Question about COBY-PERSONAL & PORTABLE 1.8IN 2G VIDEO MP3 PLAYER - MP620-2GBLK
When its plugged into the usb on the computer despite im holding down the power button its not coming on
My iphone 3 is not working only the apple sign is coming while charging the phone
1. Turn the iPhone off by holding the button on the top of the iPhone for 10 seconds, until the screen is black.
2. Plug your USB Cable into the back of your computer (the back USB ports can be higher power then your front ones, if your using a laptop, just plug into any one) 3. Open iTunes on your computer, make sure its fully updated (it will ask you automatically to update)
3. Now hold down the Home button on the front of your phone (The button on the front of the iPhone, at the bottom, has a square inside of it, your thumb will fit into the button to press it down)
4. While holding down the home button, plug it into the computer, and keep holding down the home button 5. Eventually you are going to see a connect to iTunes screen on the iPhone display, this may take 30-45 seconds. (A USB Cord with an arrow pointing towards the iTunes Logo)
6. Once you see that screen, let go of the button 7. A Message should pop up in iTunes saying it has detected the iPhone in recovery mode and you must restore to continue 8. Click ok, and there should be a Restore button in the middle of iTunes on your computer 9. Click this and it will say it needs to erase everything and update. You must do this, there may be backup files for your iPhone on your computer, if there are, it will automatically ask you when its done to load those onto your phone.
For further information follow this article: http://support.apple.com/kb/ht1808
Aug 20, 2011 | Apple iPhone 3G
My itouch is locked with a passcode and it shows the itunes with the USB port pointing at it and when i plugged it into my itunes it said that it couldnt connect to the ipod because it was locked by a...
Okay well you have to do a full restore. Turn your itouch completely off. With it off, hold down the circle button and plug in the USB cable connected to your computer. The itouch will power on and you will see the apple, but keep holding in the circle button. After 15-30 seconds, you will see another (different) cable/itunes screen on the iphone. iTunes should then recognize that the itouch is in recovery mode and you can then do a restore. You should be good from there.
Remember, turn off the itouch. Then while its off hold down the circle button and plug it in. Keep holding down the button until the recovery screen comes up. Good luck!!
Now
May 18, 2010 | Audio Players & Recorders
HP Photosmart C7280 color ink running out despite not using it?
  1. Unplug power cable while the printer is ON.
  2. Press and hold the '#' and '3' buttons, and plug the cable back into the printer.
  3. Continue holding the buttons down for 20 seconds, and then release it.
if doesn't initialize successfully repeat
on step 2 press and hold the '#' and '6' button and plug in the power cable.
May 13, 2010 | HP Photosmart C7280 Printer
Itouch will not reboot. Stuck on update script . USB got unplugged while updating
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Try this it will put your ipod in recovery mode and you can restore it:
Plug the usb cable into the Ipod and NOT into the computer.
Hold the Home Button down for 5 second (do not release it)
Then Press and hold the Power Button for approx 10 secs (count them out)
Your iPod will reboot.
Release the power button and continue holding the Home button for an additional 27secs.
You may see the screen go blank or not.
Plug the USB end into the computer with itunes open.
Your ipod will mount in recovery mode.
May 05, 2009 | Apple iPod touch
I press the power button and the pearl logo comes on then it goes off with out saying please wait or loading i tried a brand new battery and nothin! i plug it into the computer and the music still wont put...
Try removing the battery, insert Pearl WHILE SIMULTANEOUSLY PRESSING and HOLDING the "PLAY" button. Windows Device Manager should see the device under "Human Interface Devices"as a "USB Human Interface Device". Run the latest firmware update, it will see the HID device and initialize it as a "Disk Drive", "_Generic MSC Recovery USB Device". Once the firmware update is complete the Pearl should work again. The trick was to remove the battery and hold down the "Play" button while inserting to force recovery mode.
Mar 27, 2009 | RCA TH1602 MP3 Player
MP3 Player Not Charging!!! (USB)
The most common cause is a flat battery. There is a trick to charging
the battery in these small mp3 players. It wont charge if it is turned
on, and it won't charges if it's in sleep mode (zzzz). Here what to do...
1. plug the payer into your USB port. or wall charger
2. switch thje player on
3. turn it off by either holding down the play button, or selecting
"System" from the menu
4. The screen will go black and the battery will begin charging.
Feb 15, 2009 | Coby MP-C7092 (2 GB) MP3 Player
Emprex me1 media player firmware update
Unplug your Emprex with the USB plugged into it, then while holding down the power button plug the emprex back in, keep holding the power button down until the screen changes from loading to the updating page, usually you have to hold the power button down for a around 15 seconds then the update starts, once it starts updating let go off the power buton and let it do its thing
Aug 11, 2008 | Televison & Video
Bought a iphone off the street,need to reset passcode
plug in phone and usb to pc .... hold down the home button and sleep button at same time for about 20-30 secs....you will see the usb plug and itunes sign come up...then it will prompt u to restore..
DONE STOLEN PHONE IS GOOD AGAIN
Dec 05, 2007 | Apple iPhone 3G
My Iphone wont turn on
listen to solution number 4..I tried it and it worked. Hold the power and home button until the apple logo pops up and your golden
Jul 20, 2007 | Apple iPhone Smartphone
My ipod nano wont do anything
umm im not sure if this will work but you could try holding menu center button untill the apple comes up (this may not work if ipod has not got any power to run)
Feb 22, 2007 | Apple iPod nano
COBY-PERSONAL & PORTABLE 1.8IN 2G VIDEO MP3 PLAYER - MP620-2GBLK Logo
Top COBY-PERSONAL & PORTABLE Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a COBY-PERSONAL & PORTABLE Audio Player and Recorder Expert? Answer questions, earn points and help others
