The machine drains fine. The pump is working correctly. No matter how the machine is loaded, its spins out of balance and rocks and jumps. What's wrong?
    Genius:
  • Washing Mach... Master
  • 1,585 Answers
Check impeller in pump
Posted on Apr 12, 2015
5 Suggested Answers
SOURCE: off balance during spin cycle
I have a Performa Model PAV3200AWW that would go unbalanced every time it would go into a spin cycle. I found the problem to be a worn out snubber. This is a plastic ring that is at the pivot point for the whole tub. It separates the metal to metal contact at the bottom of the washer pivot point. The part is less than ten dollars, but it is a quit a job to replace. I had to remove the whole tub to replace mine, but it did solve the problem. If you see a lot of plastic shavings around the pivot point, then this could be your problem.
Posted on Dec 15, 2007
  • 22 Answers
SOURCE: Maytag Atlantis Washing Machine does not ever drain or spin unless lift lid
your machine needs a new lid switch assembly!
Posted on Aug 22, 2008
honeymokey
  • 3113 Answers
SOURCE: Washer will not stay balanced on spin cycle no matter what size load.
The tub brace or spring may have come loose.
Posted on May 05, 2009
  • 693 Answers
SOURCE: whirlpool washing machine 6alsr7244mw3 always out
A very common call I get on Whirlpool built direct drive washers, and one of very few problems they have, is that the machine vibrates like it's out of balance when spinning even without any clothes in the basket. Sometimes it'll walk across the floor if this is allowed to worsen.The cause is nearly always support pads. The entire mechanism rests on these three small plastic pads, and when they wear even a little bit, the machine will vibrate like crazy in spin, like its load is badly out of balance. Replacing these pads (part 285744, around 10 for the set will nearly always correct this problem. And they aren't hard to replace if you re just a little handy Here s how Unplug the washer. Remove the 2 Phillips screws that retain the console. On some machines, these are hidden under console end caps that must be pried off. On newer models they re on the back of the console Rotate the console fwd then up and back it will hang back out of the way if the washer s away from the wall far enough.Unplug the white lid switch plug and pry up the 2 large clips that hold the cabinet to the washer back panel.Tilt the entire cabinet forward and it ll unhook from the retainers on the base. Lift the cabinet off and set aside (not as heavy as it sounds With the cabinet off you ll see 3 large horizontal springs, one in each corner of the support 'tripod and one smaller, vertical one in the left-rear that counterbalances the motor's weight. Unhook all 4 of these springs and insert a small piece of 1 by (5 8 or 3 4 thick) board to prop the mechanism up, to access the pads one at a time. Insert the piece of wood between pad locations, on a side of the support triangle a helper's handy here Use a little lighter fluid to clean the mating surface of the support plate that these pads ride against before inserting each new one. Be careful not to scratch the support plate when working under it it needs to be smooth and contaminate-free. Knock the old pads out one at a time, by lightly tapping on their mounting pins from underneath with a hammer. Put each new pad in place in its mounting holes, carefully remove the wooden 'shim then stand up and push down ******* the tub on that corner. You ll hear and feel the pad snap into its mounting holes.Repeat this process for each of the other two pads mounted on the support tripod' (do the rear, 'fun' one last after you have experience replacing the other two and your washer will behave a whole lot better in the spin cycle. And if you have any trouble finding these support pads locally, let me know. I keep lots of them in stock. You can order a set here Oh, and remember to reach around and pat yourself on the back! You just saved yourself at least 100.00
Posted on Oct 25, 2011
My washer will not empty all of the water out on the spin cycle, it does not matter which wash cycle I have put it on. I have even tried the Drain and Spin cycle. I have even taken all of the clothes out...
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 15, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have a top load Maytag washer which I have had for about 5 years. For some reason, for appriximately the last year, it seems to have problems with balance when spinning. I have to be more cautious in...
Hi from retired Englishman in SW France
I mostly answer front load problems but ' out of balance' is a common problem with both!
I don't believe the legs do 'auto correct'; they can be adjusted to correct.
It is necessary to ensure absolutely that the machine, even when empty, has all 4 feet very firmly on the floor, and I mean firmly ;-0)
Doesn't matter whether it is empty or not but switch it off then-
very firmly push one front corner diagonally into the centre of the machine and see if the machine moves or rocks AT ALL, even the slightest. If it does you will need the open-ended spanner which came with the (new) machine........which of course went missing a long time ago?!! An adjustable spanner will suffice.
Adjust the foot under that corner downwards until it is very firmly- almost pushing- against the floor but not so far that the corner lifts up!
If this corner did not rock do the same to the other.
Once you cannot rock the machine the slightest little bit, screw the locking nuts up tight to the underside of the machine so that they will not move. Ideally the rear feet should also be locked.
If this has not cured the problem it is possible that the internal drum suspension is malfunctioning.
Good luck,
John C
Mar 18, 2011 | Maytag Washing Machines
Machine jump all over on spin cycle
I don't know what machine yours is- front or top load. I mostly answer front load problems but ' out of balance' is a common problem with both!
Jumping during spinning so common- the initial cure is the same.
very firmly push one front corner diagonally into the centre of the machine (sorry about my UK spelling!) and see if the machine moves or rocks AT ALL, even the slightest. If it does you will need the open-ended spanner which came with the (new) machine........which of course went missing a long time ago?!! An adjustable spanner will suffice.
If this has not cured the problem it is possible that the internal drum suspension is malfunctioning but I've not had any feedback of this nature.
Good luck,
John C
Feb 15, 2011 | Washing Machines
It doesn't self balance and spin out all the water from clothes. the clothes are very wet, especially jeans. And the washer rocks bad during the spin cycle.
heatman101
Oct 20, 2010 | GE WSXH208A Front Load Washer
LG Washing Machine won't spin, signals that load isn't balanced
Check the drain clean out at the drain pump. If is cloggedm with debris, it will not spin and go off a a long drain error code.
Feb 06, 2010 | Washing Machines
I have a Maytag Atlantis washer that runs fine until the spin cycle. Once it hits the spin cycle, it gets very loud, like it's off balance. When we get the clothes out, they're still soaking.
make sure you loads are balanced, put heaviest clothes in first... if you can rock it by hand then the legs are not adjusted properly. If you stand 2 feet away from front of machine, jump up and down and see it move the floor is soft and you need 2 sheets of plywood to make 1 1/2 inches put under the machine
Aug 17, 2009 | Washing Machines
My washer is perfectly level but during the spin
if you can make it rock by hand or by jumping the legs are not adjusted proper.it can also rock if the floor is soft... then get thick plywood under the washer ....11/2 inch should be good.you should try to balance the load put heavy things in first
Aug 04, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Out of balance condition
check the drain pump in the bottom of the unit and verify its not clogged, verify unit is level, also check the support struts/springs for the tub.
May 26, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Spin cycle
the machine has sensors within it that detect off balance loads, very possible that the 1 or 2 items are not enough to correctly balance themselves, so the machine will never achieve full speed spin.
Nov 22, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
