Question about Garden
ENCORE Z ZTR with park brake issue
I have tried adjusting it and it seems that it does not pull far enough to engage hydropump release on both sides. I tried tightening the crown nuts on both sides to tighten bracket contact and I tightened the spring rods to max. adjustment where the springs are fully compressed and it still does not disengage transmission fully. What to try next? I do not understand how this is supposed to work?
  • 2 more comments
  • Eugene Rounds Apr 05, 2015
    Hi Zoowho, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? Could you answer a couple questions? What is the model number? should be something like 42K17Z.
    As the brake issue are just not releasing when use the mower or is it the you just trying to move the mower without the engine running?
  • Zoowho Apr 05, 2015
    I have looked for a model number and get nothing. It is an ENCORE Z 32" ZTR.The issue with the Prk Brake is that it is not holding the mower still when in neutral. The drive arms are in neutral and the machine creeps forward. When I set the Park Brake it does not seem to stop the creeping forward. So I attempted to adjust the lever arms and spring dampened control arms. I want to understand how to adjust it so it will stop creeping forward while in Neutral postiion.
    And with the Park Brake set.
    Users Manual does not address adjustment of the Park Brake.
  • 2,992 Answers
I googled: ENCORE Z ZTR with park brake
Try this or one of the others
http://www.encoreequipment.com/test/wp-content/uploads/2012/06/42B350Z-OPERATORS-MANUAL-933077.pdf
Posted on Apr 05, 2015
  • 2468 Answers
SOURCE: Snapper Rear Engine Riding Mower
if they have been adjusting it for you this many times they have done it wrong and have ruined the clutch face plate material by letting it slip and sand off the facing material,now its down to the metal back plate and its now metal to metal,you need to have the clutch replaced soon or your going to ruin more drive components
Posted on May 02, 2010
  • 3911 Answers
SOURCE: transmission belt slips, can it be adjusted to
You can replace the drive belt, and make sure the springs on the tensioner and clutch pulleys are good, but the belt itself has no adjustment. They stretch a bit with age, also not uncommon for the transmissions to go bad which means slow or no movement even though the engine runs normally.
Posted on Aug 10, 2010
  • 3 Answers
SOURCE: My 420 c won't steer to the left. I've made all
I'm not familiar with your system but it sounds like you could
have a bad pressure plate.
Posted on Jan 02, 2011
ToolBoxHero
  • 171 Answers
SOURCE: My auger stops rotating with
The most common cause of this is the drive belt is worn. If you remove the cover in the middle of the snow thrower and look at the belt farthest from the motor. This is the auger/blower drive belt.
With the engine not running, have someone depress the auger lever and check the belt. You should only be able to depress the long side 1/2 inch or less. More than that the belt has stretched and needs to be replaced. On some older blowers you can adjust the tension pulley, but most made in the last 15 years, you can't.
I didn't see what make and model this blower was but:
If this is a craftsman you can get parts through searspartsdirect.com. With other makes you can get parts through jackssmallengines.com
Feel free to ask any other questions. I know Craftsman Snow Blowers. Please remember to rate this answer!
Posted on Jan 13, 2011
  • 6468 Answers
SOURCE: poulan 42 parking brake slips
look at sears parts online
Posted on Apr 01, 2012
I need diagram showing how to put rear brake shoes on 1994 escort
Adjustment: 1) Start the engine and shift to Reverse. With the vehicle moving backwards, firmly depress the brake pedal several times to seat the shoes in the brake drum. Turn engine off. 2) Remove the console trim surrounding the parking brake lever. This isn't really necessary if you have a deep socket and extension. 3) Pull up on brake lever until the seventh notch is engaged, just listen and count the clicks. 4) If it is out of adjustment and you can't get the seven clicks, turn the adjusting nut located on the drivers side next to the lever. 5) Release the lever, block the front wheels, raise the rear end. Best to put on jackstands. 6) With car in neutral and brake lever released, rotate the rear wheels. The wheels should turn freely, but a slight drag is acceptable. 7) If the lever travels too far or the parking brake fails to hold the vehicle on a hill, tighten the adjusting nut a little more and recheck,
Jun 28, 2014 | 1994 Ford Escort
Parking light wont go out and keeps dinging
Reach down and release the parking brake at the same time pull up on the parking brake pedal. Sometimes the pedal gets bumped just enough to engage the switch indicating the brake is engaged.
Apr 13, 2014 | 2005 Pontiac Aztec
2004 cavalier wont move
The rear brakes are in fact engaged.
The parking brake handle may be released, but the rear wheel brakes are on.
Jack up one side and see if you can turn the wheel, then check the other side.
Jul 13, 2012 | 2004 Chevrolet Cavalier
How to adjust parking brake. do you need to take anything apart?
You cannot adjust the cables on a minivan manually. the tension is automaitcally adjusted by the self adjuster on the pedal release.
The park brake cables on this vehicle have an automatic self adjuster built into the park brake pedal mechanism. When the foot operated park brake pedal is in its released (upward most) position, a clock spring automatically adjusts the park brake cables. The park brake cables are adjusted (tensioned) just enough to remove all the slack from the cables. The automatic adjuster system will not over adjust the cables causing rear brake drag.
Due to the automatic adjust feature of the park brake pedal, adjustment of the parking brake cables on these vehicles relies on proper drum brake.
When the park brake pedal is applied the self adjuster is by-passed and the pedal operates normally to engage the park brakes.
When a service procedure needs to be performed on the park brake pedal or the park brake cables, the automatic self adjuster can be manually locked out by the service technician.
Aug 25, 2010 | 2004 Dodge Caravan
95 325 is e-brake doesn't fully engage
Adjustment will usually help, but try parking with front pointing down hill next time.(back in, apply E brake .) Emergency brakes usually hold better/well when vehicle front heading down hill. If it doesn't hold with front pointing down, then rear brakes need attention.
Apr 12, 2009 | 1997 BMW 318
Shifter issue?
Hi their.Yes there is a place that's not to hard to adjust. Underneath the truck on drives side there is an adjustment there.Make sure nothing was broke in the slamming on the shifter..
Mar 29, 2009 | 1996 Toyota 4Runner
PARKING BRAKE RELEASE
IF U SET DOWN ON THE ROCKER PANEL ON THE DRIVERS SIDE AND WITH YOUR RIGHT HAND REACH RIGHT UP TO THE RIGHT SIDE OF THE PARKING BRAKE ASSEMBLY, THEIR IS A LEVER U CAN FEEL (ITS GOT LIKE A LITTLE HANDEL TO THIS LEVER) AND I BELIEVE U PULL IT TO U, THIS IS THEIR INTENTIONAL TO RELEASE THE BRAKE, I HAVE A 97 AND I HIT THE PEDAL WITH MY FOOT SOMETIMES AND THE LIGHT WILL COME ON SO I HAVE TO RESET IT THIS WAY, I THINK TO MUCH FORCE OR OUT OF ADJUSTED BRAKE CABLE WILL CAUSE ALSO. GOOD LUCY TO U..
Mar 02, 2009 | 1992 Cadillac Seville
Releasing Parking Brake
adjust the park brake cable first (3 pedal clicks and brake should start to engage the rear wheels) then lube the park brake ratchet release parts (under the dash) with WD40, this should take care of the problem.
Jan 12, 2009 | 2000 Chevrolet S-10
Garden Logo
74 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
