Why is water leaking from the hose? Do I need to replace it?
    Genius:
  • Washing Mach... Master
  • 1,585 Answers
Yes
Posted on Apr 12, 2015
Leaks water
see this causes and fix it. God bless you
Drain Pump If the washer is leaking water the drain pump might have a hole or crack. Or, the bearings might be worn out. Replace the drain pump if it is leaking water, they're not repairable
Tub Seal and Bearing Kit If the washer is leaking water the tub seal and bearing might have a tear or rip and is letting water leak past. The tub seal and bearing can be replaced. This is common and relatively easy to replace.
Tub Seal Kit If the washer is leaking water the tub seal might have a tear or rip and is letting water leak past. The tub seal kit can be replaced. This is common and relatively easy to replace.
Tub Seal If the washer is leaking water the tub seal might have a tear or rip and is letting water leak past. The tub seal can be replaced. This is common and relatively easy to replace.
Tub to Pump Hose If the washer is leaking water the hose from the tub to the pump might be split or torn. Don't try to cut off the bad piece of hose and stretch it to fit the pump, this will put strain on the remainder of the hose and may cause a sudden and complete failure of the hose which will dump potentially hundreds or thousands of gallons of water onto the floor because the next time the washer tries to fill all of the water will end up on the floor and so the washer will never shut off the valve. Any time there is a damaged hose, replace it completely with the OEM part.
Washing Machine Fill Hose If the washer is leaking water, check the fill hoses on the back of the washer, this is the most common place for water to leak. If the washer still has the original black rubber fill hoses replace them with stainless steel or some other, more durable hose.
Drain Hose If the washer is leaking water check the drain hose. The most common places for the hose to spring a leak is from the connection to the pump out to the back of the washer. Another common occurrence is when the washer gets pushed too far back against the wall.
Sep 30, 2012 | Washing Machines
Tip
How to troubleshoot water leaks
Water leaks in a washer are often difficult to trace. There are many possibilities to look for. The problem could be a loose connection, a broken hose, a cracked component, or a defective seal. It could also be a hole in the tub. If a hole in the tub is the problem, it's usually best to replace the washer.
Most leaks can be eliminated by tightening water connections and replacing deteriorated components. To stop a leak:
Check the lid seal. If faulty, replace with a new gasket.
- Check the hoses at faucet connections. Tighten connections or replace hoses.
- Check the hoses at water valve connections. Tighten connections or replace hoses.
- Check the drain hoses. Tighten connections or replace hoses.
- Check the inlet nozzles. Tighten connections or replace nozzles.
- Check the splash guard. Tighten connections or replace.
- Check any plastic valve. Tighten connections or replace.
- Check the outlet hose to drain. Tighten connections or replace hose.
- Check the water pump, using the procedures that follow.
on Jan 16, 2010 | Washing Machines
Leaks from underneath
Drain Pump If the washer is leaking water the drain pump might have a hole or crack. Or, the bearings might be worn out. Replace the drain pump if it is leaking water, they're not repairable.
Tub Spin Seal If the washer is leaking water the tub spin seal might have a tear or rip and is letting water leak past. The tub spin seal can be replaced. This is common and relatively easy to replace.
Sep 30, 2012 | Kenmore Elite Washing Machines
Water return hose leaking on
Your post got cut off. Leaking on ...what? If the hose is loose, may need to just tighten the hose clamp. If the hose is ruptured, replace the hose.
There are only 2 water return hoses: from heater core to engine, and from radiator to engine- this big hose connects to the water pump on the front of the engine- If it's leaking there, you must determine if it is the hose or the water pump[. If it's the pump it will have to be replaced. Here's hoping it's just the hose. Good luck. Post back for more.
Jul 08, 2012 | Cars & Trucks
1998 Dodge Durango heater hose
The metal section is part of the water pump. You can just replace the rubber section of hose.
Nov 01, 2011 | Cars & Trucks
Old admiral clothes washer leaks at front
Troubleshooting Water Leaks
Step 1: Check the lid seal. If faulty, replace with a new gasket.
Step 2: Check the hoses at faucet connections. Tighten connections or replace hoses.
Step 3: Check the hoses at water valve connections. Tighten connections or replace hoses.
Step 4: Check the drain hoses. Tighten connections or replace hoses.
Step 5: Check the inlet nozzles. Tighten connections or replace nozzles.
Step 6: Check the splash guard. Tighten connections or replace.
Step 7: Check any plastic valve. Tighten connections or replace.
Step 8: Check the outlet hose to drain. Tighten connections or replace hose.
Step 9: Check the water pump, using the procedures that follow.
Aug 25, 2009 | Maytag PAV2300 Top Load Washer
MY TRUCK IS LEAKING SOMETIMES COOLANT, COULD IT BE A HOSE OR THE WATER PUMP?
Check the radiator and hoses for leaks. Also, look at the water pump and see if any coolant is leaking out of the vent or "weep" hole. If coolant is leaking from the weep hole, the water pump is defective and will need replaced. When checking hoses, look for cracks and leaks, especially around the hose clamps. Hope this helped and best wishes.
Aug 05, 2009 | 2005 GMC Sierra 1500 Hybrid
My clients unit is leaking substaintial water in
Check the drainage hose to see if its connected properly. it is located under the unit. it may be loose or, not connected correctly. if the drainage hose is connected properly, this will be a faulty water valve. replace if found to be faulty.
Jun 16, 2009 | Dishwashers
Water leaks
If there is water leaking from under the washer, then you have a water leak from one of your water hoses. Check the back of the washer, where the water comes into the washer, to see if its leaking water or the hose is cracked. If its leaking water from the intake hose, then unscrew the hose and check the rubber washer, to see if it needs reolaced. Sometimes those rubber washers get cracked or broken. If that doesn't help, unplug your washer from the power cord and unscrew your intake water hoses and flip the washer gently on it's side and check the water hoses under the washer for leaks or cracks. Replace the hoses if cracked. Your local hardware store should have replacement hoses. This should solve your problem, but if not, then you need to call a washer repair person to look at it. I hope this helps.:)
Jan 19, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
The water does not drain out. Water in tub bottom
hi Most dishwashers discharge used water through a pipe or a hose connected to the drain or garbage disposer under the kitchen sink. If the drain line is made of flexible hosing, it may have cracked from prolonged exposure to hot water. Examine the hose; if it's damaged, replace it. If the hose is leaking at its connections with the disposer or dishwasher, tighten the fittings or clamps at the connections, or replace the clamps. Also check for water leaks around inlet valves, drain valves, and anywhere you see flexible hoses and hose connections. Leaks at clamps can be stopped by tightening or replacing the clamps. Leaks in hoses can be eliminated by replacing the hoses.
Sep 13, 2008 | Amana Dishwashers
Washing Machines Logo
24 people viewed this question
Top Washing Machines Experts
