Question about Ovens
It won't heat over 280 degrees.. What is the problem?
    Top Expert:
  • Ovens Master
  • 45,382 Answers
Thermostat probably bad .
Posted on Apr 05, 2015
Oven made pop noise now won t heat
It sounds like the control board blew out. I have had a couple of these just blow like that lately. The bake and broil wont work. . Check for any bad wiring but the control board is most likely the culprit.
Feb 20, 2014 | Ovens
Adjust thermostat
A thermostat only cuts the heating off when the temperature it is set to is reached while the heating is on. If the heating is set to off then the thermostat will do nothing.
Generally you want to think about when you want your heating to come one and off by using the timer and then the thermostat is just used to ensure that you don't waste energy by exceeding the maximum comfortable temperature.
Hope this helps a little.
Nov 22, 2013 | Ovens
New oven won't heat
1.Check sensor connection. 2.Measure sensor resistance (1080 Ohms at 70 degrees F. Add 2 Ohms per degree F). 3.If resistance is not valid, replace sensor. 4.If sensor resistance and connections are good, then check for welded-closed relays on the control.
Here is the sensor to order if it is bad.
Nov 28, 2012 | Ovens
Hotpoint oven won't heat above 250 degrees broiler works fine as well as the stove top
either its the oven sensor rod located at the top of the ovens cavity,or your bake element could be getting a hot spot which is when it gets a discolored spot in the element and can no longer pass sufficient current to heat the oven past 250 degrees
Jul 28, 2012 | Hotpoint Ovens
Oven won't heat up past 200 degrees
The temperature sensor needs to be checked.It must not working properly. thanks.
Oct 11, 2011 | GE JTP45 Electric Double Oven
I set the oven at 350 degrees and after 3 hours it has only reached 185 and won't go any higher. The oven is approx. 8 years old.
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Jul 25, 2011 | Ovens
The temp. on oven is about 70 degrees off, preheated at 350 , only about 280 in oven. says it might be a sensor, or thermostat, dont know waht this model has, and could it be the sensor, model...
kenmore expert here....
Welcome to fixya
Hello
I have a solution for this
Press Ok, Accept or replay so we may get started
Your pre-solution is coming up shortly
PLEASE REPLY OR LEAVE COMMENT TO CONFIRM YOU RECEIVED THIS EMAIL
My name is Bruce
Jan 18, 2011 | Kenmore Ovens
My amana oven will not heat up. Thought it was
More than likely your going to need a new thermostat or control. Likely when the element burned up it shorted out the control. Check that everything else is working good like the broil element and the top burners. If so there is only two other option the control for baking or the wiring from the control to the element you just replaced.
Jan 23, 2010 | Ovens
Ovens Logo
62 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
