Question about World Marketing of America Kozy-World KWN191 Infra-Red Electric Wall Mounted Panel Heater
I need a thermostat control for a Spartan Electric model S2530T electric wall heater . It is 3000w 240 volt.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 83 Answers
Standard Appliance Parts Sacramento California can get you anything you need
Posted on Apr 07, 2015
Controlled by wall thermostat. Heater has two wires, both ends, white/black
so my question is this is electric heat? it sounds it so next question is it 120 or 240 volt. but you will have a black and a white wire from your electric panel feeding the line side of the thermostat then another wire loading from the t-stat to the electric heat. i hope this helps. Tom the electrician
Apr 04, 2015 | Heating & Cooling
I have a GE "SmartWater" Model #GE50M6A It only has 120 volts on the lower element. It is not heating water, but does have 240 volts to the upper element and, as I stated, 120v to the lower element.
1) Test elements,and if elements are good, replace both thermostats
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
2) Test across top two screws on upper thermostat for 240Volts.
If this test shows 240V, then no more voltage testing is needed.
http://waterheatertimer.org/How-water-heater-thermostats-work.html#electric
3) Add comment Feb 2013 and say where you are so far
Feb 09, 2013 | Water Heaters
Intertherm baseboard heater model 1580. Need thermostat
Home Depot carries I believe 2 different T-stats , wall mount, and unit mount. Try there. Or you will need to get it touch with the manufacturer. Also have info, 120 or 240 volt.
Mar 06, 2011 | QMark Portable Hydronic Electric Baseboard...
I TURNED ON POWER TO MY NEW ELECTRIC WATER 40gal MODEL # GEM402 AFTER FILLING WITH WATER. WATER WOULD NOT HEAT UP. CHECKED THREMOSTATS BOTH WERE PRSET AT 120 CHECKED POWER,BOTH HOT WIRES HAVE 124 VOLTS TO...
The controls of electric water heaters are designed so that at no time are both the top and bottom heating elements energized. Nearly all electric water heaters of this capacity in the US & Canada (other places, too) operate on 240 Volts.
When the water in the tank is below the set point of the thermostat (in your case - 120 degrees), the top heating element is expected to be on - (unless there is an issue with the top thermostat or limit switch). The top most control is the "high temperature limit". It is identified by the reset button on it. Make sure this isn't tripped by depressing the button. If it clicks - it was tripped and should start to make hot water at this point. If not tripped, you should check for the presence of 240 Volts between the heating element terminal screws. Do not measure from ground to a terminal screw and believe 120 Volts is "good". To make heat, you need 240 Volts - not 120 Volts measured across the terminals - not to ground. The amount of heat created running at 120 Volts is only 1/4 of what it will do at the correct voltage.
If you don't measure 240 Volts on the top element, check the bottom element in the same manner described for the top element.
If unable to measure 240 volts on any element, either there is a problem with the power source (blown fuse or circuit breaker), high temp limit switch, or thermostat(s).
If 240 Volts is present on either heating element, and water is not warm / hot in 30 minutes or so, a defective heating element is suspect. You can change controls without draining a tank, but replacing elements will require draining the tank first. Do not power the water heater without first filling it.
You can read a very detailed "how to" article about checking water heaters here.
I hope this helps - and good luck!
Nov 04, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Electric Hydronic Baseboard Heater, 240 Volt: WHEN I TURNED ON MY ELECTRIC BASEBOARD HEATER THER...
My PLF504 detonated this morning (11-25-2010). It worked fine for two years then BANG. Room was lit by flame coming from center (left to right) of unit. I wrote Marley asking them to honor the 10 year heater element warranty. Also, no burnt wires at thermostat connection, no dust bunnies on the fins. Source of fire was the fluid filled encapsulated heater core. Thank God, circuit breaker tripped and wall was tiled.
May 17, 2010 | Fahrenheat Electric Hydronic Baseboard...
Only comes on when thermost is pushed to click
Take the thermostat off the wall and touch the 2-wires togeather (only 28 vollts yhe body has enough resistance up to 52 volts) & if it comes on, then your thermostat is going bad and needs replacing!
Dec 19, 2009 | Fahrenheat Electric Convector Baseboard...
Connecting 240 volt singer baseboard heater
Need front grill for singer model WJA-12 wall heater Cat # 9756-A
single phase 60 HZ
240 volts 5.2 Amps
1250 Watts
Where can I find it?
Nov 28, 2007 | Heating & Cooling
World Marketing of America Kozy-World KWN191 Infra-Red Electric Wall Mounted Panel Heater Logo
169 people viewed this question
Top World Heating & Cooling Experts
don-ohio
Andrew Taylor
Andrew Taylor
Are you a World Heating and Cooling Expert? Answer questions, earn points and help others
