Question about Maytag Washing Machines
This print SUD/5UD is where the time of minutes left should be. It won't go away either! Could anyone help me solve this issue?
Maytag washer (4000 series)
  • Maytag Master
  • 2,963 Answers
Owner's manual troubleshooting no manual, try MFG website, or their customer service email
Or try manualslib.com
Posted on Apr 05, 2015
I have a Kenmore Elite Smartwash QuitPak9 washer. I keep getting error messages 02F and Sud or 5ud . Seems washer will not drain , Can get it to drain sometime , no clog
its a suds sensor error. meaning tom much or the wrong detergent was used and it has clogged the wash cycle, you will have to try to run rinse cycles over and over to u clean it out if u can, some machines have an auto clean cycle for this problem, it is difficult to deal with as I have the same issue with one of mine and still not running right
Jan 07, 2017 | Kenmore Washing Machines
What does 5ud mean 10 minutes from finishing 5 Ud displayed can't open door?
The SUD (not 5UD) code is displayed when excess foam is detected (possibly because excessive detergent is being used). If your machine does not cure itself, you may have to run an "Eco drum clean" cycle (if your machine has it) or a 90 degree cotton cycle with no detergent and no load.
Aug 29, 2016 | Samsung Washing Machines
What does 5ud mean on a elite he3
I think the 5UD is SUD. It means excessive sudsing has been detected, and a suds routine has been started to reduce excessive suds. This routine will add time to the original cycle. I have had this on my display a couple of times when I guess I put too much HE soap in the machine.
Jan 15, 2012 | Kenmore Washing Machines
Washer code 5ud
Hello & Welcome to FixYa
Sud error is displayed when the washer is unable to drain, press PAUSE/CANCEL button twice to clear the display. After this please check the drain hose and drain pump filter for any blockages and make sure it is not clogged with foreign particles. You can also check the drain pump to verify that its working. Please get back to me if you have any other questions.
Kevin
Dec 02, 2011 | Kenmore Elite 45986 Front Load Washer
I'm getting an 5ud and don't know what that means?
Hello, Thank You for using FixYa. I will be helping you today.SUD means suds as in soap suds. Are you using too much soap? Are you using high efficiency detergent? If your using the correct detergent and not using too much,Only fill to bottom line on cap and still getting sud error then you may have a failed pressure switch.
Thank You and please rate my answer if it was helpful..
Jun 16, 2011 | Kenmore Front Load Washer
What does '5ud' or Sud displayed on the light console mean?
It is meant to be SUD rather than 5UD and it stands for 'suds'- too much sudding. Machines normally go into a mode to flush the suds out at that point. As a suggestion it could be you are using too many tablets/too much soap powder.
John C
Feb 16, 2011 | Whirlpool Washing Machines
The washer screen says 5ud. wat does that mean?
"SUD" means just that - suds. It may mean too much detergent, or drain pump clogged, or water level switch is faulty. Check drain line and drain pump first.
Vlad
First Choice Appliance
Feb 05, 2011 | Dryers
Maytag 4000 series 4.5 cu saying SUD PLEASE HELP!!!
this usually means to much soap.you can either shut it off or unplug it for a few minutes let the suds die down and restart it with just plain water this may to a couple of times. you can also use a wet dry shop vac and attach it to the end of the drain hose to remove all the water and restart your machine.
Oct 15, 2010 | Maytag MAH6700AWW Neptune Front-Load...
Whirlpool Duet Mdl GHW9150PWO Washer stops
HI. this code represents a Long Drain issue.
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
Press PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is running.
• Check the drain pump filter for foreign objects
• If the above does not correct the problem replace the pump
Oct 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Error codes
I own a HE3 kenmore elite for 4 years now and the troubleshooting codes are: SUD When excessive suds are detected, a suds routine automatically starts. This causes the cycle to go longer to remove the excess suds. Reduce detergent amounts or use HE detergent. The F02 error I had with mine and it is a drain problem. Book says check the hose for kinks, clogged or is it more than 96 inches above the floor. On mine it was the fan pump on the forward motor that drains the washer. It was worn and not pushing out the water fast enough. You will hear a high pitched whine at the front bottom of the washer if this is bad. To reset the washer from the F02 error, select pause/cancel twice to cancel the cycle. Unplug washer or dissconnect power. good luck
Jul 07, 2007 | Kenmore 46462 Front Load Washer
Washing Machines Logo
306 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
