Question about Garden
Stilh FS 450: I serviced the carburetor and changed the spark plug.It still does not start.
I serviced the carburetor and changed the spark plug.It is still not starting.
    Top Expert:
  • Garden Master
  • 52,126 Answers
Make sure the kill button is in the run position
Posted on Apr 05, 2015
Fs 85 loses power in the heat
Change all filters--and spark plug. Use a good cleaner in fresh fuel. dump the old first. use premium fuel--it has less ethanol in it
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/david_2f6e03df6c124197
Jul 14, 2014 | Stihl FS 85 Weed Eater
Stilh bg55 spark plug setting
Hi
Stilh recommend 0.020 inch (20 thou), however I have found that 0.025 (25 thou) or 0.6 mm provides a better start and run arrangement.
Regards
Jacko from down under
Apr 26, 2014 | Stihl Bg55 Bg65 Bg85 Leaf Blower Fan
I have a dewalt d28710 metal chop saw which blows the 13 amp fuse in the plug when I press the trigger to start cutting , anybody else had this problem ?
Download Link:
This service manual contains detailed descriptions of all the repair and servicing procedures specific to this power tool series.
1.stihl ts350 parts manual
There are separate handbooks for servicing procedures for standardized parts and assemblies that are installed in several STIHL power tool models. Reference is made to these handbooks in the appropriate chapters in this manual. As the design concept of models FS 120 FS 200 FS 300 FS 350 FS 400 FS 450 and FR 350, FR 450 is almost identical, the descriptions and servicing procedures in this manual generally apply to all models.
2.stihl ts350 parts service manual
Dec 03, 2013 | Saws
Check tps on 2007 wr450
Hi, Gerard and the usual suspects are:
1. Severely discharged or a damaged battery, should have 12.5 volts or better and be able to pass a load test if necessary.
2. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
3. Spark plugs in bad condition or partially fouled.
4. Spark plug cables in bad condition and leaking check for spark leakage in the dark
5. Spark plug gap too close or too wide.
6. Faulty ignition coil, module, and or sensor.
7. Loose, dirty, or corroded ignition module connector at crankcase.
8. Faulty CKP or CMP, MAP, ETS, ATS, TPS, O2 sensor.
9. Dirty air filter.
10. Intake air leak.
11. Water, dirt, or rust in the fuel system, carburetor and/or filter.
12. Old dead or bad fuel.
13. Fuel tank vent system plugged or carburetor vent line closed off.
14. Vacuum line from intake manifold to fuel valve is broken, cracked, pinched, or missing.
15. Carburetor controls misadjusted.
16. Damaged carburetor.
17. Incorrect valve timing.
18. Weak or broken valve springs.
19. Damaged intake or exhaust valve.
20. Check for engine trouble codes
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
Diconnected TPS good results WR450 WR 400 426 450
http://www.dirtbikeworld.net/forum/archive/index.php/t-7603.html
YAMAHA WR450F Owner Service Manual
OEM parts for Yamaha
YAMAHA WR450F Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jul 10, 2013 | 2007 Yamaha WR 450 F
Yamaha kodiak 450
Your float adjustment is incorrect, asis your fast idle
Jul 02, 2013 | Motorcycles
Stilh trimmer wont start changed plug still doesnt even fire
Please make sure you have no leaks on the carburetor, if it has not been turned om for a long time, prime the engine for cold start. Here is how to do this.
Clug exhaust pipe while you crank it up.
Pump the bubble filled with gas closed to the carburator.
Thanks,
Jul 17, 2011 | Garden
When i give my stihl weedeater (fs 55) gas it dies. i changed the gaskets in the carburetor, new spark plug, new air filter. it idles fine just when i give it throttle it dies
This could be from a bad fuel filter (has a dark appearance when dry), from the spark arrestor screen in the muffler being plugged up with carbon deposits (take out the spark arrestor screen and clean it by burning off the carbon deposits), or the carburetor needs to be adjusted. If the carburetor needs to be adjusted I would take it to the nearest Stihl dealer that has a Gold Certified Technician. That way the unit is adjusted properly and is in good running condition. You can find a local dealer with the dealer locator. The link is HERE.
Mar 19, 2011 | Garden
Starts but dies when warmed up or gas it and choke off dose this couple times then wont start till totaly cold again
Check the fuel filter, air filter, and muffler for plugging. Inspect the fuel lines for decay or damage. Make sure the carburetor fasteners are tight including the carburetor to cylinder mountings. If still not running properly, service the carburetor and rekit if the diaphragm in the lower chamber is hard or cracked. Also, inspect the fuel metering valve that the diaphragm controls. If the tip of the needle is damaged, replace it. Remove the spark plug and check for snappy, blue spark when the saw will not start. Hope this helps!
Jun 13, 2010 | Husqvarna 450 e-series 18" Chain Saw
Want to change the spark plug on my new bike - 07 yamaha yz250f. Don't have a manual, is it a big deal ?
Taking out the plug is straight foward ,you should have a plug spanner in your tool kit .But take care putting the new plug back ,and DON'T cross thread the plug ,as this will damage the head and cost a lot of bucks to repaire .
Mar 16, 2010 | 2004 Husaberg FS 450 e
CRF 450 Honda leaking oil through carburetor
it sounds like your valve/rocker cover to spark plug tube seal is folded over or something. My reason for saying this is, because the only place for oil to get into the plug tube is a bad seal to the cover or the spark plug isn't tight? and that hole is for expelling liquid so it doesn't cook the plug into the head
Dec 06, 2008 | 2005 Honda CRF 450 R
Garden Logo
277 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
