Question about Home Security
PLEASE PLEASE HELP ME I AM BEGGIN u I sent a picture in earlier of the inside of my outside wireless IP SECURITY CAMERA as I cannot find the SD card slot It's not on the camera Its inside its like pic
    Top Expert:
  • 6,702 Answers
It is the metal and shiny square on the left, mounted on the blue circuit board. On this picture you have to slide the card in from the left.
Posted on Apr 05, 2015
t00nz
  • 4738 Answers
SOURCE: reformatting an SD memory cardf
You can format the card in your camera while not connected to your computer. In fact it's recommended to do so. Read your instruction book to find out how. It should be a selection available from your "menu" button when in image review mode. Select "low-level" or "full" format, not "quick" format (quick format is only good for erasing pictures).
Posted on Jan 12, 2008
SOURCE: memory card stuck in camera slot
No need for pliers! I was able to eject the memory card by sliding a packing knife along the edge of the memory card. The blade was very thin, narrow, and long. I'm not sure if a regular box cutting knife blade would do. I've been able to eject the memory card with ease about a dozen times using this method.
Since I can't eject the SD card on the go, I use the USB cable to download images from the camera. Glad to know I can remove this when absolutely necessary, but sure wish I could remove anytime I'd like.
Jason
Posted on May 11, 2008
  • 3 Answers
SOURCE: camera screen said SD card is locked when I installed an SD card
#1) On my camera if there was a picture that got stored in the internal memory it would not reconize the sd card nor store the pictures on the sd card. I would have to take the sd card out and delete the pictures in the internal memory and then reinsert the sd card.
#2) Some how or other the files that were on the sd card would get scrambled on the sd card when I would try to erase them. I would have to reformat the sd card back to a "fat" format before it would work again.
Posted on Jul 28, 2009
  • 3287 Answers
SOURCE: Camera doesn't recognize the sd card, bypasses it
1) This camera accepts SD cards up to 4 GB in capacity. Most 4 GB SD cards however, are "SDHC" types (check the label to determine which type you are using). If you are using a 4 GB "SDHC" card, it may be causing the problem, as it is not an "SD" card. Furthermore, any card greater than 4 GB is not compatible with the camera. Any SD card with a capacity less than 4 GB should work without issue.
2) Check the position of the lock or "protect" tab on the side of a compatible SD card to be sure it is in the unlock position. The camera will be unable to write to a locked or protected card.
http://www.moultriefeeders.com/Game-Spy-D40
I hope this helps!
Posted on Oct 20, 2009
  • 11967 Answers
SOURCE: coolpix s220 won't transfer pics via usb cable
If you can get the pics using a card reader, why are you insisting on using the camera and USB cord? Pros always use a card reader.
Posted on Feb 07, 2010
Dlink cloud camera buzzing
I had the same issue - this is a bad amplifier in the camera, I was under warranty when it happened, they sent me a new one. Dlink cameras are hit and miss. I have some INDOOR camera that have been running OUTSIDE (covered) in FL for years. Then I had one inside 6 months - just stopped working. Their quality is so, so.
Jan 18, 2014 | D-Link DCS-5010L Cloud Wireless IP Camera,...
Can't connect to wireless camera on cell phone
Did you forward the port the camera is on in the router? You need to do this otherwise you cannot access the camera from an outside IP address.
Jan 13, 2014 | Uniden Guardian Advanced Wireless 2-Camera...
Casio EXILIM EXH5 - My camera is storing pictures at the camera memory. I have earlier used the SD Card for picture storing - How do I switch to SD Card for picture storing again?
With no card in the camera, go into the menu and find "format" (called "initialize" on some cameras) and follow the on-screen instructions to erase the internal memory. Then, your card should work properly.
Aug 22, 2011 | Casio EXILIM EXH5 Digital Camera
Need help with moving pictures from internal Kodak Z740 to SD card
Hi.
You will need to use a computer, there is no option for direct transfer from internal memory to SD card.
Remove the SD card from inside the camera and connect the camera to the computer using an USB cable. With no SD card the computer will show the pictures stored in camera's internal memory. Copy the pictures in the internal memory in computer hard disk, then eventually move them onto the SD card.
Regards.
Ginko
Jul 18, 2011 | Pentax Optio S Digital Camera
I need help with my new HTC G2!!! How do I download pictures sent in my picture messages? I want to save them and can't figure out how, it's a little frustrating! THANKS!!!
You need a USB adapter that reads the SD card and a pc suite. You can get them a computer store or Camera store.... its the easiest way because picture messages in the phone itself are copyright.
Oct 18, 2010 | HTC Cell Phones
Doesn't recognize memory card. I had an Eye Fi wireless memory card installed and now it's totally blank and the camera doesn't recognize it. Tried a regular SD memory card, and the camera doesn't...
Your camera is only supporting SD/MMC Cards (up to 2 GB)
The card that you currently have might be faulty. Please try another card.
You might also need to switch the camera over to saving pictures directly onto the SD card.1: Menu, Cam settings, Chose AUTO or SD card option Press OK
Note: If the SD card isn't in the camera or is unreadable the camera will automatically go back to saving you taken pictures on the internal memory.
Jan 23, 2010 | Kodak EasyShare Z740 Digital Camera
Memory card not showing all pictures on camera
That doesnt mean that they have not been deleted after you looked at them this morning.
Remove the card and use a card reader to access the card to see ALL of the pictures currently on the card. This is like having a second opinion, both can't be wrong. The other aspect is that some pics are in memory and not on the SD card
Please rate our help to keep the FREE service online++++Thanks for using FIXYA
Sep 12, 2009 | Nikon Coolpix S210 Digital Camera
Dell 948 wireless printer
hi,
u need to have wireless internet connection, first uninstall the printer sw, while reinstalling choose wireless install, follow inst, connect the printer, configure wireless adapter by choosing the correct wireless nw and by entering the security key(WEP, WPA), if wireless adapter not detected then, unplug all cables from back of printer,removed wirless adapter, press power button for 20 secs without any cables connected, connect cables, restart printer, connect the wireless adapter, u will get msg nw card detected, then try reconfiguring by entering the correct keys, in case if u dont know the security key contact ur internet service provider, once correct details are entered it will configure successfully, unplug usb cable from printer and pc, install printer sw, issue resolved, if there is no communication then check the firewall settings, anything relating to printer give full access, restart pc, try printing,
ps: if usb cable is connected to printer the nw card will be disabled.
Nov 03, 2008 | Dell 948 All-In-One InkJet Printer
Home Security Logo
69 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
