Question about Alba Televison & Video
Alba LCD 40/68F Power is swiched on then it is Stuck on 'DO NOT POWER OFF SCAN' it loads to 100% then the scan restarts in a constant loop. Would changing the inverter or main board be the solution?
SOURCE: Sceptre X30SV LCD display goes black with sound... Inverter? and other parts...
I too have the same problem...Searched and waited long time for parts. I have replaced everything and the thing still flashes and goes blank but has sound. Not worth anymore stress. My neighbor is an electrical engineer who I used to think can fix anything. He too is baffled. My fix suggestion... Getting a new LCD (not a Sceptre) tonight...with an extended warranty...Sceptre (and their tech's) no help if you don't have a warranty. I learned my lesson!
Posted on Jul 09, 2008
  • 191 Answers
SOURCE: VIZIO LCD 26 INCH model# VW26L HDTV10F NOT TURNING ON
unplug ur backlight inverter plug &power on to see ,if it doesnt on , change ur mainboard
Posted on Nov 10, 2008
  • 718 Answers
SOURCE: Vizio L37hdtv10a fails to fully turn on
You will have to isolate the main board and Inverters.
Unplug the inverters and turn on the set.
If it "turns on" then try re-connecting each inverter seperately to see if only one is causing the problem.
Posted on Mar 07, 2009
  • 70 Answers
SOURCE: Philips Magnavox 37" LCD Flat
Disconnect the LVDS Cable that runs from the small signal board to the display panel and apply power,if the screen comes on,the Small signal board (aka Scaler Bd ) is the faulty board. other than that,all that's really left that has gone bad for me is the logic board.
Posted on Jul 07, 2009
BoiseLCD
  • 63 Answers
SOURCE: I have a NS-LCD37-09 tv. No picture or backlight
Your main board is faulty. I've done several of these but haven't been able to figure out which component is actually bad these yet. I've simply had to replace the board itself, and it fixes it every time. One thing you can do to get your backlights to come on (and so you know I'm not Jive'n you) Is unplug the three wire bundle that spans from power supply to main board. This will usually make the backlights fire up. I even had one that after I left it that way for a minute (with the backlight on) it suddenly started working again! But this was short lived. :-(
One time I even tried recapping the entire main to see it that would fix it. It did not. I think it might be something to do with the small chip labeled SL37HA37. It's a 16 legged bastard near the 3-wire plug I told you to pull. It's that or possibly the bigger IC near it that has a heat sink on it. The ball grid array solder joints may be faulty. Just guesses, if any smart guys out there figure this one out, be sure to tell the rest of us please!
Thanks, Chris Boise LCD www.boiselcd.com
Posted on Apr 23, 2010
How do i put an alba ac40ne into recovery mode?
Uninstall the app then reinstall it.
Sep 16, 2017 | Cell Phones
Tv stuck on scan
Try Re-set... Turn the TV off. Un-plug it.
Every Tv made in the last 10 years has a Re-set...
Look up on the Net.. How to Re-set your TV...
Keep in mind. If you re-set it. It will go back to how you first got it.....
Hope this helps....
Jun 03, 2014 | Alba LDVD1538WDCH LCD TV
Repair ecm
why start with the most expensive part that is never bad.?
I5 engine. 4 cylinders. high MPG or high liters/100km
instead, why not check:
  1. CEL lamp glows running? oops. PCM is unhappy.
  2. no matter scan it. scan it with a obd2 scan tool (USA CAR?)
  3. first make sure the engine thermostat reaches 180F. more.
  4. then see if EFI holds closed loop mode,status at hot idle.
  5. If not we fix that 1st.
  6. Then we drive. and make sure at light flat cruise, closed loop holes. if not we fix that.
not guessing, just statistics.
1: fuel pressure i too high, , fuel reg stuck.
2: leaking injectors.
3: ECU stuck in limp home mode, and sucking fuel and has bad sensors.
4: exhaust pipe newer front oxygen sensor cracked, (sucks fuel now)
no cracks allows, or a bad oxy sensor here.
bank1 sensor 1 , replace at 100k miles for best L/km.
5: thermostat bad. runs cold .
6: FAILED to to the 100km tune up. bad. deal there.
there are simple tests in each case.
ask.
Feb 18, 2014 | Honda CR-V Cars & Trucks
Cant get any bbc channels on new alba tv freeview
In that case you need to auto scan your TV to get all available channels on your location..
Go to menu and find auto scan and enter it..For best results please complete the 100% scan..
Aug 28, 2012 | Televison & Video
Alba tv
You will need to see if the TV is set for the proper type of broadcast system (in the USA that is the NTSC standard) in the menu and that the antenna is giving a good strong signal.
Dec 23, 2011 | Alba LDVD1538WDCH LCD TV
Trying to scan: I can read on printer screen: LCD list need to be upgraded
When you try to scan using the product control panel, the message 'Error: LCD List needs to be upgraded ' displays on the computer. The 'LCD list' is the list of potential scan destinations that displays on the printer.
The solution to this issue is to re-establish the connection between the computer and the printer, and then set up the scan destination list again, if necessary. Try the following solutions in the order presented.
Solution one: Restart and reset
Follow these steps to restart your computer and reset the printer.
  • Restart your computer.
  • With the product turned on, unplug the power cord from the back of the product.
  • Unplug the power cord from the electrical outlet.
  • Wait 15 seconds.
  • Reconnect the power cord to the product, and then reconnect the power cord to the electrical outlet.
  • If the product does not automatically turn on, press the Power button.
  • Wait a couple of minutes to make sure that the product is ready, and then try scanning again from the product control panel.
  • If the issue persists, or if you want to make changes to the scan destination list, continue to Solution two.
Solution Two: I will post it after confirm the issue still exists.
Regards
Riztech
Sep 26, 2010 | HP Officejet 6500 Wireless All-in-One...
Computer got stuck
Long press the power button until it shutdown.
and then restart, if the system failure to start tell me what happen i will tell you the solution.
if the system start scan the system with antivirus. here some online scan that are verygood. http://www.precisesecurity.com/antivirus/online-scan.htm
may this help.
Feb 04, 2008 | Toshiba Satellite M45-S265 Notebook
Televison & Video Logo
71 people viewed this question
Top Alba Televison & Video Experts
Demonic-2011
Demonic-2011
Michael Galve
Michael Galve
Are you an Alba Televison and Video Expert? Answer questions, earn points and help others
