Question about Russell Hobbs 18036 Breadmaker Fresh Bread In Minutes
Machine making terrible knocking noise when in use?!
    Prodigy:
    An expert who has answered 500 questions.
  • 613 Answers
Sometimes this is caused by not having enough liquid in the recipe.
All flours are not made equal. Make sure you ladle the flour into the measuring cup with a spoon , then level off with the back of a knife. Scooping a measure into flour, impacts the flour and you actually get more flour than you need. If this does not help, try adding more liquid a tablespoon at a time and see if this works. good luck.
Posted on May 02, 2015
My Panasonic washer,error code E03 appeared. When the drum turns it makes a terrible noise, like metal knocking on metal. Is this possibly due to the filter or something more serious?
If you turn the drum and hear metal knocking sound it's most likely to be either a broken drum support or a collapsed bearing
Jun 13, 2016 | Washing Machines
Brothers Electric Sewing Machine Knocking noise
First thing, install a brand new needle. A bent/damaged needle will frequently make noises.
Second, if it is mechanical machine (not computerized), it most likely needs a good cleaning and oiling.
Will not zigzag or decorative stitches New to these newer plastic style...
If it continues to make a knocking noise, it could have a bent part or be out of time, in which case you should contact a service repair shop.
Apr 13, 2016 | Sewing Machines
Making loud noise like machine gun
Install a brand-new needle? Frequently, a damaged or bent needle will make a terrible noise.
Mar 20, 2016 | Brother PE770 Embroidery Machine w/ USB...
Kenmore 29422801 knocks when spinning
It is so common that the washing machine can make terrible noise in many ways and is a common fault. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that machine is vibrating when it is running then the motor /drum suspension has to be inspected. Since these fittings are located on the underside of the machine it is important that you look for the noise with a good inspection lamp. Manually turn the motor and drum and listen for the noise, if so the motor bearings, the drum agitator shaft and fittings must be checked. Also the suspensions which include the shock absorbers and springs, the body clamps must be checked to be in correct alignment and not changed in position. Tightening of the mounting is also very important. Finally in most cases a drop of OIL or smear of grease on the moving parts cane solve most issues.
Check this link :
http://www.espares.co.uk/advice/washing-machines/a/7/1210/wobbly-washing-machine-or-tumble-dryer.html
For replacement of bearings check for tips on this visual link: http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html
Sep 27, 2012 | Kenmore Washing Machines
Loud Noise
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
879dgyj
Dec 18, 2008 | LG DLE5932W Electric Dryer
Noise from washing machine
heatman101
fddfs
Oct 25, 2008 | Whirlpool AWG329 Front Load Washer/Dryer
Terrible noise while agitating
THAT COULD BE A BROKEN or LOOSE SCREW THAT HOLDS THE INNER TUB in the Center mast, hope this helps AJ
Oct 25, 2007 | GE WHRE5260E Top Load Washer
Russell Hobbs 18036 Breadmaker Fresh Bread In Minutes Logo
129 people viewed this question
Top Russell Hobbs Kitchen Appliances - Others Experts
Jerry Greenberg
Jerry Greenberg
ashburton
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Russell Hobbs Kitchen Appliances - Other Expert? Answer questions, earn points and help others
