Question about Sony MegaStorage CDP-CX455 400-Disc CD Changer
Thank you Steve.. I think it was caused by a couple CDs out of their slots jamming carousel movement. Does this cause crazy behavior with the unit as well?
It doesn't want to power off, have to unplug
  • 195 Answers
Yes it does,
Posted on Jan 06, 2017
Kodak 140 slide carousel trays jam
The 140 tray with older slides and an older projector is a gamble with slide jams every time!! Slides have a natural curve that gets bigger over time. In addition, as slides age, the corners will begin to de-laminate (aka: "dog-eared" slide). Because the slide slot in a 140-tray is SO NARROW, the least little deformation of the slide from normal will cause the slides not to drop. My recommendation, given the age of the projector, trays and slides, is to get rid of those 140 trays and stick with 80-slide trays. Good Luck !! Jim
Sep 16, 2013 | Kodak Carousel 4400 Slide Projector
How to remove a Croussel from Ektagraphic AF1
First of all, make sure the LOCKING RING is in position on the tray & locked! This will prevent all the slides from falling out when you remove the tray. Next, place a quarter (or a dime or a penny) in the SLOT in the HUB of the projector. Turn the coin to release the Emergency Latch Release and lift the tray off. Flip the tray upside down. Remove the jammed slide from the optical gate of the projector (inspect it for damage - "dog-eared" slide corners cause this kind of jam) and re-insert it in the slot of the tray from the underside (now facing you). Now rotate the tray until the pointing arrow and the notch on the bottom of the tray align. At this point the tray should be back in the "Zero" position and can be re-installed on the projector. I have attached copies of Kodak instructions for this, as well. Good Luck !! Jim4d786888-c152-4bd3-b086-29e6f8e29e37.jpg409ae3e8-80fd-44c8-820b-23fd94def009.jpg
Mar 14, 2013 | Kodak A Ektagraphic 35mm 140 Slides Rotary...
Tub shakes crazy when spinning. Whole machine vibrates
A couple of things may be going on. One is that the load may be quite heavy and is sitting to one side of the tub so to speak, causing the unit to be out of balance. The other is that the leveler feet may be out of adjustment which would require re-leveling. Your "shaking like crazy" description makes me think the leveling issue is the likely problem. Aside from the bad behavior, either cause can be hard on bearings.........and sanity. Good luck.
Feb 27, 2011 | Washing Machines
Our dell powervault 122t shows error code A0
Error Code A0 - Error occurred during carousel movement (Position Not Found). Could be caused by a missing or misaligned cartridge carrier, or an obstruction, or unexpected cartridge in either the carousel path or Import/Export slot.
Remove the power cable and SCSI cables then try open the top cover. Check and see if there are any tape blocking or obstructing the movement. Sometimes it works sometimes it doesnt. I have 5 of these devices, few of them were replaced as its not working anymore due to these codes and as they are pretty obsolete, its not worth to repair them anymore.
Feb 03, 2011 | Dell PowerVault 122T LTO (pv122tlto)...
IBM Autoloader 36232sx error code A027 & A060
A0= Error occurred during carousel movement (position not found). Could be caused by a carousel motor power issue, a missing or misaligned cartridge carrier, an obstruction, or an unexpected cartridge in the carousel path.
I also advise you to update the FW of the loader.
Are you having tapes get "Stuck" in the unit?
Feb 01, 2010 | IBM Computers & Internet
I have a Wurlitzer 1015 OMT 50-Disc model. Is it possible to upgrade it to handle 100 discs? Thank you. Steve W.
It is possible.
If it is a 100 cd carousel then it is a simple computer setting.
If it is a 50 cd carousel you need a credit computer able to recognise 100 selections, a 100 slot carousel and a latch bracket for a 100 cd carousel.
I have never done it but it is definitely possible.
Jan 05, 2010 | Wurlitzer Jukebox CD Player
JBL 6 CD AM/FM Cassette Audio has CDs stuck inside and won't play or eject them. How can I get them out?
I've had this happen before with car stereo's uh i just normally unscrew the screws out of the top of the player to where you can get to the tray or slot for the cds and force the cd tray or the cd itself out but be careful and not break the cd this might work it usually does for me
Aug 17, 2009 | JBL MCDC100 6-Disc CD Changer
CD player does not rotate
Hi there.
There could be a couple of reasons. I doubt very much that it is due to the lens. First thought is that it is probably the locking mechanism. If you look at the cd loading mechanism, there is a small plate with a locking tab that moves into place to hold the carousel still when the unit is loading a cd. This plate slides along the bottom of the unit between the cd loader and the carousel.
Secondly, it could be that the carousel is jammed on the rotating platter that it moves on. A couple of screws and it should come out - be carefull not to bend anything!
Thirdly, check the stepper motor that turns it - but I doubt this is the problem either as you said you couldn't turn it by hand either. You will need to remove the carousel to do this.
Good Luck !
Feb 10, 2009 | Sony CDP-CX235 200-Disc CD Changer
Wurlitzer 1015 OMT 100CD
I asked a Wurlitzer engineer about this problem and he simply said, "Bend it a bit."
Sounds horrible but there is no genuine adjustment. But before doing that, try moving the carousel lock latch (at the 5 oclock position). This is what locks the carousel and determines its position when the correct CD number is reached. If you could ****** or advance it a little it might work.
Apr 05, 2008 | Wurlitzer Jukebox 1015 One More Time...
Denon m50
You can probably fix it yourself but you may need some parts. Here's Denon's link that'll take you to the next step
Nov 24, 2006 | Denon D-M50S CD Shelf System
Sony MegaStorage CDP-CX455 400-Disc CD Changer Logo
83 people viewed this question
Top Sony Audio Players & Recorders Experts
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
