Question about Water Heaters
Adust time on digistat - Water Heaters
  • 2,963 Answers
Owner's manual no manual, try MFG website, or their customer service email, or
manualslib.com
Posted on Apr 05, 2015
How to get my clock running
activate timer mode then set time and on times and off times if confused see utube for your unit it is helpful
Aug 01, 2014 | Hayward Industrial Products Hayward...
Can we install a a ptg 74pvp tankless hot water heater in a closet? Would we need to install grating in the closet wall to provide more fresh air?
Rheem Tankless Water Heater Selection and Installation Videos
  • Introduction - time 04:11
  • Pre-Qualifying the installation - time 01:13
  • Selecting the Right Product - time 01:48
  • Key Differences Between Tankless & Storage Heater- time 01:27
  • Choosing the Location - time 01:20
  • Installation: Major Components - time 00:58
  • Installation: Tools Required - time 00:48
  • Installation: Mounting the Heater - time 01:15
  • Installation: Plumbing & Gas Connections - time 04:29
  • Installation: Side Wall Vent Termination - time 02:41
  • Outdoor Installation - time 01:21
  • Connecting the Remote Control - time 01:42
  • Turning on the Water Heater - time 01:00
  • Commercial vs. Residential Products - time 01:47
  • Manifolding Multiple Units - time 01:43
  • Troubleshooting & Additional Support - time 01:01
Feb 02, 2011 | Rheem Tankless Hot Water Heater...
I suddendly got air in my hot water lines. Not all the time but has happened three or four times. At the same time it seems as though I have less hot water than I used to. Is it an element or do you...
Sorry to read about your problem, I hope this helps you out.
sounds like you have a defective fill tube, plus you water heater is on the old side, and is getting past the fail point.....
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 03, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
How do I set the time on the Grey Box?
The little yellow dial has to be pulled away from the box in order to line up the silver arrow with the correct time.
Pull the whole dial towards yourself, you will notice that the yellow dial can now turn so you can line up the times that are printed on it to the correct time of day it is when you do this.
It's best to set the dial clock to the correct time of day.
Then tighten the little pointers that have the on-off words printed on them to the times you would like them to function.
If I helped you please give me a vote,Gary
Dec 01, 2010 | Intermatic WH40 - Water Heater Time Switch...
Lose of hot water at times
If you keep kicking the reset you have a thermostat that is bad...it could be either the top or the bottom one...but you will have the check and see if it is switching to the bottom element or not...if it does switch to the bottom it is the bottom t-stat bad, if not then the top one is bad...
heatman101
Apr 28, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Have a timer on the hot water heater took out the times slot water doesnt get hot how do you take a timer off.
Hello The easy way is to leave it on.Here is what to do.Put a time slot back in and wait untill slot just passes the time then remove time slot.You have disabled it during the (off) time
Mar 31, 2010 | Water Heaters
Red alarm light on constantly and heating wont work unless over ride system
Have you tried turning one of the thermostats off.? They are both talking to the same unit and they may be arguing with each other.
May 21, 2009 | Dayton Water Heaters
I have a digistat scr with a flashing red light and no heating there is nothing wrong with the batteries, this only occured after a poweer cut.
Try this first before condeming the unit.
1. Turn off the power supply to the Digistat SCR (receiver unit)
and leave for 5 seconds.
2. Turn on power to SCR unit and check red light is on.
3. Press override button No.2 and check the green light comes
on and boiler fires.
4. Press & hold down button No.1 (Keep depressed), then
press No.2 and keep depressed. {The Red LED light will flash
a couple of times and then it will go out}
5. Now release both the buttons – {the two LED lights should
come back on}
6. Get the Digistat+2RF/+3RF unit and stand two metres away
from the SCR unit with the Digistat+2RF/+3RF unit in your hand.
7. Remove the battery cover and fit the batteries.
8. The Red LED light on the SCR will now flash for approx. 7
seconds.
9. This confirms that the radio signal is being sent and
received.
10. The Digistat+2RF/+3RF and the SCR are now successfully
linked by a dedicated RF address.
Mar 21, 2009 | Water Heaters
No constant hot water...
Only two things come to mind. Either the clock is not set to the correct time (which I'm sure it is) or one of the elements most likely the bottom one is not heating for some reason. I would start by leaving the heater on 24 hrs by removing the trippers and switching it on. See if the problem goes away. If it does then focus on the timer settings, give it more warm up time etc. Make sure the clock is set to the right time and keeps time. If the problem persists on a 24 hrs running schedule then focus on the elements. --Turn the power off at the breaker-- and remove the access cover for each of the elements and or thermostats. Check the thermostat settings on each element for reasonableness. Sometimes the thermostat is covered by insulation material. If you need further assistance please write back with more detail. I can walk you through an element checkout if you have an AC volt / ohmmeter but since its new it should been under warranty.
Jan 19, 2009 | Intermatic WH40 - Water Heater Time Switch...
Bosch AQ125BNG gas water heater
First thing I would do is clean and rebuild the watervalve. The watervalve on this heater mandates everything. This watervalve has a maintenance schedule in the manual. She be rebuilt every 3 years. Also sounds like the diaphram in the watervalve may be damaged.
Dec 13, 2008 | Bosch AquaStar Indoor Natural Gas Tankless...
Water Heaters Logo
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
