I have a Rockola 456 console. I was playing it yesterday. Without any problems! I switched it on today and it had an awful buzzing sound from the right bass speaker. Anyone got a solution please?
    New Friend:
  • 25 Answers
ONE WIRE NOT IS NOT SUPOST TO BE THER
Posted on Apr 05, 2015
  • 14 Answers
SOURCE: Fuzzy Speakers
Suggest that the speaker cone is damaged
Posted on May 08, 2007
cyrylthewolf
  • 143 Answers
SOURCE: Front right and left speakers problems
This is going to have to be a solution in the works...so don't rate until we have some kind of end-result.
Connect the speakers to a different device such as an MP3 player or a Nintendo DS. See if the speakers still cease to work. If they work just fine with a different device, then consider that it may not be the speakers...but a problem with the sound system in your PC.
Perhaps the sound configuration in Windows is disrupted. Perhaps the driver settings for your soundcard in your PC are corrupted. (A complete reinstallation of Windows with a fresh installation of the sound drivers would probably prove this theory right or wrong.)
Perhaps there is a problem with the FRONT CHANNEL hole on the sound system on the rear of your PC. You could check that by plugging the REAR channel of the speakers into the FRONT channel on the PC.
And lastly...there could be a break or a short in the cable of the speakers. You could always test another set of speakers with each sound channel and see if that might be the possible issue.
If the sound card in the PC turns out to be the problem, then install a different sound card. If the soundcard in your PC is currently the onboard one, then disable it in the BIOS before installing the new card.
Let us hear the results before we do any rating. Unless of course you're able to fix it with the data given. :)
Cyryl
Posted on Dec 08, 2007
SOURCE: Speakers Buzzing Whilst Playing Music
Those speakers are not magnetically shielded, shielded speakers resist buzzing caused by monitors. Just about any decent computer speakers on the market today are shielded, and will most likely state that on the box. Apart from moving the speakers farther away from the monitor, there is little you can do to avoid this interference.
Posted on Aug 30, 2008
SOURCE: Speakers stop playing when bass is turned up
how do i lower the bass on my speakers. what controls to i use
Posted on Feb 09, 2009
  • 5603 Answers
SOURCE: Right speaker on the logitech z2300 sound system wont play.
Make sure the PAN control is centered in your mixer control panel.
Posted on Sep 05, 2009
Testimonial: "that wasnt the problem... called support but it turned out i forgot to check the jack in the back of the computer if it was securely fastened it wasnt"
Rockola jukebox keypad doesnt work
If the whole panel is out it sounds like a missing or bad ribbon cable. start there and tell us what happens.
Nov 21, 2013 | Neonetics Rockola Jukebox Neon Clock
I have a Rockola jukebox model 456.It worked well overall,but now it will not reject the records after play?What should I be checking?
You might want to try this forum:http://www.antiqueradios.com/forums/viewtopic.php?t=104054&highlight=&sid=231c6e27ef15ccbe83c7a412bb9c8b86 The part in the post about lubrication is important but might not be the solution to your problem. I would suggest joining and posting as there is probably other owners who are members.
Mar 25, 2010 | Music
Loaded game = loud buzzing
After removing the casing, all that need to be done was loosen (yes, loosen) a screw on the inner frame about a quarter turn. This allowed a little movement to the frame and stopped the buzzing.
Jul 22, 2009 | Nintendo Wii Console
Wii fit
I know this might sound obvious but have you got it inserted in the console the right way up?
May 17, 2008 | Nintendo Wii Console
sounds like interferance try moving the speakers around maybe away from the monitor and try turning off any thing elec around your pc to find out maybe what is causing this
Dec 01, 2007 | Philips MMS 460 Computer Speakers
91 people viewed this question
 Grubhead
Grubhead
