Question about Garden
ENCORE Z ZTR Mower, Parking Brake not working properly.
I have tried adjusting it and it seems that it does not pull far enough to engage hydropump release on both sides. I tried tightening the crown nuts on both sides to tighten bracket contact and I tightened the spring rods to max. adjustment where the springs are fully compressed and it still does not disengage transmission fully. What to try next? I do not understand how this is supposed to work?
rick_amick
  • 72 Answers
SOURCE: Changing V belts on Nissan Frontier 2002 4cyl
That should be right if it is an idler pulley. On belts that do not have idler pulley you will have to loosen lock bolt on adjuster. Like alternator
Posted on Mar 24, 2009
  • 88 Answers
SOURCE: PARKING BRAKE LEVER- NO TENSION / DISC BRAKE ADJUSTMENT-OFF
If you remove the cover of the E-brake there should be a tention ajustment that you can do yourself.
Posted on May 19, 2009
  • 45 Answers
SOURCE: tightening parking brake for 2001 GMC Jimmy
Hi... to adjust rear brakes providing the shoes are good... just drive vehicle in reverse and pump brakes... rear shoes are self adjusting so they should "adjust" themselves... after doing this test by putting on park brake, put vehicle in drive and see if vehicle moves forward, repeat procedure if necessary. Hope this helps... please rate suggestion.... ty
Posted on May 21, 2009
SOURCE: 2005 Nissan Sentra 1.8S, with AC - how to replace belts?
first of all you don't have to loosen the pulley,this will no solve the problem,well you already loosen the adjuster,good,bot thing you have not done i will tell you now,on the power steering pump where the belt pass there is also a bolt that hold it ,you must loosen that also,then after you will see the pump moving on the two position that means you will see the belt loosen on 1 position an d the position it will tight the belt,try that man.............
Posted on Aug 23, 2009
  • 9 Answers
SOURCE: trying to adjust clutch on 2001 Hyundai Accent.
hydraulic clutches are non-adjustable
Posted on Oct 14, 2009
ENCORE Z ZTR with park brake issue
I googled: ENCORE Z ZTR with park brake
Try this or one of the others
http://www.encoreequipment.com/test/wp-content/uploads/2012/06/42B350Z-OPERATORS-MANUAL-933077.pdf
Apr 05, 2015 | Garden
I have a toro z149 ztr 52" when I release the parking brake it will die,I have replaced the seat switch twice and still dies
Check all your grounds for corrosion, wire damage, and contact points. If it did it before you changed the first seat switch and still does it, then its not that. Check fuses is there are any. There are 3 safety features that all work in conjunction. Blade engage, parking break, seat switch. Varying by type of mower.
Oct 31, 2013 | Garden
Dixon ztr 46
unhook the pto safty swicth you might have to jump it or leave disconnetected see if that will help you need some more detail
Jul 04, 2013 | Garden
Cub Cadet ZTR will not start
Is the blade engagement off? If that is ok, does the solenoid even click when you put the key to start position? If the solenoid doesn't even click check the battery connections and make sure they are good and clean. If the connections are good, are you sure the new battery is fully charged. If the battery sat around for a long time in the store it could need charged. If all that is good and then you don't get the starter solenoid to click when you put the key in start position, then it is either the seat switch, parking brake switch, handle switches, or mower engage switch keeping it from starting. If all that is ok maybe you have a bad starter solenoid. Please rate my answer so I am rewarded points for it.
Jan 30, 2012 | Cub Cadet Garden
Bobcat ZTR new blade brake won't engage while engine is running
SOUDS LIKE THE CLUCH SAFTEY SWICH IS BAD OR THE SEAT SWICH MAY BE BAD CK THAT OUT AND LET ME KNOW OK THANKS
Aug 18, 2009 | Husqvarna 23 Hp 48" Deck Yard Tractor
Arien524 when clutch is engaged the wheels donot pull right away
Sorry I should have posted this as a solution.
You might want to check the friction wheel to see if it is either worn down and needs adjusting or if it needs replacing.It could very well be just an adjusting. The friction wheel is located inside the panel under the engine. When looking inside the panel and you pull on the handle to engage the wheels you will see the round disc pull towards the friction wheel if it doesn't pull in tight enough you will have problems.Also check the belt and the idler pulley for the drive make sure the idler pulley moves easy and that it puts enough tension on the belt.
Dec 13, 2008 | Ariens 34 In. Zoom Series Riding Mower
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
