Start button continues to flash when pressed but does not start cycle?
    Genius:
  • Washing Mach... Master
  • 1,585 Answers
Check inter lock
Posted on Apr 12, 2015
SOURCE: he2 washer flashing code f51
check hose inside mine had two baby socks clogging it up
Posted on Feb 14, 2008
SOURCE: Kenmore Elite HE3 front loading washer
Before you go crazy trying to solve the F2 code make sure the filter is clear. Disconnect the power cord, PLEASE. Remove the kick plate on the bottom front by removing the 3 screws below it. You will need a hex socket and extension or a torx screw driver. If there is water in the machine and it will not drain you will need a shop vac and some old towels to catch the water when you open the filter. Now, you will see the filter in front of you. Have the towels ready and vac turned on. Quickly unscrew the filter cap and stick the vac hose right in the filter to catch the water. Clean the filter cap. Did you find any socks, money or other debree ? If yes that may have been your problem. Put the filter back on and HAND tighten well. Test the machine. From now on empty all pockets before you do the laundry. You just saved yourself a big repair charge. Be proud of yourself.
Posted on Apr 17, 2008
SOURCE: Door Lock LED flashing
The solution from testy helped me but I decided to change it.
I cut the plastic latch away from the end of the interlock,just the little bar that holds the door closed.This means that the lock position doesn't affect the door.
I then used the little piece of plastic to act as 2 packing pieces to hold the lock half closed. This works fine.
Don't push the lock fully closed or it doesn't work
Posted on Nov 29, 2008
SOURCE: I need to cancel a washing cycle in the middle of the cycle.
i also had this problem, i switched the machine setting to drain, then it cancelled the delay, and i was able to reset
Posted on Sep 11, 2009
  • 7 Answers
SOURCE: I have a zwd12270w. Seven second after pressing
The problem is with the tumble drier heating element. If you remove the top of the machine (disconnect it from the electricity supply first!) you will find a big metal oblong "bar" that runs from the front to the rear of the machine. At the rear there are 4 white wires connected to the metal "bar". Make a note of where they go and remove them. You may need pliers to get a good grip of them. Once removed, the washing machine should work just fine but obviously the tumble drier will not. This is a well known fault and it may be worth contacting Zanussi as they MUST know about it!
Posted on Jul 26, 2011
My washing machine will not turn on.
I suggest you rapid reading of alarms.
  • Press the START/PAUSE button and the nearest option button simultaneously for at least 2 seconds: the LEDs initially switch off, and then display the flashing sequence indicating the last alarm.
  • To display the previous alarms, press the button to the left of the START/PAUSE button in sequence.
  • To return to the last alarm, press the START/PAUSE button.
  • The alarm continues to be displayed for the amount of time required, and then the display returns to its normal operation.
  • While the alarm is being displayed, the appliance continues to perform the cycle or, if in the programme selection phase, it maintains the previously selected options in memory.
Dado
Dec 09, 2015 | Electrolux Washing Machines
I have a Bosch dishwasher model # shx4ap05uc/06 and I want to silence the alarm for when it is done. It goes off every 10 minutes until you open the door
Yes, you can switch the cycle completion signal off (or raise/lower the volume)
1. Switch the dishwasher off using the ON/OFF button
2. Open the door
3. Switch the dishwasher on again. (One of the wash cycle LEDs will flash.)
4. Hold the > button in. Continue holding it and press and release the Start/Reset button once, then release the > button.
"Clean" and one other LED should now be flashing. This indicates that the dishwasher is in the options/settings mode. If they are not flashing, start over at step 1.
5. Press > repeatedly, until the LEDs for "Clean", "Sanitized" and "Rinse Agent" are all flashing.
6. Press repeatedly until none of the LEDs are flashing.
The number of flashing LEDs indicate the volume setting . . .
0 = Silent
1 = Volume level 1
2 = Volume level 2
3 = Volume level 3
7. Press the Start/Reset button once to save the setting and exit the options mode
8. Close the door
9. Switch the dishwasher off.
Hope this helps. Please let me know if you need further assistance.
Regards,
BElectric
May 27, 2011 | Bosch Dishwashers
Front loader stops mid cycle and blinks Er until start button is pressed, the cycle will continue, and sometimes repeats this scenerio three -four times each load. any thoughts anyone?
The control board has detected an error. Press any button to wake the machine then wait for 5 seconds. Press and hold the START/PAUSE and CANCEL buttons simultaneously then the failure code will appear in the display as an "E" followed by two numbers, a number and a letter or two letters as long as the buttons are held. The control will beep and the Door Lock, Wash, Rinse, and Final Spin indicator lights will flash. Post back the code for further advice.
Jan 11, 2011 | Frigidaire Washing Machines
Will not start
look under unit for the book it wil tell you how to get it out of this mode
May 30, 2010 | KitchenAid 24 in. KUDU02FR Built-in...
The digital display is showing a KEY symbol flashing, and i can't program a new load. What does this mean?
This is the childproof lock symbol and prevents you from changing a program once it has been selected The symbol flashes if the program is changed during a wash cycle. If the machine is switched off mid cycle with the lock on then it will continue the program as so as the machine is switched back on. To activate the lock press the START button and hold for 4 seconds and the key is displayed. To deactivate the lock press the START button and hold for 4 seconds until the key symbol disappears.
Sep 30, 2009 | Bosch Exxcel WFX 2467 Front Load Washer
Replaced drum on Dell 1720dn printer. Where is
This should fix the drum light being on that 1720
Turn off the power using the switch on the back of the printer. Open the front door of the printer. Hold Continue button down, power on the printer, and continue to holding Continue down until the LEDs begin to flash. When the LEDs start to flash, release Continue button. The LEDs will continue flashing until only Error LED will be lit. Close the front door. Continue, Ready/Data, Toner Low and Load Paper LEDs should be lit. Wait till the printer completes the POST process. POST is complete when fan noise and rollers stops. After POST wait for 5 seconds Press Cancel button 4 times slowly until the Toner Low LED is lit. This is the procedure resetting the counter. Press and hold Continue until all LEDs begin to cycle in sequence, then release Continue. Now only the Toner Low LED will be lit. Cycle the power of the printer: Remove the power cable - Wait for 5 seconds - Plug the power cable back to the printer - Power the Printer on.
May 13, 2009 | Dell 1720dn Laser Printer
How do I adjust date of my watch bought from GAP
Here is the manual from GAP customer service.
Dear gap.com Customer,
Thank you for your email regarding the Sporty Printed Watch user
instructions. Please accept our apologies that no directions were
received with your order.
The instructions are as follows:
Button Functions:
A. Light
B. Mode
C. Start
D. Reset
Standard Time Adjustment:
1. To set the time, press the Mode button three times (The seconds and
the word Tuesday should start flashing).
2. If the seconds position shows less than 30 seconds, pressing the
Start button will reset the seconds to 00. If the seconds position shows
more than 30 seconds, pressing the Start button will reset the seconds
to 00 and the minutes will increase by 1.
3. Press the Reset button until the area you want to change starts
flashing (i.e., second, minute, hour, day, month, and weekend. Press
Start button once for per unit increment, press and hold for 3 seconds
for speedy advance.
4. At completion, press Mode button to resume standard time display.
To reset the Alarm:
Press the B: Mode button until you reach the alarm.
Press the D: Restart button.
Press the C: Restart button to get back to the time
Sep 29, 2008 | Tag Heuer 2000 Aquaracer WAB2011.BA0803...
Start up cycle continues?
This is the normal start up procedure. The green light will continue to flash until it has completed the startup/warmup rpocedure.
Oct 15, 2007 | Epson AcuLaser C900 Printer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
