Paper jam and no manual how do I open the printer
  • 2,992 Answers
Manual is probably in PDF on the software install CD. Or google make model troubleshooting paperjam.
Posted on Apr 05, 2015
Paper jam inside machine
You need to open your printer. Some printers even have back opening panel for fixing paper jams. Since you didn't say which printer are you referring to, try searching here for user manual and see if it will help: Download Free Manuals
Jan 03, 2016 | Office Equipment & Supplies
Paper jam
you need to remove the jammed paper, you may need to take the printer apart as much as possible to get it all out, the manual generally has instructions on clearing a jam do you have the manual do you need it?
Oct 20, 2008 | HP Photosmart 3310 Printer
Gympac 1600 manual
Device error An internal error occurred in the device. Press (Select) to resume the job. - Door open The printer door is open. The door must be closed before printing can continue. - Engine comm. error The device experienced an internal communication error. This is a warning message only. Job output might be affected. - Invalid driver You are using the incorrect printer driver. Reselect the printer driver appropriate for your device. - Invalid entry Invalid data or response. Correct the entry. - Jam in Cartridge area A paper jam has occurred in the print path. Open the door and clear the jam. Then press the (Select) button on the control panel - Jam in Output bin A paper jam has occurred in the output area. Clear the jam, and then press the (Select) button on the control panel. - Jam in print paper path. A paper jam has occurred in the print path. Open the door and clear the jam. Then press the (Select) button on the control panel. - Jam in tray 2 A paper jam has occurred in Tray 2. Clear the jam, and then press the (Select) button on the control panel. - Jam in tray 3 A paper jam has occurred in Tray 3. Clear the jam, and then press the (Select) button on the control panel - Load paper The HP Color LaserJet 1600 printer is out of paper. Please load specified paper type into the tray indicated. - Load Tray X [TYPE] [SIZE] The printer is processing job, but the tray indicated is empty. Please load specified paper type and size into the tray indicated. - Manual feed The printer is waiting for paper in the tray indicated Load the paper as indicated. - Memory is low The device memory has been almost completely filled. Allow the device to finish the job, or press (Select) to cancel the job. Break the job into smaller jobs that contain fewer pages. - Misprint The printed pages have been incorrectly placed on the paper. To continue, press the (Select) button on the control panel.
Dec 31, 2014 | Office Equipment & Supplies
Paper jammed open left cover
Hello, To solve this problem try follow this steps
1. Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred.
2. Turn off the printer.
3. Remove any paper trays, inspect them for wrinkled or damage paper.
4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
5. If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly
The goal is to keep the paper from tearing. If several pieces are jammed together,try pulling out the middle piece first to loosen the jam.
7. If the paper does tear, try rotating the roller gears manually to free the paper.
8. Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
Thanks
Jun 29, 2011 | Office Equipment & Supplies
Machine diplays "paper jammed" with no paper in
Hello
This the method to clear paper jam, follow these steps:-
Remove any paper trays. Inspect them for wrinkled or damaged paper.
Open any other doors that give access to the printer's paper path and to the ink cartridge. 5 If necessary, remove the ink cartridge. Place it in a bag or away from light to avoid damaging it.
If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though.
Replace the ink cartridge and paper trays, close any doors you opened and turn the printer back on.
Good Luck
Dec 18, 2010 | Sharp UX-B20 Plain Paper Inkjet Fax
Stylus CX9400 Photo Printer: paper jammed inside printer...
If paper is jammed, a Paper jam message will appear on the control panel display.
Follow these steps to clear the jam:
  1. Gently pull any jammed paper out of the output tray or sheet feeder.
  2. If the paper is stuck inside, turn off the Epson Stylus CX.
  3. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus CX back on.
    alert_note.gif Note: Be sure to check the far left of the carriage area when checking for jammed paper. Paper that is jammed there may be hidden from view.
If paper jams inside the Automatic Document Feeder, clear the jam as follows:
  1. Open the Automatic Document Feeder cover and remove any jammed paper.
  2. If necessary, lift the document cover and remove any paper that has jammed inside.
  3. Press OK to clear any messages on the display screen.
May 18, 2010 | Epson Stylus CX9400 Photo Printer
Paper jam
First I would request you to provide the name and the model of the printer which would helps us to provide you more specific troubleshooting steps for your type of printer. I am providing you some of the trouble shooting stpes which should be ideally done in cases like papaer jam:
* Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred.
* Turn off the printer.
* Remove any paper trays. Inspect them for wrinkled or damaged paper.
* Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
* If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
* If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly . The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
* If the paper does tear, try rotating the roller gears manually to free the paper (see B). Don't force anything, though.
* Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
* If the printer paper jam message still appears, then there is still some paper in the printer.
Hope this would resolve the issue.
Thank you for contacting Fixya.
Jul 10, 2009 | Office Equipment & Supplies
Unable to open to remove paper jam
Step1
Step
Step
Step
Step
5
Step
6
If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly (see A). The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
Step
7
Step
8
Step
9
Sep 23, 2008 | Canon PC1061 Copier
Paper Jam feeder
Step1
Step
Step
Step
Step
5
Step
6
Step
7
Step
8
Step
9
Aug 14, 2008 | Dell 3100cn Laser Printer
Epson Aculaser C900 - Paper Jam Notice, but no Jam?
Step1
Step
Step
Step
Step
5
Step
6
Step
7
Step
8
Step
9
Jan 14, 2008 | Epson AcuLaser C900 Printer
27 people viewed this question
k24674
jasbo
jasbo
