Question about Boating
My autopilot wont disengage.i flip the lever on the back but unit stayes navigating
    Problem Solver:
  • 5 Answers
When you have a raymarine wheeldrive mk2 you have to loosen the belt. For that purpose, there is a nut on the back;
Also it can help to flush the drive with fresh water.
Posted on Apr 30, 2015
Mower won't go forward or backward
Is the hydrostatic drive disengaged? On some mowers there is a lever on the hydrostatic drive you can flip to disengage so the mower can be pushed or towed. Other possibility is a broken hydrostatic drive belt.
Jul 22, 2014 | Yard Machines Garden
1803 bobbin winder reset button
there is a part In the machine that work the bobbin winder that is not functioning like it should, a repair technican can tell you why
Apr 15, 2014 | Kenmore Sewing Machines
Why wont my tomberlin stay in nuetral
On most motorcycles the shift drum has 2 levers and springs called a detents. One lever and spring(detent #1) holds the drum in nuetral and the second lever and spring(detent #2) holds the transmission in gear each time a gear is selected. The nuetral detent (detent #1) has a notch that it drops into when it is in nuetral only. If the spring for the nuetral detent is bad or the detent lever does not drop into the notch (for whatever reason) the transmission will not stay in nuetral. The detent levers and springs will be located to the outside of the shift drum, normally opposite the shift lever side of the engine and inside the engine cover.
If you can rock the bike back and forth and find nuetral with the engine off but have trouble getting nuetral with the engine running, the problem with finding nuetral is probably clutch related and is not the detent. Clutches that are not fully disengaging will make it hard to find nuetral with the engine running.
Aug 06, 2012 | Tomberlin Motorcycles
Disengaged transmisson moved lever back now wont engage transmisson
the lever only locks when pulled out just floats when released
Apr 01, 2012 | Garden
I would like to connect my garmin gps72 via the garmin supplied four line plug to the nmea ports in back of my raymarine st6002 autopilot controller. The st6002 controller is plugged into a smartpilot x5...
I connected my Garmin gpsmap76 to a Raymarine autopilot using the NEMA output from the GPS. The autopilot was also on the seatalk bus. It work fine. The GPS provided navigational guidance to the autopilot
Dec 21, 2009 | Garmin GPS 72 GPS Receiver
After replacing the belt, new pulleys, and bolts, my mower wont disengage the blades when i disengage the lever. when i start the mower, the blades are off, but once i engage the lever, they start, but...
sounds like the linkage to your blades, check your lever, to make sure its working right may need some grease, it may be sticking and not fully engaging, or doing its job when its supposed to
Oct 17, 2009 | Craftsman Garden
Raymarine autopilot swings hard over immediatly i select auto
CHECK RUDDER REFERENCE UNIT FOR CONTINUITY(IT IS A POTMETER) CHECK IF MOTOR IS RUNNING IN THE CORRECT DIRECTION ,CHECK CONNECTION OF RUDDER REF UNIT.
Apr 04, 2009 | Raymarine St8002 Smartpilot Autopilot...
Ink
On the fuser (under the top cover), there are 2 green levers with envelopes on them. The one on the right is probably flipped up. The purpose of these levers is to decrease pressure on the paper when printing on envelopes which are 2 or 3 layers of paper. It reduces the wrinkling that occurs when printing envelopes on most laser printers. Flip that lever down and you're golden.
Nov 04, 2008 | Xerox Phaser 6120/YN Laser Printer
Boating Logo
248 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
