Question about Michael Kors Watches
Where to buy screw lug for michael kors watch
escapement
  • 2334 Answers
SOURCE: Wirst band problem
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Don't forget to rate, please.
Posted on Jul 28, 2009
disap1
  • 98 Answers
SOURCE: i have a michael kors white ceramic watch and the
Ceramic links break VERY VERY Easily!!! Take your watch to a reputable watch repair shop and have them adjust your watch band! :-)
Posted on Jan 16, 2010
  • 2501 Answers
SOURCE: How do i set a Michael Kors ladies 5055 watch.
You can get instructionsfrom the Micheal Kors web site.
Enter (copy this) "www.michaelkors.com/category/assistance/service/KORS_Instruction-Warranty.pdf" into your search engine and you will see a long list of instructions and diagrams for the various watches they make.
Choose the one that looks like yours.
Posted on Feb 05, 2010
  • 2501 Answers
SOURCE: I accidently dropped my Michael Kors white ceramic
If you copy the following into your search engine, you will be able to contact Michael Kors to discuss your problem.
"/www.michaelkors.com/store/service/nmAssistance.jhtml"
Posted on Feb 18, 2010
escapement
  • 2334 Answers
SOURCE: how to remove links from
Check out my tips and tricks. You will find explanation there.
Posted on May 18, 2011
Where can I buy winding stems from that will fit Michael kors watch?
sorry but no we do not know .perhaps the manufacturer .
Aug 27, 2015 | Michael Kors Watches
WHAT SIZE BATTERY IS IN THE MICHAEL KORS WATCH
OMG, why does it take s much to answer and who wrote the first answer? Perhaps she works for some repair woman? The answer to this question for Michael Kors Acrylic Womens Watch MK5248 is a 364 battery. It took longer for me to find the answer to this question than it did to replace the battery on my gf's watch. Here's a tip go to a hardware store or Amazon.com and by it for much cheaper than Walmart or like stores. you van get a 10 pack for about $5 on Amazon. Remove the screws over a white pillow case so that when/if they fall as you remove them you can easily see them. Took less than 5 mins to remove and replace the battery. Enjoy
Oct 17, 2014 | Michael Kors Watches
Does michael kors watch 5498 use battery?
Yes, MK5498 uses battery.
Regards.
TicTacArea.com is Official Michael Kors dealer
Michael Kors Watches MK
Aug 18, 2014 | Watches
How do I remove links from Michael Kors watches?
I keep getting spam about michael kors watches too.
Aug 02, 2014 | Michael Kors MK8072 Wrist Watch for Men
How can i remove the back from a mk watch that has four screws
Tricky question here.
If the watch case is made of metal, you will have no problem finding a screwdriver in some electronics parts store.
But be careful!!, if your MK has got a policarbonate case you are in danger by doing it yourself.
May happen you damage the screws head , and then you have to buy a new (and really expensive) case for your beloved watch.
If this is your case, I'd rather took it to a Michael Kors watch shop to do the job. It can save you a lot of money.
Regards.
Jun 15, 2014 | Michael Kors Watches
Where can I buy this watch
I can sell my Michael kors watch mk5060 email me
Dec 18, 2012 | Michael Kors MK5060 Watch
Changing battery in Michael Kors watch
back off, remove old battery, install new battery, back on
Sep 21, 2012 | Michael Kors Chronograph MK5198 Watch for...
Broken band on MK5235, where or how to fix it?
Only one place if you need anything other than a pin or screw. That would be the manufacturer. I a pin or screw is what is required, go to a watchmaker. They will have the required part usually. My experience is not good dealing with fashion watch manufacturers. Look in the booklet that came for your watch for the M Kors service center and call or write for directions. Good luck, Michael
Nov 03, 2011 | Michael Kors MK5235 Watch
Watches Logo
206 people viewed this question
Top Michael Kors Watches Experts
Ansel Alberto
Ansel Alberto
colinat108
deton8 von Splosion
Are you a Michael Kors Watch Expert? Answer questions, earn points and help others
