Want turn on,power button blinks three diffirent times,then turns itself back off
  • 2,963 Answers
Owner's manual troubleshooting? no manual, try MFG website, or their customer service email or
manualslib.com
Posted on Apr 05, 2015
SOURCE: TURNS OFF BY ITSELF
it's time for a projection bulb,order it and put it in yourself.
Posted on Jan 14, 2008
Slinteriors
  • 8617 Answers
SOURCE: blinking power button
Blinking power light is usually due to bad capacitors on the power supply. See the tip for RCA atc336 under my profile that can apply to your set as well.
Posted on Apr 09, 2008
HeXx13505
  • 65 Answers
SOURCE: I have an RCA Scenium 61
sounds like you need to replace the color wheel but most of the time that is almost as expensive as the TV itself best bet for this problem would be to bring it to a shop and have it serviced
Posted on Mar 27, 2009
SOURCE: it wont stay on it cuts itself off and on the power button has t
This seems to be a problem in the Power Supply I would think. Either that or a fault that is overloading the PSU.
This means a trip to the repair shop.
Make sure ya get a firm "Quote" for tha fix before proceeding.
Posted on Jan 20, 2010
info33
  • 72 Answers
SOURCE: Our Sony KDF-55XS955 turns off after 60 to 90
That is a definitely a lamp issue - Get a NEW lamp (with casing) online, have it shipped overnight - install according to your user manual (this is a common mainenance issue) and you should be fine. Or just call Sony or go to their website and they'll ship it directly to your home. Best Regards,
Beach TV Repair
Treasure Coast, FL
Posted on Jul 04, 2010
Panasonic TC-P50VT25 1 yr 3 month old powers off after 30 secs blinks 11 times pauses blinks 11 times and continues
The issue suggests either no voltage to that fan or it is bad--most of these all fans are powered from the same source.
I have seen this before---try swapping fans if they are identical--if another where you swap it now does not work--fan is bad.
Usually we (in the shop) if find this change all three fans.
Mar 20, 2012 | Televison & Video
What does theblue light mean when its blinking
the steady, blinking blue light means it is working. If the light blinks quickly, ususally 3 times, then it is either turning itself off or turning itself on. if you're getting a steady blink, try holding the button down long enough for it to flash rapidly 3 times in succession. after that, it should blink no more, because you have just turned it off. Want to turn it back on? hold the same button down until it flashes rapidly 3 times again, and you have just turned it back on.
Jan 23, 2011 | Mad Catz PS3 Bluetooth® Headset Wireless...
When the tv plugged up the power led blinks 3 times. When the power button is pressed the tv comes on for three seconds and turns back off. What could be the problem? Could this be a convergence problem?
Do the self check when power light goes out:
ON front of set (not remote) press and hold both the Menu and Input (Device) buttons at same time for 5 seconds or longer and release both buttons.
Power light will blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat it several times.
Let me know code.
SD TECH
Sep 24, 2010 | Mitsubishi WT-46809 46" Rear Projection...
Our Sony KDF-55XS955 turns off after 60 to 90 seconds, the green power button blinks about 30 steady blinks then turns itself back on, then repeats the turnoff, blinking 30 times, then turning back on. ...
Beach TV Repair
Treasure Coast, FL
Jul 04, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
IT TURN OFF ITSELF RIGHT AFTER TURN ON GREEN
If the Lamp red light is blinking then replace lamp, replacement procedure is written in user manual and its easy.
If standby/ power red light is blinking then please count its blinking and post here. It is an error code that has info about problem in specific section of tv.
You will see 3 seconds long pause between blinks so count pause to pause.
May 11, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
TV won't turn on, standby LED starts blinking
HI, this is the result of an unstable power sector in this unit. the fly back is malfunctioning and, you will need to replace it asap. i will list the part number below and a link to a site as well. you can purchase this part on-line if you wish.
FBT ASSY NX-4521//X4
Sony Part Number: 1-453-310-11
CLICK HERE TO ORDER
Jun 21, 2009 | Sony FD Trinitron WEGA KV-27FS120 27" TV
I have an RCA Scenium 61" DLP tv. Recently when you attempt to turn it on, it turns back off and the power button blinks three times. Then the tv will continuously attempt to turn itself back on with the...
Mar 27, 2009 | RCA HDLP50W151 50" Rear Projection HDTV
Blinking power button
Mar 23, 2008 | RCA D44LPW134 44" HDTV
How to turn on Sony Trinitron without a remote control
Good day.
Please check with the channel buttons of your unit. They replace the power buttons functions.
chris
Mar 21, 2008 | Sony KV-27V40 27" TV
Televison & Video Logo
35 people viewed this question
Top Televison & Video Experts
Electro Med Services...
