Question about Onkyo TX-SR302 Receiver
Receiver keep cutting off each time it is turned on.
  • Onkyo Master
  • 2,963 Answers
Probably a short in some of the wiring connections in the back. Make sure there are no wires or connections touching each other. Otherwise, there may be an internal issue. Are you sure the voltage setting is correct? 120vac vs. 220vac if that option is available. and you are using the incorrect setting (accidentally)?
Posted on Apr 05, 2015
Receiver is cutting on and off by itself
It is the power control relay that do the cutting OFF and turning On.
these relay is driven by a processor via transistor output.
• One will have to check circuits that accompanies with it.
• Have a plan , prepare tools and equipments
should you need to DIY.
• While having a plan, disconnect all speakers and reconnect later
one at a time if it turns On properly without the speakers.
Sep 22, 2012 | Pioneer VSX-D411 Receiver
Everytime i try to play my system at full volume it cuts out then keeps playing and carries on doing this to i turn it to a certain volume
First of all find out the recommended speaker impedance for the receiver. Then find out the impedance of the speakers you are using along with it.
Simple rule is the speaker impedance can be higher but not lower than the recommended value. If it is so the receiver will run hot and if you turn up the volume higher it will run even hotter and then the protection circuit will cut off the Amplifier output to prevent burn out of components. Even if you have one defective speaker this cut off can happen. To confirm defective speaker -- disconnect one speaker at a time and turn on the amplifier and play it at cut off volumes.If by disconnecting one particular speaker the Amplifier does not cut off -- THAT SPEAKER HAS A SHORTED COIL and needs replacement.
Apr 03, 2011 | Philips Audio Players & Recorders
The receiver keeps cutting out. i dont know why its cutting out everytime i turn it on. all it says on the face of the receiver is lpcm 48... Help?
I had this same problem with my Onkyo sr701, and it turned out to be a twisted kink in the speaker wire. Run a sound check to each speaker separately (from your receiver menu) and turn each one up until the receiver shuts off. Check the wire to the speaker that caused it to shut off and make sure the +- ends are not touching each other at either end, and that there are no twists or kinks along the way.
May 23, 2010 | Sony STR-DE945 Receiver
Receiver powers on then shuts down. Any mode (CD AUX,VIDEO,etc) will cause same result. Sometimes FM mode will keep receiver on for longer. Once speakers are connceted, shut down happens no matter which...
If it's not happening when your speakers are disconnected, your problem is not in the receiver, it's either a wire touching at the terminals on the rear of the receiver, or a bad voice coil or crossover in your speaker. If you re connect the speakers and it immediately cuts out, disconnect all speakers and reconnect one by one testing the receiver each time until your receiver shuts off or remains on with all wires connected and you've fixed the problem. If it cuts out, disconnect the problem speaker at the speaker and test again. If it stays on, problem is in the speaker, if it still cuts out, problem is in the wire. Hope this helps. If you need further help, post a comment and I can help you troubleshoot some more.
Aug 11, 2009 | NAD C730 Receiver
Receiver cuts inself off about 15 seconds after you turn it on
you need to check your speakers connections to make sure nothing is touching and all is connected right and not to have to many spkrs on the channels, also only have the skrs on that you are using, make sure zone 2 / 3 are off and multi volm is turned down
Feb 01, 2009 | Denon DRA-395 Receiver
Receiver keeps turning off after I turn it on.
CHECK THAT YOUR SPEAKER CABLES ARE NOT TOUCHING.ALSO DID YOU NOTICE THAT THE SPEAKER CONNECTIONS ON YOUR 605 ARE SIDE BUY SIDE NOT ABOVE EACH OTHER?
Jun 02, 2008 | Onkyo TX-SR605 Receiver
How do you reboot the Denon AVR-2807 to factory settings
To reboot, turn receiver off by the small on/off button, not the big standby button. While off press the night and pure direct button at the same time and keep holding them with your right hand while pressing the small on/off button with your left. You will see your receiver menu flash. When you see it flash let go of the night and pure direct button and the receiver will reset it self to the radio station 87.50. The receiver's microprocessor has now been set back to factory. Enjoy this info is straight from Denon's Tech support. I had to do this on mine
Nov 25, 2007 | Denon AVR-2807 Receiver
Reciever turning off.
You have a short in the speaker wiring. Simply put, the pos and neg (red/black ends) of your speaker wire are most likely touching somewhere. The receiver has a short protection circuit that keeps you from blowing the receiver or your speakers. Either try re-cutting the ends of the speaker wire, or if that doesn't remedy the issue, buy new speaker wire.
Jun 18, 2007 | Onkyo TX-SR601 Receiver
Onkyo TX-SR302 Receiver Logo
56 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
