Question about Refrigerators
Change fridge thermostat - Refrigerators
  • Refrigerators Master
  • 5,323 Answers
See atttached pics hopes it helps
change fridge thermostat - change-fridge-thermostat-iizpua1124tc1voeqjalmrl5-3-0.jpg
Posted on May 07, 2015
The refrigerator runs almost continually for no apparent reason. It started a few days ago. We have changed nothing.
There are four likely reasons:-
If it is not a frost free refridgerator, the thermostat is iced up and not sensing temperature - defrost the fridge.
The thermostat is faulty and in this case the contents of the fridge should be freezing up - replace the thermostat.
The gas is low in the system and the fridge should then be warmer than normal and the thermostat is trying to compensate by having the compressor running constantly - re-gas the fridge.
The door seal is leaking or the door is not closing fully, allowing cold air to escape - check the seal and the door and correct or replace the seal.
Please rate this response.
May 21, 2011 | Refrigerators
Idesit BAAN134 PSUK fridge keeps freezing food . The fridge part of my tower f/f keeps freezing food even though I have turned the dial down to the minimum the temperature regularly drops to below...
If it is an electronic thermostat it could be that the engineer has changed the board but not the sensor which reads the temp. If it is a mechanical thermostat it may be hes fitted the wrong type.It could also be that the system is short of refrigerant and the actual refrigerant charge is not getting all the way to the thermoststs sensor to switch it off, the back wall of the fridge should be frosted at least 3/4 of the way down and not just forming in a small part of the fridge.
Jan 05, 2010 | Refrigerators
Hotpoint fridge freezer icing up freezer and fridge does not work
Does your model have independent thermostats for the fridge & freezer???
If not, could be that you will need to change the Thermostat.
These are not expensive - around £10 if you buy on the Internet.
Easy to fit yourself...just turn off the power, remove the power plug from the wall, then unscrew the 'stat unit from inside near the top of the fridge (some are attached to the interior light) and remove the screw holding the thermostat tube to the rear wall.
Often the thermostat gets a small hole somewhere in the long tube, which then lets all the gas escape, making the stat useless.
You can see these small holes in the pipe if you use a magnifying eyeglass, like the kind Jewellers use.
Nov 17, 2009 | Freezers
I have the same problem.
test thermostat. when fridge is running, turn dial to lowest setting , fridge should turn off. then when fridge is not running,turn to highest setting, fridge should turn on. if it fails this test thermostat is faulty and needs to be replaced
Sep 10, 2009 | Maytag MBB2256G Bottom Freezer...
Fridge keeps freezing
If u change the thermostat and it keeps freezing the heater or timer are bad
Jul 24, 2009 | Westinghouse Refrigerators
Side by side frezer frezes up icebox side won't stay cold until manualy thaw fezer side the icebox side cools for a few days.
sound like a timmer and a thermostat to me
we have had the same problem from time to time usualy we just change the thermostat out and problem solved
remember to unplug the fridge for a 24 hour period to de thaw the baffels in the fridge after you change the thermostat
also check your drain lines in the back they might also be pluged
another words wrap your lips arround the pipe in the rear of the fridge and blow if there is back preasure then you probably have a blockage
Jul 23, 2009 | Refrigerators
Refrigerators Logo
54 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
