ", and none of the buttons work. I have tried resetting the breaker with same
Hi cschnur,
     It seems that you might need to replace circuit board.
All the above mentioned conditions refers to a faulty circuit board. You might have blown few Ic's.
Take a voltmeter, check the continuity. If you are aware of the Ic's, replace them.
Unless, look for a tech, a used board ( On http;//www.ebay.com ) or purchase a new one.
Thanks for using Fixya.
Do rate the solution as "Fixya" if 100% satisfied.
Apr 17, 2009 | Kenmore 63682 / 63684 / 63689 Microwave...
Maytag MBDTT70AWW Dishwasher will not start
Had same problem. Repair tech said controller board needs replacement. Cost $300. His suggestion was buy a new dishwasher.
I did
Mar 11, 2009 | Dishwashers
I am gettting a message on my dishwasher that says 1h
I think that the delayed use is engaged.  Wait an hour, and it will probably start up on its own.
Jan 10, 2009 | GE 24 in. Profile PDW7800 Built-in...
Prolonged washer cycle time
Hi! I'm not familiar with this model, but it sounds to me like there is not a problem! If you set the delay time to 0H, switch off the unit at the main switch, then switch back on. If there is still a 2H displayed, it means that the PROGRAM that you have selected will take 2hours! This is fairly common for the Bosch units on the 50 - 65degC cycles...some models have a "reduced washing time" button - it looks similar to the "delay" symbol, but once pressed, it reduces the washing time by almost half (cuts on rinse cycles) If your model does not have a reduced time button, select a shorter cycle (35/40/50eco), and see if the time is less. Remember that the latest dishwashers are engineered to be more energy efficient and water wise, so they had to lengthen the wash cycles in order to get good wash results! Hope this helps! C.
Jun 24, 2007 | Bosch SHU5307UC Built-in Dishwasher
Dishwashers Logo
67 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
