Question about Hipstreet Flare 9 inch Tablet with 8GB Memory and Case
Worked than tried turning it on again onlt to see a solide question mark on it. shut it a few times to turn it back on but the question mark is still there
    Sergeant:
  • 242 Answers
Don't make it worse and or get confused from our many great answers...Take it to a repair shop...
Posted on Apr 05, 2015
Shows 99% won't open and can't shut down
You can first try doing what's called doing a Soft Reset. It's the first and preferred method to try as you don't lose any files or settings. Hold the power button until the Nook turns itself off. In most cases that will be twenty seconds or more. Then turn the power back on by holding the power button down for about two seconds. Hopefully this will allow you to complete a normal boot process. The second and more dramatic way to get a working Nook back is what's called doing a Hard Reset. This process will put your Nook back to "Just Out of the Box" mode. You will lose any files and settings stored internally inside the Nook itself. The good part in all this is it won't touch anything stored externally on your external SD Cards. To do a Hard Reset Turn the NOOK off completely. Hold the Power button and Home (n) buttons. The device will turn on. Continue to hold both buttons until the device shuts off once again (~15-20 seconds). Turn the device on normally. It will prompt for a factory reset. Press the Home button twice to confirm. ------- The important part in the above is to be sure you start the Nook via holding down both the power button and the Home (n) buttons at the very same time and keep them both pressed down until the Nook turns itself off.
Mar 07, 2015 | Nook HD+
How do i fix my asus tablet its froozen on screen cant turn it off
Take a flat object like a butter knife, start near a corner and pop the back cover loose...then work your way around removing the cover, pull the battery out, press and hold the power button for a few seconds, put the battery back in, put the cover back on, turn the tablet back on.
Feb 17, 2015 | ASUS MeMO Pad HD 7
My kindle fire has frozen and I cannot change app or switch it off - what do I do?
Press the on/off button and let the sleep screen show up without the light. Then press the on/off button again and hold it just a few seconds and it'll shut off
Feb 03, 2015 | Amazon Kindle Fire HD
My tablet won't turn on. I was on it and it had a good amount on the battery left and it just shut off and won't turn back on. It's a 7" rca
Even with "enough" power you should first try to charge the battery. When the app forgot to refresh the battery bar on the screen, there was less power then expected.
If it after a normal charging time still does not want to switch on, there must be a serious defect. Perhaps even the battery.
A tablet also can power down when it is getting to hot, but after a few minutes of rest it should work fine again.
Jul 26, 2014 | Tablets & eReaders
I have a white screen what do i do my tablet is 7 inch
If you just dropped it on carpeted floor there should not be a problem, unless you have a bad tablet. Try shutting the power down by pushing down the on and off button with the volume button at the same time. This may take a few moments but it should work, once it is shut off leave it off for awhile, the turn it back on and it may work for you.
Feb 18, 2014 | Android 7 inch Tablet
Safari shuts down when new tab
Most of the time things like this happen not everyone's good at working with technology if it shuts down you either have waayy to much memory or just turn it off and turn it back on again.
Dec 17, 2013 | Apple iPad Mini with Retina Display
Ablet doesnt download app at app store says need SD cardt
Try shutting down your tablet completely and wait a few minutes before turning it back on. Turn it on and see if that helped. That happened to my tablet too and I shut it down a while and it worked.
Aug 07, 2013 | Tablets & eReaders
Emerson tablet touch screen is frozen. How do I get it to work?
There is a tiny reset hole on the back of the tablet marked with a "R" near the SD card slot. Push a small paper clip in the hole until you feel it hit the button. This will reset the tablet and the touch screen will start working again once you power it back up. --Emerson m744 android tablet.
Dec 04, 2012 | Tablets & eReaders
Why does my tablet when i turn it on it has a battery sign with an explanation mark inside it and will not turn on
The exclamation mark means that your tablet has no battery left. You should try plugging your tablet in for a few hours before turning it on (if it doesn't turn on by itself.) If that doesn't work and you still see the exclamation mark, I suggest that you ensure the charger is properly plugged in to the socket and that its properly attached to the tablet.
Sep 05, 2012 | Tablets & eReaders
Wont turn on...before this it would shut off and then power on like it was loading a web page..I have only had this kindle since Christmas.
I received my 3g model for Christmas as well. Last night, it lost wireless connectivity, froze and then would not turn back on, even though it was fully charge. However, I charged overnight again.
This morning, I held the on switch for much longer than normal, until the green light started flickering. I received a simple black screen a few times, but contintinued to hold the switch on. Then it reset itself and all is good.
So I know that sounds like a simple solution, but maybe worth trying. Good luck. It's disgusting, I know. I was so upset.
Jan 24, 2011 | Amazon Kindle 3G
Hipstreet Flare 9 inch Tablet with 8GB Memory and Case Logo
47 people viewed this question
Top Hipstreet Tablets & eReaders Experts
Lawrence Oravetz
ray gallant
Are you a Hipstreet Tablet and eReader Expert? Answer questions, earn points and help others
