Question about Hoover Washing Machines
I have a Hoover Eco Technology, 1600rpm, DYN 8164 D It keeps coming up with error code 8
  • tom cassidy
    tom cassidy Apr 05, 2015
    Hi Naomi Blom, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
3 Suggested Answers
  • 6277 Answers
SOURCE: my hoover dyn 8164d washing
Hoover's 'e03' states 'drain timeout'- probably a blocked filter or even jammed drain motor/pump.
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Following are my complete and hopefully 'coverall' pre-typed guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Sep 07, 2011
traviskelly8
  • 62 Answers
SOURCE: how do i open my hoover eco technology door when it wont open and comes up with the code E15
That means a sevies tech has got to come out an unlock
it the main board is bad these front loaders
are bad about this they will lock up all your
cloths
Posted on Jun 13, 2014
Hoover DYN 8144D Electrical fault/Crackling noise when power is applied
get a service technician to check it over but there is a very serious problem that may be safety related
Sep 07, 2015 | Hoover Washing Machines
My hoover washing machine model dyn d8p has a code error of ao3/t know what is wrong ..its new and just used then 3 month now but it was not drying well and showing that error code
if it is 3 months old , I suggest that you call the repair shop as it is under warranty
touching it yourself or having any unauthorised person fix it will void the warranty.
Apr 10, 2015 | Hoover Washing Machines
How do i open my hoover eco technology door when it wont open and comes up with the code E15
cloths
Jun 13, 2014 | Zanussi ZWD1470W Front Load Washer / Dryer
Hoover washing machine manual
HOOVER DYN 10144 DP What does it mean ERROR E13 CODE
Mar 01, 2014 | Hoover Dishwashers
Hoover DYN 9144 DG - 80
washing machine won't start. display screen is flashing constantly, no error codes up. does any one know what the problem is??
Mar 23, 2013 | Hoover Washing Machines
Hi we have literally just brought a Hoover dyn 7164 d and on first check-which the manual asks us to the error code e03 appears and will not drain!!!what do we do??its full of water!how can something...
What a heap of junk of a machine. The one I own died after 13 months taking the electrics in the house out with it. A faulty heating element was the cause. They leak over their electrics with predictable results. A modified element has been fitted. Avoid this and all Hoover products like the plague.
Dec 02, 2012 | Washing Machines
Hoover eco technology washing machine
Did you try washing your Samsung UN55C6500 55 LCD 1080P HDTV in a hoover eco technology washing machine?!
You'd have a whole lot better success trying to get your hoover eco technology washing machine to watch the Samsung UN55C6500 55 LCD 1080P HDTV.
They particularily enjoy soap operas.
Sep 25, 2012 | Samsung UN55C6500 55 LCD 1080p HDTV LED...
Error Code E13?
HOOVER DYN 10144 DP ERROR CODE E13
Nov 30, 2010 | Hoover Washing Machines
Error code 8 on Hoover vision hd 9 kg frontloader. No Manual.
Had same problem wouldnt spin found clip on motor had come loose pushed it back on problem solved!
Nov 18, 2008 | Hoover AAA160 Front Load Washer
Washing Machines Logo
44 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
