Motor rotor not spinning - Washing Machines
    Top Expert:
  • Washing Mach... Master
  • 46,177 Answers
Make and model would help us help you . suspect the motor or the controller
Posted on Apr 05, 2015
Why doesn't the machine wash?
Firstly check power supply machine is getting or not. If your machine is not spinning the rotor shaft has been Jammed or the Machine Motor coil is burnt away due to this machine motor rotor is not spinning...... Check the Spinner is it jam, if it doesnt work call electrician to check the motor
Oct 30, 2016 | Washing Machines
GW712 will not agitate or spin, 1st and 7th lights lit, beeping every second.
Your Error code is 130
130. (10000010) Phase 1 to 6 Single Rotor Position Sensor Error
The Motor Controller has found an error in the pattern received from the Rotor
Position Sensor. Likely causes of this fault are a bad connection on the harness
between the Rotor Position Sensor and the Motor Controller, or a faulty Rotor
Position Sensor.
Primary Source: Wiring.
Action:
1) Check for corrosion on the edge connector of the Rotor Position Sensor and
the Motor Controller module connector.
2) Check the contacts on the rotor positional sensor end of the hall harness to
see if any have been damaged. (Each set of contacts in the socket has two
wipers. If the distance between these wipers varies between different
contacts, replace the rotor positional sensor harness).
Secondary Source: Rotor Position Sensor.
Action:
Check the Rotor Position Sensor with an R.P.S. tester. Replace if faulty.
Tertiary Source: Motor Controller module.
Action:
Replace Motor Controller module.
Apr 24, 2014 | Fisher and Paykel Washing Machines
Won't fill, spin, rinse, drain
130. (10000010) Single Rotor Position Sensor Error
The Motor Control Module has found an error in the pattern received from the Rotor
Position Sensor. Likely causes of this fault are a bad connection on the harness between
the Rotor Position Sensor and the Motor Control Module, or a faulty Rotor Position Sensor.
Action: Check for corrosion on the RAST connector of the Rotor Position
Sensor and the Motor Control Module connector.
Action: Check the Rotor Position Sensor with an R.P.S. tester. Replace if
faulty.
Tertiary Source: Motor Control Module.
Action: Replace Motor Control Module.
Quaternary Source: Rotor
Action: Ensure the correct rotor for this phase of machine has been fitted
May 24, 2013 | Fisher and Paykel GWL11 Top Load Washer
My fisher and paykel smartdrive wont agitate or spin but it pumps the water out it , when i spin the drum there is a bumping sound. can i get into the drum part to see if anything has gotten inside?
That is fault code 130
130.(10000010) Single Rotor Position Sensor Error
faulty.
Jul 31, 2012 | Fisher and Paykel Fisher & Paykel Washer
Chopper spins clockwise . How do I fix it
It is spinning around because one of the rotors is not spinning at full speed. This happens when you bump a spinning rotor against something. Determine which one it is by observation or logic (i.e, the one that turns clockwise will produce counterclockwise torque, which is to be balanced by the other rotor spinning counter clockwise. So the counter clockwise spinning rotor is slow) Tighten the screw that holds that rotor that is spinning more slowly. Use the screwdriver that came with the spare parts.
Dec 15, 2011 | JCPenney Gyropter RC Helicopter
Battery is good but when I turn it on it just clicks won't start,maybe after 20 times it starts
Without hearing the sound it makes - it's kind of hard to diagnose.
The engine starting process consists of turning the key to start, the starter motor's rotor moving forward to engage the engine's flywheel, and then the starter motor 's "rotor" spinning until you move the key from "start" to "run". You can hear the starter motor spinning - but one usually can't hear the rotor moving forward to engage the flywheel. As a result, you hear the odd spinning sound - which is the starter rotor spinning. The engine never actually turns over because the rotor never engages the fly wheel. If this is the case, then it is very likely that your starter needs to be checked and / or replaced.
Nov 09, 2011 | 1994 Buick LeSabre
I was using my Craftsman 12 Gal 5.0 160 HP Wet/Dry Vac, dry vacuuming, and it just stopped working. I did check the receptacles but that was not the issue.
Good day!
Try to see the motor and the carbon brush that connected to it..
This are the step on how to open or remove the cover of the vacuum to reveal the motor.
  1. Take off the top panel.
  2. Loosening all screws that you will see inside that top panel.
  3. After that, the top cover of the vacuum release and the image of the motor reveal.
  4. Now try to look at the motor and remove it to the unit by unscrewing it.
  5. Next, try to spin it manually using your 2 fingers and hold the plate then spin it.If the plate is hard to spin,the motor is need to re-align.
  6. To re-align the motor you have to loosen the screws at the 4 corners then release the rotor then back again.
  7. After that,clean the bushing of motor and the rotor and apply the motor oil for lubrication.Then re-install it and tighten the screws on the 4 corners while you re-align the rotor.
  8. Use a rubber mallet to align the rotor,hit the body of the motor while you tighten the 4 corners screws.
  9. After that spin the plate again to test the alignment,if the plate spin it smoothly.the alignment is OK.
  10. After that you have to test the resistance of the motor to make sure that the carbon brush is contact to the armature of the rotor.Use a multimeter (range in ohms) then point the test probe directly to the carbon brush wire.It should have not more than 25 ohms depends on the horse power of the motor.
  11. When the reading is open the contact of the carbon brush is reaching the armature of the rotor.Replace the carbon brush.
If you accomplish all of the steps above and the you found a defective parts.Test the vacuum by powering it ON.
Thank you very much and wish you luck.
May 02, 2011 | Craftsman 17925 Canister Wet/Dry Vacuum
The tail rotor will not work. The tiny motor is not working so it does not spin the rotor. What can I do???
doubld blade rotor there is no need for a rear/tail rotor, on the remote are 2 buttons they will control Left/Right spin , adjust so that it does not spin around
Feb 05, 2011 | JCPenney Gyropter RC Helicopter
Tail rotar
Yes - it matters for any heli.
The main rotor creates drag which makes the heli want to spin - the tail rotor pulls the heli in the opposite direction to compensate and keep it steady.
Look at the angle of the main rotor in regard to the direction it turns - you'll see how it 'pulls' upward. The tail rotor will need to 'pull' sideways, according to whichever direction the tail rotor is spinning.
I'm assuming you're reattaching a tail rotor or rewiring a motor?
Nov 19, 2008 | RC Airwolf Rc Electric Helicopter Body...
Washing Machines Logo
Top Washing Machines Experts
