Question about Brother Sewing Machine, Model LS-2125
I plug my sewing machine to an adaptor to the outlet then I switch it on then switch the power button on the sewing machine but the light on the sewing machine is not coming on and won't work.
On Tuesday the 31st of April I received my sewing machine. from that day I started using it. I followed the steps in how to set it up. the power cord plugged in to and adaptor and machine been working fine until the fourth of April I was using the sewing machine then all of a sudden it cut off. so I switched of the power button on the machine and switch of the power supply. then I switch the power supply back on and the power button on the machine on and it didn't come on. I tried a couple of times but the machine still won't come on. what maybe causing the problem.
    Master:
  • Brother Master
  • 470 Answers
What kind of Adapter are you using?
Is it a voltage changer?
Ore does it let you plug a three prong plug into a two plug outlet?
Posted on Apr 05, 2015
I need to know where the power switch to my vintage sewmor sewing machine is
It depends on the model of your sewing machine. Usually, there is a push button switch somewhere on the machine. However, some machines did not have an on/off button--just activated as soon as they were plugged in to the electrical outlet.
Mar 11, 2017 | Sewing Machines
Sewing machine won't run.
1. Make sure the machine isn't set for bobbin rewind. Also, try to move the control hookup around slightly to ensure it is making a good connection.
2. Is it possible the power switch looks like it is on but isn't because of the surrounding light? Check this and the outlet you are using.
3. Is the sewing machine light on? A puppy biting in the wire could have caused a short so a pro will have to check the guts of the machine.
Aug 08, 2016 | Juki TL-98Q
How do I replace power switch on unidentified sewing machine?
Um, unless we actually have experience with your particular machine, how can we offer specific answers?
In general: Disassemble machine far enough to access power switch. Remove switch. Obtain matching switch. Install. Reassemble machine. Done.
Sep 15, 2015 | Sewing Machines
My brother sewing machine wont come on
test the outlet is working ok, then test the power adaptor, ensure the light on the machine is on and try working your way up the cable incase the cable is broken, if there is no light on the adaptor but is g etting warm after a while then one can assume it is working but this is not a 100% test. if it stays cold it could be defective and needs replacing. if you have another adaptor of the same type try using that to see if the machine works. best is to take to a repair shop or send it back to Brother if it is still under garantee.
I hope this was useful.
Apr 05, 2015 | Brother LS-2125 Mechanical Sewing Machine
My Pfaff model 1211 machine won't come on. The power switch has been replaced but no light and no power for stitching
Sounds like a bad connection somewhere as the power seems intermittent. Consult your repair man to check the electrics.
Apr 06, 2017 | PfaFF Sewing Machines
No power to machine, checked power cords were all plugged in properly and plugged into outlet, still can not turn on light or machine to operate
If you have a light to light up the sewing area, this light has to be on or the machine will not work.
The switch should be next to were the cord goes in the machine.
Jun 22, 2011 | Singer 3116 Simple
When I use the presser foot nothing happens. The machine is plugged in, turned on and everything is set up correctly. I was told my a not so reliable source that the motor may be shot. But, the machine...
even though it's only used moderately the motor can go out,
does the light come on?
try plugging the sewing machine into a different outlet
check to make sure the power cord is pushed all the way in
it also may be the power cord itself that has gone out
it could also be the on & off switch
Sep 01, 2010 | Singer 6038 Mechanical Sewing Machine
I have a Juki MO-655. I just threaded the machine, plugged it in and when I turn it on the light comes on but the motor doesn't start when I press the foot control. I have all the doors on the machine...
I also have the Juki M)-655. Look at the power button; it should have 3 positions. First position turns the power switch Off, second position turns the power switch on and it will sew, third position turns on both the power switch and the sewing light. Several times I have thought I turned on the power switch to sew only to realize it was not in the second position. Hope this helps.
Jun 14, 2010 | Juki MO-655 Mechanical Sewing Machine
Power doesn't work!
Disconnect, re-connect. If there is power at the outlet and the machine does not have any power, you may need a new power cord.
Or, it could be the switch is broken (internally).
Have the machine checked by a sewing machine service person.
Feb 21, 2010 | Singer 6038 Mechanical Sewing Machine
White swing machine will not turn on
begin by checking the power. plug something else into that outlet to be sure it has power. if it does, plug the sewing machine in again and check it.
if it still doesn't start up you will most likely have to replace the switch.
Sep 09, 2009 | Sewing Machines
Brother Sewing Machine, Model LS-2125 Logo
77 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
