Question about Hotpoint Washing Machines
My hotpoint WMPG742P was not working and an engineer came and changed a circuit board, now all it shows on the display is F09, what can this be?
The engineer doesn't want to know now
    Genius:
  • Hotpoint Master
  • 1,585 Answers
Get another reputable repair person
Posted on Apr 05, 2015
I have a hotpoint ultima wf860 it was all fine then all of a sudden its saying the error code f-18 how can I fix this please as I havent enough money for a newone yet. many thanks x
Hi, The link below is a user manual for a hotpoint ultima wf860 and below that are the error codes, I wish you all the best......CHEERS...
file:///C:/Users/Steve/Desktop/4992cbf9-f956-4127-bdab-caa958e02377.pdf <---"NEED TO COPY AND PASTE"
Hotpoint Washer Error CodesF01 - Electronic circuit board fault
F02 - Motor circuit fault
F03 - Temperature sensing fault
F05 - Waste pipe blockage or pump issue
F06 - Door lock fault
F07 - Electronic circuit board fault / heating circuit fault
F08 - Heater fault
F09 - Software fault
F11 - Pump circuit fault
F12 - Electronic control fault
F13 - Dryer temperature sensing fault (washer dryers only)
F15 - Heater control fault (washing machines and washer dryers)
F16 - Drum lock position sensor fault (top loading machines only)
F18 - Internal data error
F19 - Fan motor or heating fault (washer dryers only)
Apr 01, 2016 | Hotpoint Washing Machines
Machine stops working and shows F09 what does this mean
Really need the make and model as different manufacturers use the same code to mean different things. Hotpoint/Indesit/Creda F09 on almost all appliances means "Eprom Fault" this is a problem with the main control chip and you will need an engineer to reprogram the main module or swap it out. If it's Bosch, then the good news is F09 means "Heater Fault" which almost certainly means a cheap £20 replacement heating element needs fitting
Sep 19, 2015 | Washing Machines
Washer stops working and displays F6
hotpoint?
"EVO1 Washing Machines and Washer Dryers" open="0" style="2"]
  • F01 - Short circuit motor triac*
  • F02 - Motor jammed tacho detached*
  • F03 - Wash thermistor open/short circuit*
  • F04 - Pressure switch jammed on empty*
  • F05 - Pressure switch jammed on full*
  • F06 - Program selector error*
  • F07 - Heater relay stuck*
  • F08 - Heater relay cannot be activated*
  • F09 - Incompatible eeprom*
  • F10 - Pressure switch not sensing correctly*
  • F11 - Pump cannot be activated*
  • F12 - Communication error*
  • F13 - Dryer fan or dryer thermistor faulty*
  • F14 - Dryer element faulty*
  • F15 - Dryer element relay faulty*
  • H20 - Not fillings. Check tap, hose and inlet valves
  • LOCKED - Check interlock*
Aug 24, 2015 | Washing Machines
What is a f12 fault
F02 - Motor jammed or fan blocked*
F03 - Front thermistor open/short circuit*
F04 - No pump piloting*
F05 - No feedback from the pump*
F08 - Static heater relay with contact welded closed*
F09 - Eeprom is not programmed or not functioning*
F10 - Common of heater open or one shot open*
F11 - No pump connection*
F12 - Communication error between board*
F13 - Rear thermistor open/short circuit*
F15 - Dynamic heater relay with contact welded closed*
F17 - Master relay welded closed* - See more at: http://www.hotpointservice.ie/help-and-advice/error-codes/#sthash.nR8Jb1cP.dpuf
Dec 12, 2014 | Hotpoint Dryers
Hotpoint wmd960
F09 EElectronic module configuration error Washing machine controller EEPROM is either not programmed or is not functioning
  • Check EEPROM
Dec 27, 2013 | Washing Machines
Ariston washing machine. Error code F09
Most Indesit ( Hotpoint, Ariston) machine's 'F09' decodes as ' incompatible eeprom' or eeprom error, check/change eeprom'. Sorry, whichever it is requires an engineer call ;-0(
Hopefully it might only need connectors reseating.
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Jun 28, 2011 | Ariston Technologies Washing Machines
HOTPOINT F09 FAULT CODE, WHAT DOES IT MEAN?
Error code F09 means that that the Eeprom is not programmed or is not functioning.
Check the Eeprom and control board.connections.
Eeprom is short for electronic programme controller.
Please rate my solution.
Thanks.
Nov 18, 2009 | Hotpoint Dryers
Hotpoint washing machine WF 840 displaying F-09
f09 is a communication fault on the computer board.A suggestion to you would be to unplug unit.Carefully remove and reistall each wire at board
Nov 01, 2009 | Hotpoint Ultima WF860 Front Load Washer
I have a hotpoint washing machine WF840 which is displaying F-09, do you know the fault
f09 i s a communication problem between mother board and controls.Before replacing board, I would suggest unplugging unit and re-terminating each connecter going to board
Machine wont work and flashes f12 on function display
f12 is a communication error between the circuit boards. engineer job. if the machine is less than 5 years old the parts are free but the callout +repair's about £100 from hotpoint.
Jan 25, 2009 | Hotpoint Ultima WD72 Front Load...
Washing Machines Logo
73 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
