The red power light is blinking no picture What does that mean?
  • 848 Answers
SOURCE: red light blinking on power
this all problem may exist in your tv
1. High voltage problem/ deflection circuit problem.
2. Shorted picture tubes.
3. Problem in the vertical deflection circuit.
4. Problem in the audio ouput circuit.
5. Problem in the convergence circuit.
6. Problem in the power supply regulation.
7. Problem in the portect circuit.
8. The common high voltage arcing that Toshiba sets do at the picture tube.
so for getting pictures gently tap on the side of tv if it works then there may be some loose connection you can fix it by soldering
Posted on Jun 22, 2008
Slinteriors
  • 8617 Answers
SOURCE: Sony KDP-65S550 red light keeps blinking
How many times is the LED blinking in between pauses? that is possibly a error code if you can determine the number of blinks.
Posted on Jun 28, 2008
SOURCE: kdf-60xbr950 - red light blinks 3 times for a minute and tv turns off
same problem as others 3 blinking green lights then orangey colors then 3 red blinking lights afterwards shuts down fan runs for about 2 mins solution check your door cover for warpage or deformed just a bit under set screw there is a push in switch try and push it in with q tip while holding turn on tv if it works then that door is deformed and defective change it
thanks for solving my issue tv works again very helpfull thanks
Posted on Jan 07, 2009
welcomejee
  • 10594 Answers
SOURCE: TV powers off after 10 seconds of powering on....
Thats great, Please rate solution.
Posted on May 19, 2009
  • 1015 Answers
SOURCE: red power light continuously blinking. no picture no sound.
It could be the lamp went out and needs replacement. The Toshiba website states when this happens to unplug the televison for 10 minutes then plug back in. If that does not work then try another power outlet. If that does not work then call for service
Posted on Sep 12, 2009
LG air conditioner blinking red power light
This is not a split system a/c unit guys. Look at the picture. The blinking light means the air filter may need cleaning. Reset power to turn it off.
Jul 25, 2012 | LG 8000 BTU Air Conditioner w/Remote
Mitsubishi HC 5500. While playuing the picture disappears. No picture only sound, also status and power lights start blinking red and green
Red and Green bliking with no picture means a service problem. But you might try cleaning the filters first and being sure that nothing is blocking air flow through the projector. Red status solid means replace the lamp, but that doesn't seem to be the indication.
Feb 09, 2011 | Mitsubishi HC5500 LCD Projector
I have a 4 year old Sony KDF-E42A10 television - the power/standby light blinks red 5 times, pauses, blinks red 5 times again, etc. I have replaced the lamp previously when the light was blinking red 3...
5 blinks means there is a problem with the video board. It could be as simple as unplugging everything, includding power. Wait 3 minutes then plug power only back in. Or it may be a damaged component that requires replacing.
Hope this helps
TV_Doctors
Jan 05, 2011 | Sony Televison & Video
When charging battery green light flashes then red 3 times
KODAK Easyhare digital camera light status
1. Blinking green light(or blinking blue or white light in some models) - Means camera is performing a power up procedure. Note: Wait a few moments to see if the camera displays a solid green (or blue or white) light or a blinking red light.
2. Solid green light(or blinking blue or white light in some models) - Means Camera has sufficient power
3. Blinking red light - Means camera batteries are weak or need replacement; If battery are new and still red light camera needed to be repaired
For futher assistance contact Kodak support line 1 800 235 6325 (23KODAK)
Nov 21, 2009 | Kodak EasyShare M863 Digital Camera
No picture and the power light blinks
A red blinking light could mean that the lamp timer is at it's limit and it is time to change the lamp. You will also have to reset the lamp timer by pushing and holding down 2-3 buttons on the tv or remote. Refer to your user guide for the proper way to reset and or change your lamp.
Oct 04, 2009 | Toshiba 50H81 50" Rear Projection...
Sony triniton,no sound or picture,flashing red light blinking!
the main problem of your tv set is the main power or what u call the regulator.the red light blinking it means your tv set is on standby mode.
Feb 19, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Tv turns on but no picture just a red blinking light stays on
Red light blinking means there's a problem in the TV....
What kind of tv is it?
Feb 10, 2009 | Televison & Video
Blinking red light
I DO HAVE THE SAME PROBLEM , ONLY THE RED LIGHT BLINKING ,NO SOUND NO PICTURE '
PLEASE I DO NEED HELP TO FIX IT .THNKS
Nov 15, 2008 | Akai LCT2715 27 in. LCD Television
Kds55a2000 red light flashing
The SONY Owner's Manual for the KDS55A2000 does not state what the 4 times blinking Power LED means.
However, my Sony Extended Care Service support insists that the projection lamp is the cause for the 4X blinking LED
Power light.
I do not agree but am forced to buy a replacement lamp (not cheap) to prove that the problem is probably the fan, as the TV Technician states elsewhere in these FixYa support questions and answer
Nov 10, 2007 | Sony KDS55A2000 55" HDTV
Televison & Video Logo
42 people viewed this question
Top Televison & Video Experts
Electro Med Services...
