Question about Home
Hosw to use controls
Cannot control temperature
    Top Expert:
  • Home Master
  • 45,291 Answers
Sorry but without make and model what are we going to search for .
Posted on Apr 05, 2015
Having problems with climate control. Temp setting does not come back on to the last setting it always comes back on at 75. Also when pushing the front defrost it doesn't blow air.
You may want to have it check for DTC'S diagnostic trouble codes . A code may point to the problem , these HVAC systems are very complex .
DTC B0248, B0268, B0408, B0418, B0428, or B3531
The HVAC door actuator is an electronic motor with a feedback potentiometer. The HVAC control module supplies power and ground to the actuator. The HVAC control module controls the direction of the actuator by changing the polarity of the control circuit. When the actuator reaches the desired position, voltage is removed from the control circuit. The HVAC control module determines the current position of the actuator by monitoring the feedback voltage of the door position signal circuit. The feedback potentiometer position is a function of the actuator position.
• Air flow control 3 circuit refers to the front mode actuator
• Air flow control 7 circuit refers to the recirc actuator.
• Temperature control 1 circuit refers to the driver air temperature actuator
• Temperature control 2 circuit refers to the passenger air temperature actuator
• Temperature control 3 circuit refers to the rear air temperature actuator
• Air flow control 10 circuit refers to the rear mode actuator
DTC Descriptors
This diagnostic procedure supports the following DTCs:
• DTC B0248 Air Flow Control 3 Circuit
• DTC B0268 Air Flow Control 7 Circuit
• DTC B0408 Temperature Control 1 Circuit
• DTC B0418 Temperature Control 2 Circuit
• DTC B0428 Temperature Control 3 Circuit
• DTC B3531 Air Flow Control 10 Circuit
Your having air flow issues and temp. control !
DTC B0413, B0423, B0433, B3761, B3773, or B3782
• DTC B0413 Temperature Control 1 Feedback Circuit
• DTC B0423 Temperature Control 2 Feedback Circuit
• DTC B0433 Temperature Control 3 Feedback Circuit
• DTC B3761 Air Flow Control 3 Feedback Circuit
• DTC B3773 Air Flow Control 7 Feedback Circuit
• DTC B3782 Air Flow Control 10 Feedback Circuit
Do you know what a scan tool is ?
Install a scan tool.
Turn ON the ignition, with the engine OFF.
With a scan tool, command the appropriate actuator in both directions.
Does the actual parameter of the appropriate actuator change?
Jan 10, 2017 | 2005 Cadillac STS
No heat. New thermastat, heater core flushed, good circulation. Has a rear heater.
Does blower motor work , air blowing out of ducts ?
Temperature blending is varied by the air temperature control door, which regulates the amount of air that flows through and/or around the heater core (18476) , where it is then mixed and distributed.
Movement of the control knob from COOL (Blue) to WARM (Red) causes a corresponding movement on the air temperature control door and determines the temperature that the system will maintain.
Temperature Control
The temperature control operates in the following manner:
  • Temperature control of the heater system is determined by the position of the temperature control knob (between COOL-BLUE and WARM-RED) of the heater control .
  • This control knob is connected to a potentiometer mounted in the heater control . This potentiometer is electrically connected to the electric blend door actuator that operates the A/C air temperature control door.
Feb 25, 2016 | 1996 Ford Windstar
With deluxe Electronic Temperature Control Freezer control panel shows "OF" and I can't restart the freezer
Search Results
    Freezer electronic temperature control manual... ' Sears ...
    www.searspartsdirect.com > Ask an Expert
    Jul 5, 2012 - I have a Kenmore elite freezer with electronic temperature control. ...my freezer was delivered yesterday, the control panel is stuck on of, ... an electronic control on front. the display is showing hi temp and door ajar. also an l in ...
    Control Panel is not working right - Samsung
    www.samsung.com/sa_en/support/skp/faq/239315
    Samsung ElectronicsSep 3, 2015 - In case of wrong temperature display, possibly door opens so inside ... If the control panel is still not lit up after you plug the refrigerator back in, it may ... When initial installation, Temperature will show current temperature for a ... When the refrigerator/ freezer reach the set temperature, the blinking will stop.
    Adjusting Side-bySide Refrigerator Temp Controls - Actual ...
    ? 3:50
    https://www.youtube.com/watch?v=DFzTGKVo79g
    Jun 27, 2010 - Uploaded by GE Appliances
    CAN I TURN OFF THE DIGITAL CONTROL ON FREEZER AREA ONLY. ... I need to know How to reset this kind of refigirator, same front panel ... When you try to set the actual temperature, does your control show your new ...
    Electronic Temperature Controls - ManualsLib
Feb 03, 2016 | Freezers
Where is a air temperature control sensor in a 2004 GMC Canyon located at
There is none on your vehicle , temperature control is by a cable .There is a evaporator temperature sensor , this is used to keep the evaporator from freezing up !
Air Temperature Control The air temperature control regulates the HVAC system air temperature in any mode. An air temperature control cable mechanically links the air temperature control to the air temperature door.
Evaporator Temperature Sensor The evaporator temperature sensor will not allow an A/C request to the body control module (BCM) at temperatures less than 0°C (32°F).
Sep 14, 2015 | GMC Cars & Trucks
What is an ICP - RCC - Speedometer fuse for on a 1997 ford taurus dohc ICP - RCC?
Hey Brian ,
ICP - Integrated control panel
RCC - Remote Climate Control Module
Integrated Control Panel-Electronic Automatic Temperature Control
Control Assembly The Taurus, Sable vehicles group together the following systems into a single integrated control panel:
  • AM/FM stereo radio
  • clock
  • rear window defroster switch
  • electronic automatic temperature control (EATC)
  • full-logic cassette tape player
  • compact disc player control (optional)
The remote climate control module is mounted to the A/C evaporator housing behind the integrated control panel. The integrated control panel is connected to the remote climate control module with a dedicated two-wire communication link. The integrated control panel EATC features:
  • a vacuum fluorescent display (VFD) for displaying set temperature, ambient temperature, function and diagnostic trouble codes (DTCs).
  • electro-luminescent backlighting for all buttons and graphics.
  • function override buttons.
  • temperature control and blower speed rocker switches.
Jun 08, 2015 | 1997 Ford Taurus
Where is the air and heat blend motor on a 2000 dodge dakota?
Hi Sharon, I'm glad to help. Your 2000 year doesn't have a motor for the temp door. It operated by a cable running from the control head to the temp door and you work it manually. If you can't control the temperature from hot to cold, sometimes the cable come off or breaks. Here how you can see the cable to see if its working. Remove the radio and right behind it you will see the cable attached to the door, while watching it move the temp lever from hot to cold and watch it. If it is moving then its most likely out of ajustment. If it is not moving, then you'll need a new cable. Just in case it is moving, I'm attaching the instruction on how to adjust it below. Hope this helps and have an awesome day Sharon!
TEMPERATURE CONTROL CABLE
Any time the heater-A/C control or the temperature control cable are removed and/or replaced, the following procedure must be performed.
  1. The temperature control cable housing and core must be installed at both the heater-A/C control and the heater-A/C housing ends, and the heater-A/C control must be installed in the instrument panel. See Heater-A/C Control and Temperature Control Cable in the Removal and Installation section of this group for the procedures.
  2. Rotate the temperature control knob on the heater-A/C control so that the knob pointer is in the 12 o'clock position.
  3. Pull the temperature control knob straight out from the heater-A/C control base until the perimeter of the knob (not the knob pointer) protrudes about 6 millimeters (0.25 inch) from the face of the control base.
  4. Rotate the temperature control knob to the 1 o'clock position. Push in on the knob slightly and continue rotating the knob to its full clockwise stop. The knob pointer should be aimed at a position about 8 millimeters (0.315 inch) beyond the end of the graduated red strobe temperature control graphic on the face of the heater-A/C control base. If the knob is not pointed to the correct position, go back to Step 2 and repeat the adjustment procedure.
  5. Rotate the temperature control knob counterclockwise until the knob pointer is in the 12 o'clock position again.
  6. Push the temperature control knob straight in towards the heater-A/C control base until the perimeter of the knob (not the knob pointer) is flush with the face of the heater-A/C control base.
  7. Rotate the knob to its full clockwise stop again. The knob pointer should be aimed at the end of the graduated red strobe temperature control graphic on the face of the heater-A/C control base. If OK, go to Step 8. If not OK, go back to Step 2.
  8. Rotate the knob to its full counterclockwise stop and release the knob. If the knob springs back from the counterclockwise stop, the self-adjuster clip that secures the temperature control cable to the blend-air door lever is improperly installed. See Temperature Control Cable in the Removal and Installation section of this group for the procedures. If the knob does not spring back, the temperature control cable adjustment is complete.
May 14, 2014 | Dodge Dakota Cars & Trucks
Cant find temperature control knob
Good Afternoon Friend,
I understand that you are looking for the temperature control knob on your Frigidaire freezer, model# FFU2064DW. The temperature control is located inside your freezer on upright models, and on the left outside wall on chest models. The temperature is factory preset to provide satisfactory food storage temperatures. However, the temperature control is adjustable to provide a range of temperatures for your personal satisfaction. However, the temperature control is adjustable to provide a range of temperatures for your personal satisfaction. Hope this is helpful.
-Best Regards-
WP
May 09, 2014 | Frigidaire 20.3 cu. ft. / 575 liter...
Freezer alarm goes off even though the freezer temperature is below -20C. The compressor runs continuously.
From the sound of it the temperature control is bad. I'm only stating this because if the cold control (temperature control) isn't converting the temperature to electrical signal properly, the machine will constantly run trying to reach the set temperature the cold control is set at. Question, is there a digital display showing the temperature or did you use a meter or thermometer to check it, and how is the temperature set, by a digital control or a dial, rheostat or any other type of manual control?
Jun 21, 2012 | Refrigerators
Temperature does not go below 59 deg. refrigerator side.
Auto Damper models, The Auto Damper model refrigerator has
two controls and both have capillary sensing.
The Auto Damper controls the fresh
food temperature and the Freezer Temperature
Control guides the freezer temperature.
The fresh food compartment temperature
is maintained by a damper assembly located
at the back of the temperature control
housing. Changes in air temperature
cause the damper door to open and close.
A control rod and gear connect the fresh
food control knob to the damper control.
Turning the fresh food control knob to the
COLDEST position increases the flow of
freezer air into the fresh food section. The
freezer compartment temperature control
warms at a faster rate and cools at a slower
rate, increasing the compressor run time
necessary to maintain a satisfied freezer
Turning the fresh food control knob to a
WARMER setting decreases the flow of
chilled air into the fresh food section. The
warms at a slower rate and cools at a faster
rate, decreasing the compressor run time
It is ver possible that the auto damper has failed and will need to be cosidered as a likely cause. Part Number Click here=> 61005971 or 1005641 Auto damper control assembly here is the Service manual=> MSD2756G Instructions can be foun on pages 38 and 39 in your manual.If need you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, www.pcappliancerepair.com
Feb 28, 2010 | Maytag MSD2756G Side by Side Refrigerator
Error code 065 jjj jjjj jjj 065 (frigidair Model feb398ceb)
2 Failure
Code
Condition Check/Repair F0 & F1 EOC (Electronic Oven Control) failure Replace F2 Oven too hot Check Bake function F3 Oven temperature sensor open Check oven temperature sensor, 1100 ohms F4 Oven temperature sensor shorted Replace component F5, 6, 7 EOC (Electronic Oven Control) failure Replace component F8 Lock switches Check or Replace component Version 3 Failure
Code
Condition Check/Repair F0 & F1 EOC (Electronic Oven Control) failure Replace EOC (Electronic Oven Control) F2 Oven too hot Likely a bad oven temperature sensor (should read 1100 ohms) Possible bad EOC (Electronic Oven Control) F3 Oven temperature sensor open Replace oven temperature sensor F4 Oven temperature sensor shorted Replace oven temperature sensor F5 or F6 or F7 EOC (Electronic Oven Control) failure Replace EOC(Electronic Oven Control) Version 4 Failure
Code
Condition Check/Repair F1 Circuit board defective Replace control board F2 1. The oven temp has risen above 665F and the door is not locked or
2. The temp has risen above 965F with the door locked 1. Check oven temp in mode that failure occurred. Replace EOC (Electronic Oven Control) if above limits
2. Check 8-pin connector. Check and replace oven temperature sensor if necessary F3 Oven temperature sensor is open (above 3000 ohms) Check resistance of oven temperature sensor, check for open wiring between oven temperature sensor and control F4 Oven temperature sensor is shorted (below 500 ohms) Check resistance of oven temperature sensor, check for shorted wiring between oven temperature sensor and control F5 Internal watchdog circuit has detected a failure Defective EOC (Electronic Oven Control) F6 Shorted buttons Check push buttons and dome switches on control F8 Logic interrupted (lock motor switch sequence) Check door lock switches and wiring
Nov 18, 2008 | Frigidaire Kitchen Ranges
Home Logo
138 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
