Question about Saws
Powerbase Xtreme 800W reciprocating saw.
The tool-free blade clamp ring is supposed to turn a few degrees anti-clockwise and clockwise, to insert and to remove the blade. But it won't turn, so i can't insert the blade. it turned yesterday, when I wanted to remove the blade, which I did, so I could replace the saw in its case. Do you have the same make and model? help!
joboo1
  • 257 Answers
SOURCE: I need instructions on removing the front housing
Hi again Guy, It is easy to overlook the obvious, I do it a lot. There are two allen screws in the rubber boot at the front bottom that need to be removed to release the foot (or shoe), which should slide out the end. Then the whole boot ( forward hand grip) pulls off the end exposing the assembly you need to replace. Good Luck to you, this should Fixya!
Posted on Mar 23, 2009
rowdy45176
  • 2176 Answers
SOURCE: Reciprocating saw-snapped blade-cannot be removed
What I would try is to spray some WD40 on the pin first and then see if you can find a small screwdriver or punch and try pushing the pin in further to release the broken blade. It doesn't sound as though it is anything major, maybe a burr on the side of the pin or possibly rust or debris. DON"T hit the pin because you might damage it or push it in and never get it back out. Looked at a diagram and it appears that they used roll pins to hold the clamp in place so it might be that one is cracked or mushroomed and you might have to drive them out. I suggest that you go to Searspartsdirect.com and type in your model number to look at the same diagram.
Posted on May 26, 2009
  • 88 Answers
SOURCE: my milwaukee sawzall quik lok blade clamp will not
try pushing in collar or pulling out while truning
Posted on Aug 24, 2009
SRF518
  • 232 Answers
SOURCE: Where to get a replacement quick change blade
have you tried Sears?
Posted on Oct 20, 2009
airnailer
  • 109 Answers
SOURCE: Repair procedure for the replacing tool-less blade clamp
toolpartsdirect.com,,,schematics and parts
Posted on Dec 03, 2009
How do I replace the tool-less blade clamp in a craftsman 8 amp reciprocating saw
Craftsman Reciprocating Saw replace the tool-less blade clamp
Jun 10, 2015 | Craftsman Saws
I had to disassemble the tool-less blade clamp on my Ridgid reciprocating saw. When I reassembled it the retention pin no longer moves back and forth when I flip the blade change lever (not sure if...
The spring loaded clamp sleve mechanically holds the blade pin down to hold the blade in place. It doesn't pull it up to release the blade but simply lets the pin float freely so the blade can be removed.
Sep 06, 2012 | Ridgid R3020 27248 12 Amp Twist Handle...
Blade too thick got stuck
lock the blade in a vise or grip it tightly and with the clamp open TAP on the shoe to pull the saw away from the blade. Use gloves and unplug the tool before attempting.
Jan 05, 2012 | Makita JR3030T Variable Speed...
Cannot put blade into 310 reciprocating saw the instructions in the manual do not make it clear
Point tool away from body.
2. Rotate blade clamp collar (the knurled diamond pattern knob just at the back of where the blade goes) to release position.
3. Insert blade shank from the front.
4. Rotate blade clamp collar to lock blade into position.
May 25, 2011 | Dewalt DW310K Heavy Duty Reciprocating Saw...
How do i intall a blade on a DW303 Reciprocating saw?
To install blade into saw:
1. Loosen set screw.
2. Insert blade shank from the front between the reciprocating shaft and the blade clamp.
Locate hole in blade over pin on reciprocating shaft.
3. Tighten set screw. If the blade should break off and the shank does not come out of the clamp,
be sure the set screw is loose and eject the shank with a nail or pointed object.
May 05, 2011 | Dewalt DW310K Heavy Duty Reciprocating Saw...
My partner got me a powerbase xtreme 800w jigsaw with laser fo christmas. when i came to use it the blade keeps coming out so what can i do???
There is a locking device, screw, thumb screw or an over center lever that will lock the blade in place.
Mar 13, 2011 | Garden
I bought a Dewalt DW310 reciprocating saw and there seems to be no way to install a blade. The instructions show a wheel to turn to unlock the blade chuck but the wheel is up inside the saw body where you...
The blade clamp collar is a spring loaded knob of sorts that holds the blade in place. If you are not able to pull the blade shaft out of the saw to get at it, plug the saw in and hit the on/off trigger a few times to get the shaft and knob out of the body of the saw. Once you can get at the knob it should be easy to turn it and insert a new blade. Let me know if you have problems.
Aug 30, 2010 | Dewalt DW310K Heavy Duty Reciprocating Saw...
Saw blade loosens no matter how much or often I
put a little bit off LOC-TITE on screw, worked for me
Apr 08, 2010 | Craftsman 8.0 amp Reciprocating Saw
Clamping a blade in the saw
it's either a cylinder behind fence,twist it to open,let go so it close's. or there is a lever on the side that you lift up to insert blade let down to hold in place
Apr 07, 2010 | Dewalt 10.0 AMP Reciprocating Saw
Saws Logo
310 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
