Question about Vacuums
How do I remove the old one and replace with new filter?
  • 2,963 Answers
Owner's manual no manual, try manualslib.com or even the new filter package might help.
Posted on Apr 05, 2015
Kenmore 23155301c replacement filter
Take the new one out of the package without destroying the package and put the old one up against it and see if it will fit. If you take it home see if the new one will fit. The new one may not look exactly like the old one but if it fits it should work. If it does not fit put it back in it's new package and take it back to the store. I have done this and had no problems.
Nov 08, 2014 | Vacuums
How to replace filter
Hello! Happy to help with that. To replace the filter simply twist the dirt cup lid off of the dirt cup. Remove the old filter and replace with the new one. Twist and lock the dirt cup lid back on. This vacuum takes a Dirt Devil F1 filter. Follow the link below to purchase the filter directly from dirtdevil.com. Thanks!
F1 HEPA Filter
Aug 11, 2014 | Dirt Devil Featherlite Bagless Vacuum...
How do I remove old Brush roller part from Shark Navigator NV22L
Hi, it's Ambrai from Crucial Vacuum.
Your Shark NV22 has small wheels underneath the head of the vacuum that need to be popped out. The wheels hide screws that need to be taken out along with the three other visible screws. Using a flat and sturdy object, pry out the wheels. After unscrewing all of the screws, you will be able remove the cover and access your brush roller.
While you're repairing your Shark NV22, why not replace your hose and/or filters? For optimal performance, it is recommended that you change your filter every three to six months.
You can purchase direct your replacement parts from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/catalogsearch/result/?q=nv22&order=relevance&dir=desc
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Ambrai Brown
Crucial Vacuum Customer Care
May 04, 2014 | Shark Vacuums
I just purchased a tune up kit for my filter queen, how do I replace the dome cap pad? I can see it but I dont know how to get to it.
I was trying to replace the silencer filter, we had to take the dome cap off and remove the screws by the sn plate then lift the top off. It looks like the motor has been replaced at some point (I purchased this one used) so the wires had wire nuts holding them together. We had to separate the wires for the light so we could remove the old filter and install the new one.
Feb 06, 2010 | Filter Queen Majestic Canister Vacuum
Replacing the hepa filter
The cover for the HEPA filter is located immediately beneath the clear bin, and is exposed when you remove the bin. Removing the filter cover without breaking something can be a bit of a challenge, but if you look carefully you will see how it fits on, and then, with care, you can lever it off. Then the filter just lifts out. Don't worry if you do break the cover - the cost of a new one is nothing compared with the filter itself. You will need to buy a new adhesive seal too, as the old one will be stuck to the old filter.
Dec 31, 2009 | Dyson DC07i Bagless Upright Vacuum
Our dyson upright doesn't seem to **** up an particles anymore (still picks up some dust) about 9 years old.
Hi there SmartAlec from NelsonVacuums.com.au here. There are a couple of likely causes first check your washable filter once you remove the inner foam part and hold the white (well it would have been originally) part to the light you should be able to see light through the filter. If not you will need to get a new filter - Buy Here.
If your filter is okay check to see if your brushes are spinning. The brush roller bearings may have siezed making the brush essentially useless. Easy to replace just contact me with your model and I can help you get a new one! Happy Vacuuming
Aug 19, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
I got a new filter for my Beam central vacuum. How do I replace it? Do I take off the top lid of the canister?
You would not normally need to replace the filter unless it is damaged. Access is from inside the tank itself. Remove the bucket and locate the finger loop on the existing filter. Pull toward the inside of the bucket. Replace the filer by setting in it's track and snapping tight to the wall of the vac. Unless damaged you can save and clean the old filter for reuse.
Jun 10, 2009 | Beam Industries 2900 Serenity Plus Central...
Motor
Filter ?Queen Majestic Canister Vacuum – Motor
Motor?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
If your Filter Queen Motor is out or not working, the customer can replace the motor if they are mechanically minded and mark the wires as they remove the old motor with the new motor or you can have it serviced by your local vacuum dealer in your area, you can pickup the motor @ a local vacuum cleaner dealer in you area by checking the yellow pages or to contact the Filter Queen factory listed below. It requires a new motor and a new gasket; the biggest problem would be the wiring of the new motor. The factory information is listed below:
http://www.filterqueen.com Filter Queen Canisters Vacuums
Health-Mor World Headquarters
13325 Darice Parkway, Unit A
Strongsville, Ohio 44149
1-440-846-7800 or email @ custserv@filterqueen.com
Apr 18, 2008 | Filter Queen Majestic Canister Vacuum
Need help with my vacuum
You didn't state brand and model number. Some of these filters can be washed, make sure it is dry before putting it back on. If it is a year or more old, then replace it. Call around to your local repair shops to see they would have a replacement filter.
Mar 12, 2008 | Vacuums
Vacuums Logo
37 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
