Question about Home
Plaza sh How to use temperature control
Cannot adjust temperature
    Top Expert:
  • 44,351 Answers
Photo would help also .
Posted on Apr 05, 2015
HOW DO I ADJUST REFRIGERATOR TEMPERATURE
    1. Refrigerator Adjusting Temperature Controls. At initial startup both fresh food and freezer controls should be set at the normal setting or mid point settings. Temperature controls can be found in the back of the fresh food compartment, near the top of the fresh food compartment, or on the dispenser panel.
      Refrigerator Adjusting Temperature Controls - GE Appliances
      products.geappliances.com/appliance/gea-support-search-content?contentId...
    Feedback
  1. Refrigerator Temperature Control Dial - What Do The ...
    removeandreplace.com/.../refrigerator-temperature-control-dial-what-do-...
    Mar 4, 2015 - The more food you have in your refrigerator, the more stable thetemperature will be. Set the thermostat to the middle of its range and leave it for ...
Nov 28, 2015 | Refrigerators
Where is the reset button on a hottpoint side by side refrigerator.
Self Diagnostics
To enter Self Diagnostic mode, both temperature control panel displays must be illuminated. A display can be illuminated by pressing an adjacent temperature adjustment button. When both displays are illuminated, set the freezer and refrigerator temperature settings to 5. Simultaneously press and hold all 4 temperature adjustment buttons for approximately 3 seconds. A flashing 0 in the refrigerator and freezer displays will indicate that the refrigerator is in Self Diagnostic mode.
To perform a self diagnostic test, locate the test in Table 2, Diagnostic Tests.
For temperature control panels with single-digit displays, the COLDER temperature adjustment button will increment the numbers up and the WARMER temperature adjustment button will increment the numbers down. Use the freezer temperature adjustment buttons to enter the test code number in the freezer display. Use the refrigerator temperature adjustment buttons to enter the test code number in the refrigerator display. When a test code has been entered, the displays will flash to confirm the test. Press the HOLD button for 3 seconds to begin the test.
For temperature control panels with 3-digit displays, the COLDER temperature adjustment button will increment the numbers down and the WARMER temperature adjustment button will increment the numbers up. Use the freezer temperature adjustment buttons to enter the test code number in the freezer display. Use the refrigerator temperature adjustment buttons to enter the test code number in the refrigerator display. When a test code has been entered, the displays will flash to confirm the test code. Press any button other than a temperature adjust button to begin the test.
When testing has been completed, do one of the following things:
• Enter code 1 5 to completely reset the system.
• Enter code 1 6 to exit diagnostic mode. The temperature control panel is reset automatically.
• Unplug the refrigerator for at least 10 seconds. Test mode will terminate when the refrigerator is plugged back in.
Test mode will terminate automatically after 15 minutes of inactivity.
Read more: http://appliancejunk.com/forums/index.php?topic=10408.0#ixzz3VIqUINVz
Feb 27, 2015 | Hotpoint HSS25GFT 25.0 Cu. Ft....
How do I adjust freezer temperature on Electrolux refrigerator?
Hello friend, thanks for your inquiry!
I see that you would like to know how to adjust the temperature within your Electrolux refrigerator, EI23CS55GS1. To adjust the temperature you would use the control panel on the front of the freezer door. There should be a "-"or "+" near the freezer temperature control and that is how you would adjust the temperature within your refrigerator. Be sure to check and make sure that the control lock is not on or you will not be able to adjust the temperature. Any adjustments made within the refrigerator need at least 24 hours to stabilize. I hope this is has been helpful. -Matt
Oct 18, 2014 | Electrolux Refrigerators
Too much hot water, how to adjust water temperature
1) Copy following links:
http://waterheatertimer.org/How-to-adjust-temperature-on-water-heater.html
http://waterheatertimer.org/How-to-test-water-heater-element.html
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
2) if you have electric water heater, and too much hot water, then thermostat may be bad, or element is shorted and needs replacement. Test elements first, and if they're ok then replace both thermostats.
Jan 22, 2013 | Bradford White M240s6ds-1ncww 40 Gallon...
What type of engine oil does a Peugeot 306 (1.6 petrol engine) need?
Engine oil specifications for Peugeot 306 1.6 petrol engine:
1. SAE 5W-40, API SH or SG, for temperatures between -30 Celsius deg. and +40 Celsius deg.
2. SAE 10W-40, API SH or SG, for temperatures between -15 Celsius deg. and +40 Celsius deg.
3. SAE 15W-40, API SH or SG, for temperatures between -10 Celsius deg. and +40 Celsius deg.
4. SAE 15W-50, API SH or SG, for temperatures between -10 Celsius deg. and +50 Celsius deg.
5. SAE 20W-50, API SH or SG, for temperatures between -5 Celsius deg. and +50 Celsius deg.
Jan 02, 2011 | Peugeot 405 Cars & Trucks
I sthere a way to calibrate my oven temperature? It is off by about 35 degrees. Temperature is lower than display.
Sorry to read about your problem, I hope this helps you out.
To Adjust the Oven Temperature (do not use Bake or Broil while adjusting the oven temperature): note: Your oven control was factory set in the (Fahrenheit) °F Temperature Display Mode. To change for (Celsius) °C, see page 15.
1. Press & hold the BAKE key pad and release after the display shows the factory temperature setting of 00. note: If the oven temperature has been previously adjusted from the factory setting, the current temperature adjusted value will appear in the display instead.
2. You may increase the oven temperature in 5°F (1°C) increments with each press of the uP arroW pad to a maximum oven adjustment of +35°F (+18°C). You may also adjust the oven temperature downward in 5°F (1°C) increments with each press of the doWn arroW pad (total range of -35°F to +35°F (-18°C to +18°C).
3. If you do not want to keep the display adjustment, press the clear oFF pad before the oven control beeps. This will cancel the temperature adjustment procedure. To start this procedure over again begin with step 1 above OR;
4. If you want to keep the adjustment, wait until the oven control beeps once.
5. The oven temperature adjustment has be accepted by the oven control and the display will return to the time of day.
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 24, 2010 | Frigidaire FEB24S2AB Single Oven
The water is too cold in our newton water cooler. Is there an adjustment to make it warmer?
Yes there is an adjustment. Your water cooler should have a temperature control The enclosed adjustable thermostat is factory presetand should require no adjustment other than for altitude requirements. The temperature control should also be easily accessible.
Without specific model information difficult to identify where the temperature control may be located on your unit.
You might vist their website to identify your model. A search by model number may find more useful information on accessing and adjusting the temperature control.
Trust this is helpful.
Dec 17, 2010 | Computers & Internet
Oil type
Read your owner's manual. If not.
Proper engine oil selection is very important for optimum engine performance, efficiency and durability. A new service API classification category has been adopted. The designation for this category is "SH". The "SH" category is intended to replace the "SG"category and provide improved performance in: deposit control, oil oxidation, wear, rust, and corrosion protection. "SH" category oils may be used in applications where "SG" and earlier categories are recommended. The appropriate SAE viscosity grade depends on existing climatic conditions. Refer to the temperature chart below when selecting viscosity grades for expected temperature ranges. Brief variations in temperature are no cause for alarm. Lubricants that do not list both an SAE grade number and an API service classification on the container should not be used. 7897780.jpg
Jun 20, 2009 | 2001 Hyundai Tiburon
Kenmore range oven will not hold temperature
You're glow bar ignitor is on its way out. I had this exact problem and swapped mine out with its identical sibling that runs the broiler element. Problem fixed.
Jun 22, 2008 | Tappan TGF320 Gas Kitchen Range
Home Logo
142 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
